6616 Discussions
Can't readnetwork from Blob Ptr* on x86 smart camera. but readnetwork from xml Files is ok!!
yu__rui
Here is the example code:
int main()
Core core;
CNNNetwork network1;
ExecutableNetwork exec_work1;
std::string xmlFilePath = "xxxxx.xml";
std::string binFilePath = "xxxxx.bin";
FILE* fileXml = fopen(xmlFilePath.c_str(), "rb+");
FILE* fileBin = fopen(binFilePath.c_str(), "rb+");
fseek(fileBin, 0, SEEK_END);
long int sizeBin = ftell(fileBin);
fclose(fileBin);
unsigned char* inbin = (unsigned char*)malloc(sizeBin);
int bytesReadBin = fread(inbin, sizeof(unsigned char), sizeBin, fileBin);
fclose(fileBin);
std::vector<uint8_t> binChar;
for (int i = 0; i < sizeBin; i++)
binChar.push_back(inbin[i]);
fseek(fileXml, 0, SEEK_END);
long int sizeXml = ftell(fileXml);
fclose(fileXml);
unsigned char* inXml = (unsigned char*)malloc(sizeXml);
int bytesReadXml = fread(inXml, sizeof(unsigned char), sizeXml, fileXml);
fclose(fileXml);
std::vector<uint8_t> XmlChar;
for (int i = 0; i < sizeXml; i++)
XmlChar.push_back(inXml[i]);
std::string xmlStr(XmlChar.begin(), XmlChar.end());
auto weightsBin = make_shared_blob<uint8_t>({ Precision::U8,{binChar.size()},Layout::ANY }, binChar.data());
network1 = core.ReadNetwork(xmlStr, weightsBin);
//network1 = core.ReadNetwork(xmlFilePath );
my cpu is Atom 3940?
Could Any one has met this kind of problem,?
Wan_Intel
Hi Yu Rui,
For your information, the OpenVINO™ toolkit requires Intel Atom® processor with Intel® Streaming SIMD Extensions 4.2 (Intel® SSE4.2) for target system platforms. Intel Atom® x5-E3940 Processor) is not one of them, and hence, is not supported by the OpenVINO™ toolkit.
System requirements for using OpenVINO™ toolkit is available at the following page:
https://software.intel.com/content/www/us/en/develop/tools/openvino-toolkit/system-requirements.html
On another note, Crossroad Camera C++ Demo is a demo application for person detection which supports images/video and camera as inputs.
You may refer to its main.cpp to understand how to create input blob.
Wan
yu__rui
Dear Wan:
         Thanks for replying! But, I have more questions  for “Intel Atom® x5-E3940 Processor) is not one of them, and hence, is not supported by the OpenVINO™ toolkit.”:
         1. Why it works for me to read  local xml file path?
         2. Why  Atom® x5-E3940 Processor is included in openvino benchmark results?
Wan_Intel
Hi Yu Rui,
Thanks for your information.
My apologies, I could not find Intel® Streaming SIMD Extensions 4.2 from Intel Atom® x5-E3940 Processor’s Product Specifications. Hence, I assumed it was not supported by Intel® Distribution of OpenVINO™ toolkit.
I had read through the Intel® Distribution of OpenVINO™ toolkit Benchmark Results. Intel® Atom™ x5-3940 was supported by Intel® Distribution of OpenVINO™ toolkit.
On another note, have you solved the issue after you referred to Crossroad Camera C++ Demo’s main.cpp?
Wan
Wan_Intel
Hi Yu Rui,
This thread will no longer be monitored since we have provided a suggestion.
If you need any additional information from Intel, please submit a new question.
Wan
