6584 Discussions
Caffe Import Error with fresh installed SDK (help) - NCSDK 1.09.00.04 - x86_64 - Ubuntu 16.04
"make examples" gives import errors with Caffe models while Tensorflow import works. Error Message mvNCCompile -w bvlc_googlenet.caffemodel -s 12 deploy.prototxt mvNCCompile v02.00, Copyright @ Movidius Ltd 2016 Caffe Import Error Configuration ----- NCSDK 1.09.00.04 Cloned ncsdk github from master commit 163be9b462411802fba2ea7be4e18759a7dd6c11 (grafted, HEAD -> master, origin/master, origin/HEAD) Author: Neal Smith <neal.p.smith@intel.com> Date: Tue Oct 24 10:16:04 2017 -0700 ----- Running Linux 16.04 on x86_64 Caffe automatically installed in /opt/movidius is branch fathom_branch commit eeebdab16155d34ff8f5f42137da7df4d1c7eab0
@eruffaldi Hi. It looks like your python path environment variable isn't properly set. You can check this by typing in $echo $PYTHONPATH. You should be able to see a file path similar to /opt/movidius/caffe/python. Also make sure you are using the same account as the one you used to install the SDK. Let me know if this fixes your problem. Thanks.
Just got the stick and had same problem I think they need to fix something!
@Tome_at_Intel Already made sure the path in PYTHONPATH is included. Any other suggestions to fix this?
@braca v1.09.00 requires PYTHONPATH to include /opt/movidius/mvnc/python as well. Please add export PYTHONPATH=/opt/movidius/caffe/python:/opt/movidius/mvnc/python:$PYTHONPATH to /etc/bash.bashrc, run source /etc/bash.bashrc and try again.
I was getting a similar error on my system, the above change fixed my issue. Your issue might not be the same as mine, but it's worth a shot.
@AshwinVijayakumar Thanks a lot! Already tried and source with what you suggested and still same problem. This is what I did:
  1. Follow directions in https://developer.movidius.com/start until number 3.
  2.
  3. Configure and source again the PYTHONPATH.
  4.
  5. Get this error:
  6.
Caffe Import Error
make[4]: Leaving directory '/home/luis/workspace/ncsdk/examples/caffe/GoogLeNet'
cp: cannot stat '../../caffe/GoogLeNet/graph': No such file or directory
Makefile:9: recipe for target 'googlenet' failed
make[3]: *** [googlenet] Error 1
make[3]: Leaving directory '/home/luis/workspace/ncsdk/examples/apps/multistick_cpp'
Makefile:12: recipe for target 'multistick_cpp/.' failed
make[2]: *** [multistick_cpp/.] Error 2
make[2]: Leaving directory '/home/luis/workspace/ncsdk/examples/apps'
Makefile:12: recipe for target 'apps/.' failed
make[1]: *** [apps/.] Error 2
make[1]: Leaving directory '/home/luis/workspace/ncsdk/examples'
Makefile:51: recipe for target 'examples' failed
make: *** [examples] Error 2
Thanks for any help look forward to testing the stick and make it work. I'm using Ubuntu 16.04
@braca the error messages in https://ncsforum.movidius.com/discussion/comment/758/#Comment_758 is basically because make examples wasn't able to compile GoogLeNet (and other downloaded networks) into a graph file. cp: cannot stat '../../caffe/GoogLeNet/graph': No such file or directory explains the situation.
mvNCCompile isn't running because of the Caffe Import Error problem. I haven't come across this problem except when it was a PYTHONPATH issue, so we'll have to take some blind shots here :smile: .
  • Did you by any chance have an existing Caffe, OpenCV or Python installation?
  • Are you aware of any access permission changes w.r.t /opt/movidius/caffe/python or /opt/movidius/mvnc/python?
  • @pashmina.bendale tried a workaround on the previous SDK installation, this could be a good resource to help debug your issue - https://ncsforum.movidius.com/discussion/comment/527/#Comment_527
  • Have you tried installing on a fresh Ubuntu OS?
@AshwinVijayakumar Thanks a lot! It's already working!!! I figured it was because I already have existing installations of caffe and opencv so it some how messes thing up. You might wanna add a comment somewhere to careful about it.
I'm experiencing the same problem. Pretty Fresh Ubuntu installation (maybe 2 weeks old), no prior caffe installation. Tried everything mentioned in this thread. @braca how did you eventually get this fixed?
I have to say I've been fighting these scripts all day… Considering there is only one platform to support it seems a bit buggy.
@Yakumo01 you are right. Even with a fresh installation of ubuntu got the same problem and still no idea how to fix it. It worked on my raspberry pi though, but I see errors with memory problems, alexnet is not loaded.
@Yakumo01 What is the exact error that you get? Can you copy it here to see what's happening exactly and try to find the origin of your problem. Thanks
Ok I eventually figured this out, but really I've spent many hours installing this SDK, fighting numerous script bugs (what's with the weird combination of sudo and non sudo calls in install?). Short version is import caffe would always fail due to scikit being missing. I needed to run:
sudo pip3 install scikit-image
And then everything was golden.
@Yakumo01 Good that you fixed your problem. Tha main thing is to run installation only with "make install" on your user account without sudo. On some point install script may ask you for your password. Running installation as root fails and that was mentioned somewhere in thr forum.
I was thinking scikit-image package comes with 16.04 natively, not sure though.
I am also running into the "caffe import error" issue described by @braca above.
When I first ran "make examples" after the ncsdk install, I got an error:
ModuleNotFoundError: No module named 'mvnc'
I don't have a directory /opt/movidius/mvnc/python. After searching for mvnc, I found it in /opt/movidius/NCSDK/ncsdk-x86_64/api/python, so I added that directory to PYTHONPATH
That resolved the error above and next I got this error:
ModuleNotFoundError: No module named 'graphviz'
I proceeded to install graphviz and that error went away and now I get the "Caffe Import error".
I am running Ubuntu 16/04 and am running all the steps in a fresh conda environment. I have also installed scikt-image in this environment as suggested above.
I would appreciate any help in resolving this error.
Ashutosh
@ashutosh Maybe this discussion can be of some help to you
https://ncsforum.movidius.com/discussion/326/make-examples-error#latest
Hi @georgievm_cms,
I have installed graphviz. I had originally installed it using pip3 and it is version 2.38.0 (confirmed by 'dot -V'). I also tried installing it via 'sudo apt-get install' and got the message that it was already installed.
So my error is exactly the one at the top of this thread:
Caffe Import Error
From what I am seeing there is a general pattern to the errors people are seeing with Ubuntu 16.04:
  • not finding mvnc (which is resolved by updating PYTHONPATH)
  • not finding graphviz (which is resolved by installing it)
    which leaves the "Caffe Import Error".
Any chance you can provide a docker image of a working install that we can run?
Ashutosh
I was looking in my install logs and even though it says "Setup is complete", there are errors in the "make install" step.
I made sure I have libtiff5, opencv and libboost-python installed, but that has not resolved these errors.
So I think this is the real issue:
[ 75%] Linking CXX executable compute_image_mean
/usr/lib/x86_64-linux-gnu/libopencv_highgui.so.2.4.9: undefined reference to TI FFReadRGBAStrip@LIBTIFF_4.0' /usr/lib/gcc/x86_64-linux-gnu/5/../../../x86_64-linux-gnu/libboost_python.so: un defined reference toPyUnicodeUCS4_FromEncodedObject'
defined reference to PyNumber_InPlaceDivide' /usr/lib/gcc/x86_64-linux-gnu/5/../../../x86_64-linux-gnu/libboost_python.so: un defined reference toPyString_Size'
defined reference to PyString_FromStringAndSize' /usr/lib/x86_64-linux-gnu/libopencv_highgui.so.2.4.9: undefined reference toTI
FFIsTiled@LIBTIFF_4.0'
defined reference to PyString_InternFromString' /usr/lib/gcc/x86_64-linux-gnu/5/../../../x86_64-linux-gnu/libboost_python.so: un defined reference toPyInt_AsLong'
defined reference to PyUnicodeUCS4_AsWideChar' /usr/lib/x86_64-linux-gnu/libopencv_highgui.so.2.4.9: undefined reference toTI
FFWriteScanline@LIBTIFF_4.0'
/usr/lib/x86_64-linux-gnu/libopencv_highgui.so.2.4.9: undefined reference to TI FFGetField@LIBTIFF_4.0' /usr/lib/x86_64-linux-gnu/libopencv_highgui.so.2.4.9: undefined reference toTI
FFScanlineSize@LIBTIFF_4.0'
defined reference to PyString_AsString' /usr/lib/x86_64-linux-gnu/libopencv_highgui.so.2.4.9: undefined reference toTI
FFReadEncodedTile@LIBTIFF_4.0'
/usr/lib/x86_64-linux-gnu/libopencv_highgui.so.2.4.9: undefined reference to TI FFReadRGBATile@LIBTIFF_4.0' /usr/lib/gcc/x86_64-linux-gnu/5/../../../x86_64-linux-gnu/libboost_python.so: un defined reference toPyString_FromFormat'
/usr/lib/x86_64-linux-gnu/libopencv_highgui.so.2.4.9: undefined reference to TI FFClose@LIBTIFF_4.0' /usr/lib/x86_64-linux-gnu/libopencv_highgui.so.2.4.9: undefined reference toTI
FFRGBAImageOK@LIBTIFF_4.0'
defined reference to PyClass_Type' /usr/lib/gcc/x86_64-linux-gnu/5/../../../x86_64-linux-gnu/libboost_python.so: un defined reference toPyString_FromString'
defined reference to PyFile_AsFile' /usr/lib/gcc/x86_64-linux-gnu/5/../../../x86_64-linux-gnu/libboost_python.so: un defined reference toPy_InitModule4_64'
/usr/lib/x86_64-linux-gnu/libopencv_highgui.so.2.4.9: undefined reference to TI FFOpen@LIBTIFF_4.0' /usr/lib/gcc/x86_64-linux-gnu/5/../../../x86_64-linux-gnu/libboost_python.so: un defined reference toPyInt_Type'
defined reference to PyInt_FromLong' /usr/lib/gcc/x86_64-linux-gnu/5/../../../x86_64-linux-gnu/libboost_python.so: un defined reference toPyFile_FromString'
/usr/lib/x86_64-linux-gnu/libopencv_highgui.so.2.4.9: undefined reference to TI FFReadEncodedStrip@LIBTIFF_4.0' /usr/lib/x86_64-linux-gnu/libopencv_highgui.so.2.4.9: undefined reference toTI
FFSetField@LIBTIFF_4.0'
defined reference to PyNumber_Divide' /usr/lib/gcc/x86_64-linux-gnu/5/../../../x86_64-linux-gnu/libboost_python.so: un defined reference toPyString_Type'
/usr/lib/x86_64-linux-gnu/libopencv_highgui.so.2.4.9: undefined reference to TI FFSetWarningHandler@LIBTIFF_4.0' /usr/lib/x86_64-linux-gnu/libopencv_highgui.so.2.4.9: undefined reference toTI
FFSetErrorHandler@LIBTIFF_4.0'
collect2: error: ld returned 1 exit status
tools/CMakeFiles/compute_image_mean.dir/build.make:130: recipe for target 'tools
/compute_image_mean' failed
make[3]: *** [tools/compute_image_mean] Error 1
make[3]: Leaving directory '/opt/movidius/bvlc-caffe/build'
CMakeFiles/Makefile2:467: recipe for target 'tools/CMakeFiles/compute_image_mean
.dir/all' failed
make[2]: *** [tools/CMakeFiles/compute_image_mean.dir/all] Error 2
make[2]: Leaving directory '/opt/movidius/bvlc-caffe/build'
Makefile:127: recipe for target 'all' failed
make[1]: *** [all] Error 2
@ashutosh
same issue
I failed at this step
and when I run make examples, I got caffe import error…
The message
shows that Caffe is not compiling properly so it is normal that "Caffe Import" will not pass later.
Can you check please what's inside
/usr/lib/x86_64-linux-gnu directory
because this error origins from missing or dependency not meeting libboost_python.so
it's something wrong with caffe. try to build caffe by yourself. see the below links.
in my side, it's something wrong with opencv, I build and install opencv from source with -D BUILD_TIFF=ON
then it works fine
https://groups.google.com/forum/#!searchin/caffe-users/LIBTIFF_4.0|sort:date/caffe-users/wKYe45FKSqE/fWM6Yfo3LzkJ
http://blog.csdn.net/ccemmawatson/article/details/42004105
Thanks, I will build opencv from source and try again.
