I recently take over an project which use 2021.3(one of the older version) openvino as its inference engine, and now I have a dynamic shape onnx model that need to be converted into an ir model so it can be used in the project.
After I check the documatation, I found out that for latest version, you can simply set --input_shape with -1 for those unknow or uncertain dims, but before the 2021.3version, it seemed that you can not do it in this way, it will throw a "not fully defined" error for input shape. with its documentation says as such: https://docs.openvino.ai/2021.3/openvino_docs_MO_DG_prepare_model_convert_model_Converting_Model_General.html#:~:text=The%20shape%20should%20not%20contain%20undefined
My question is: does the 2021.3 version of openvino support dynamic shape model converting? it does, how to do it with "python mo.py", mean what extra params should I be setting?
thanks in advance for any suggestion or insights.
Hi cmkk,
Yes, you are right. Directly specifying input_shape -1 for the dynamic dimension is only available starting from Model Optimizer 2022.1.
The previous version of Model Optimizer does not have this additional feature.
Peh
Hi cmkk,
This thread will no longer be monitored since we have provided answers. If you need any additional information from Intel, please submit a new question.
Peh
