Can not create 2 MYRIAD inference engines with different model
Truong__Dien_Hoa
New Contributor II
Hi, I'm trying to run multiple models in one application using MYRIAD device. However, when I have already one engine, I can not create new one. I got RuntimeError: Can not init USB device: NC_ERROR
The error is at:  plugin.load(network=net, num_requests=self.number_req)
I then try with the GPU and don't see the error.
Anyone know where the problem come from and how to fix it ?
Thank you in advance,
[More info]
- I use Intel® Movidius™ VPU which is attached to an UP board.
- I'm coding in Python. I tried to run the sample security_barrier demo with MYRIAD (because it also load multiple models) and got no error. The code is written in C++ so I don't know if we have problem with the Python API ?
Truong__Dien_Hoa
New Contributor II
I think I find the error. It is because I use different object for MYRIAD plugin.
I works ok as below:
exec_net = plugin.load(network=net)
exec_net2 = plugin.load(network=net2)
If we try to create an exec_net with different plugin then we get the error:
exec_net = plugin2.load(network=net2)
I will try to check if it runs ok
Truong__Dien_Hoa
New Contributor II
Shubha_R_Intel
Dear Truong, Dien Hoa,
Glad you figured it out and thanks for posting your findings here.
Thanks for using OpenVino !
Shubha
Alberto_Torin
I was facing a similar issue and I was able to solve it thanks to Dien Hoa Truong's reply.
However, I'm using the 2020.2 release, and the IEPlugin class is now deprecated. Which is the correct way to handle multiple models on a single Myriad device with the latest release?
Campalo__Fardo
Is there any sample code using opencv (I mean, using cv2.dnn.readnet function) to load two networks on the same NCS2?
Moreover, I have the same question as "Torin, Alberto".
