6573 Discussions
does old version(2021.3) of the openvino toolkit support dynamic shape model converting?
cmkk
I recently take over an project which use 2021.3(one of the older version) openvino as its inference engine, and now I have a dynamic shape onnx model that need to be converted into an ir model so it can be used in the project.
After I check the documatation, I found out that for latest version, you can simply set --input_shape with  -1 for those unknow or uncertain dims, but before the 2021.3version, it seemed that you can not do it in this way, it will throw a "not fully defined" error for input shape. with its documentation says as such:  https://docs.openvino.ai/2021.3/openvino_docs_MO_DG_prepare_model_convert_model_Converting_Model_General.html#:~:text=The%20shape%20should%20not%20contain%20undefined
My question is: does the 2021.3 version of openvino support dynamic shape model converting? it does, how to do it with "python mo.py", mean what extra params should I be setting?
thanks in advance for any suggestion or insights.
Peh_Intel
Hi cmkk,
Yes, you are right. Directly specifying input_shape -1 for the dynamic dimension is only available starting from Model Optimizer 2022.1.
The previous version of Model Optimizer does not have this additional feature.
Peh
Peh_Intel
Hi cmkk,
This thread will no longer be monitored since we have provided answers. If you need any additional information from Intel, please submit a new question.
Peh
