6597 Discussions
Can I access the Intel Compute Stick 2 process in an Ubuntu Docker running on a Windows 10 NuC?
akaddoura
I got a quick question. We have an intel NCS2 connected to a NuC running Windows 10 which is running an Ubuntu Docker image. Is it possible to access the Neural Stick 2 processor (VPU?) inside the Ubuntu docker image?
If it's possible, how can we do so?
Note: I had posted this question on the processor board by mistake before.
Peh_Intel
Hello akaddoura,
For your information, if your host system is Windows 10 and above with WSL2, you can run inference inside the Docker image on CPU and iGPU (host system is required to be Windows 10 21H2 or Windows 11) targets only.
However, if your host system is Ubuntu 20.04, then running inferencing inside the docker image is available for Intel® Neural Compute Stick 2.
For more details, you can refer to the following link:
https://hub.docker.com/r/openvino/ubuntu20_runtime
Peh
AndrewG_Intel
Hello @akaddoura
We understand that you have an inquiry about Intel® Neural Compute Stick 2. We have a forum for those specific products and questions so we are moving it to the Intel® DevCloud for Edge Forum so it can get answered more quickly.
Andrew G.
Peh_Intel
Hello akaddoura,
Peh
akaddoura
Hi Peh,
Thanks a lot for the answer! So we can't connect Windows to an Ubuntu Docker to run the NCS2. Hopefully that's something we can do in the future.
Peh_Intel
Hello akaddoura,
You're welcome.
This thread will no longer be monitored since your question has been answered. If you need any additional information from Intel, please submit a new question.
Peh
