Camera Resolution cause delay
Vina_Alvionita
I build a social distance monitoring project. i use person detection retail model to detect person and calculate the distance. the camera used has several options of resolution. when the camera resolution is set to 1280*960 (1.3M) or 1280*720(720P), the delay in the output video is less than 1 second. but when the camera resolution increased to 920*1080, the resulting delay is more than 5 seconds. why it was happen? is there a way to solved the delay problem while used high resolution camera?
CPU : Intel Core i5-10500
camera : 5MP
Victor_G_Intel
Hello Vina_Alvionita,
To better assist you please provide the following report and information to continue with your support.
Intel® System Support Utility (Intel® SSU)
Download link: https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
  • Open the application and click on "Scan" to see the system and device information
  • By default, Intel® SSU will take you to the "Summary View".
  • Click on the menu where it says "Summary" to change to "Detailed View".
  • To save your scan, click on "Next", then "Save".
- When you say that you use “person detection retail model” you mean the Open VINO™ Toolkit?
I look forward to hearing from you.
Victor G.
Intel Technical Support Technician
Vina_Alvionita
Yes,  i use person detection retail model from Open VINO™ Toolkit. and here i attached the summary report
Victor_G_Intel
Your query will be best answered by our Open VINO support team. We will help you to move this post to the designated team to further assist you.
Victor G
Peh_Intel
Hi Vina,
Greetings to you.
Higher resolution required higher processing power. The delay issue happened mainly because your CPU would have been a bottleneck when running the inference engine at 1080p.
Perhaps you can use person-detection-retail-0013 model (which the model is smaller in size) instead of person-detection-retail-0002 model and also try on different precision of the model (FP32, FP16-INT8).
Peh
Peh_Intel
Hi Vina,
This thread will no longer be monitored since we have provided a suggestion. If you need any additional information from Intel, please submit a new question.
Peh
