6589 Discussions
Caffe Import Error with fresh installed SDK (help) - NCSDK 1.09.00.04 - x86_64 - Ubuntu 16.04
"make examples" gives import errors with Caffe models while Tensorflow import works. Error Message mvNCCompile -w bvlc_googlenet.caffemodel -s 12 deploy.prototxt mvNCCompile v02.00, Copyright @ Movidius Ltd 2016 Caffe Import Error Configuration ----- NCSDK 1.09.00.04 Cloned ncsdk github from master commit 163be9b462411802fba2ea7be4e18759a7dd6c11 (grafted, HEAD -> master, origin/master, origin/HEAD) Author: Neal Smith <neal.p.smith@intel.com> Date: Tue Oct 24 10:16:04 2017 -0700 ----- Running Linux 16.04 on x86_64 Caffe automatically installed in /opt/movidius is branch fathom_branch commit eeebdab16155d34ff8f5f42137da7df4d1c7eab0
Had the same Import Caffe error while make examples on Raspberry Pi3 with already existing OpenCV and Python 2/3
I managed to solve the problem by force re-installing the python decorator:
sudo apt-get install --reinstall python*-decorator
After it the make examples command work flawlessly!
For posterity, I am seeing the same mvnc, graph, caffe issue on a fresh ubuntu 16.04 install. It appears to fail when using virtualenvs and work fine when not. I don't have a solution however will post back here if I look into it and find one or will check back if someone else has. Thanks.
To add to feedback's comment: On a Raspi 3 B+ installing Rasbian from NOOBS, I found
sudo apt-get install --reinstall python3*-decorator
did correct the problem.
@braca @ashutosh hello! I get the same error with you when I first ran "make examples" after the ncsdk install, and I can't figure it out. Can you tell me how did you figure it?I would appreciate any help in resolving this error.
Caffe Import Error
make[4]: Leaving directory '/home/luis/workspace/ncsdk/examples/caffe/GoogLeNet'
cp: cannot stat '../../caffe/GoogLeNet/graph': No such file or directory
Makefile:9: recipe for target 'googlenet' failed
make[3]: *** [googlenet] Error 1
make[3]: Leaving directory '/home/luis/workspace/ncsdk/examples/apps/multistick_cpp'
Makefile:12: recipe for target 'multistick_cpp/.' failed
make[2]: *** [multistick_cpp/.] Error 2
make[2]: Leaving directory '/home/luis/workspace/ncsdk/examples/apps'
Makefile:12: recipe for target 'apps/.' failed
make[1]: *** [apps/.] Error 2
make[1]: Leaving directory '/home/luis/workspace/ncsdk/examples'
Makefile:51: recipe for target 'examples' failed
make: *** [examples] Error 2
