Can't convert MobilenetV2 from TF to IR
Singal__Dhruv
I'm using the savedmodel method with a .pb, variables/ and assets/
The error I'm getting is the following:
[ ERROR ]  'ascii' codec can't decode byte 0xfc in position 1: ordinal not in range(128)
Unexpected exception happened during extracting attributes for node Adam/Logits/bias/v/Read/ReadVariableOp.
Original exception message: 'ascii' codec can't decode byte 0xfc in position 1: ordinal not in range(128)
Singal__Dhruv
Just realized that this is most likely due to the model optimizer not supporting TF 2.0. Retraining in 1.15 now. Any ETA on 2.0 support?
JAIVIN_J_Intel
Hi Dhruv,
You may refer to this comment from another thread regarding TF 2.0
Also, let us know if you have any additional questions.
Jaivin
