Installation Failed
Hey, I'm using school computers for installation. I think I do not have the privilege to make changes in the bin directory. Is there any way so that I could avoid installing opencv since opencv is already installed?
Thanks!
@yyt224 There isn't an option to skip the OpenCV installation, however you can edit the install-opencv.sh and uninstall-opencv.sh scripts and do a select all and delete the contents of the scripts, then save the files. This should skip the step where the ncsdk installs a new version of OpenCV and uninstalls your current installation of OpenCV.
