6597 Discussions
How to use NCS with face_recognition library
LuthfanHadi
I had project face recognition with face_recognition library, but i need running that with NCS, what should i do?
Wan_Intel
Hi Luthfan Hadi,
For your information, we have transitioned from Intel® Movidius™ Neural Compute Stick (NCS) to the Intel® Neural Compute Stick 2 (Intel® NCS2). Please refer to here for more information.
As for using Intel® Neural Compute Stick 2 on Linux, masOS, and Raspbian OS, you must complete all required configuration steps to perform inference on Intel® Neural Compute Stick 2.
Configuration steps to perform inference on Intel® Neural Compute Stick 2 for Linux is available at the following page:
https://docs.openvinotoolkit.org/2021.4/openvino_docs_install_guides_installing_openvino_linux.html#additional-NCS-steps
Configuration steps to perform inference on Intel® Neural Compute Stick 2 for macOS is available at the following page:
https://docs.openvinotoolkit.org/2021.4/openvino_docs_install_guides_installing_openvino_macos.html#additional-NCS2-steps
Configuration steps to perform inference on Intel® Neural Compute Stick 2 for Raspbian OS is available at the following page:
https://docs.openvinotoolkit.org/2021.4/openvino_docs_install_guides_installing_openvino_raspbian.html#add-usb-rules
Next, proceed to the Get Started Guides to get started with running code samples and demo applications.
For example, if you are using Windows OS, you can run the Image Classification Demo Script with Intel® Neural Compute Stick 2 with the following command:
.\demo_squeezenet_download_convert_run.bat -d MYRIAD
Wan
Wan_Intel
Hi Luthfan Hadi,
This thread will no longer be monitored since we have provided a suggestion.
If you need any additional information from Intel, please submit a new question.
Wan
