6595 Discussions
Can't run Classification Python Demo with OpenVINO 2022.1
Mostafa-
Hello All,
I installed openvino-dev[caffe] successfully, and download squeesenet1.1 by;
omz_downloader --name sqeezenet1.1
 then convert it successfully by;
mo --input_model public/squeezenet1.1/squeezenet1.1.caffemodel --batch 1 --output_dir squeezenet_IR
then clone open_model_zoo to use the classification python demo;
python3 classification_demo.py -m /home/mostafa/intel/squeezenet_IR/squeezenet1.1.xml -i classification.gif --labels /home/mostafa/intel/open_model_zoo/data/dataset_classes/imagenet_2015.txt
and I got the below error;
Traceback (most recent call last):
  File "classification_demo.py", line 28, in <module>
    from openvino.model_zoo.model_api.models import Classification, OutputTransform
ModuleNotFoundError: No module named 'openvino.model_zoo.model_api'
Mostafa
IntelSupport
Community Manager
Hi Mostafa,
The error is because you wrongly specify the architecture_type of yolo-v4-tiny-tf model. The architecture_type of the model should be yolov4. You can refer to the Supported Models for the architecture_type of each model. I have verified the demo and the output is as below:
Command used :
object_detection_demo.py -i <path_to_video>\car-detection.mp4" -m "<path_to_model>\yolo-v4-tiny-tf.xml" -at yolo v4 -t 0.5 -o object_detection_output.avi
Aznie
Mostafa-
I installed also openvino-dev[tensorflow2] and tried also object detection demo - python - with tiny yolov4 and I got the same error;
  File "object_detection_demo.py", line 28, in <module>
    from openvino.model_zoo.model_api.models import DetectionModel, DetectionWithLandmarks, RESIZE_TYPES, OutputTransform
Vladimir_Dudnik
@Mostafa- starting from 2022.1 OMZ most of python demos require to install an additional module, for OMZ Model API, see documentation for more details
Installing Python* Model API package
Use the following command to install Model API from source:
pip install <omz_dir>/demos/common/python
Mostafa-
Thank You Vladimir.
I did it and there's another error;
(openvino-tensorflow_env) mostafa@mostafa-VirtualBox:~/intel/open_model_zoo/demos/object_detection_demo/python$ python3 object_detection_demo.py --model tiny-yolov4/FP32/yolo-v4-tiny-tf.xml -at yolo -i test.mp4 -t 0.5 -d CPU -o fp32_output.avi
[ INFO ] OpenVINO Runtime
[ INFO ] build: 2022.1.0-7019-cdb9bec7210-releases/2022/1
[ INFO ] Reading model tiny-yolov4/FP32/yolo-v4-tiny-tf.xml
[ WARNING ] The parameter "input_size" not found in YOLO wrapper, will be omitted
[ WARNING ] The parameter "num_classes" not found in YOLO wrapper, will be omitted
[ INFO ] Input layer: image_input, shape: [1, 416, 416, 3], precision: f32, layout: NHWC
[ INFO ] Output layer: conv2d_17/BiasAdd:0, shape: [1, 13, 13, 255], precision: f32, layout:
[ INFO ] Output layer: conv2d_20/BiasAdd:0, shape: [1, 26, 26, 255], precision: f32, layout:
[ INFO ] The model tiny-yolov4/FP32/yolo-v4-tiny-tf.xml is loaded to CPU
[ INFO ] Device: CPU
[ INFO ] Number of streams: 1
[ INFO ] Number of threads: AUTO
[ INFO ] Number of model infer requests: 2
  File "object_detection_demo.py", line 304, in <module>
    sys.exit(main() or 0)
  File "object_detection_demo.py", line 205, in main
    results = detector_pipeline.get_result(next_frame_id_to_show)
  File "/home/mostafa/intel/openvino-tensorflow_env/lib/python3.8/site-packages/openvino/model_zoo/model_api/pipelines/async_pipeline.py", line 124, in get_result
    result = self.model.postprocess(raw_result, preprocess_meta), {**meta, **preprocess_meta}
  File "/home/mostafa/intel/openvino-tensorflow_env/lib/python3.8/site-packages/openvino/model_zoo/model_api/models/yolo.py", line 122, in postprocess
    detections = self._parse_outputs(outputs, meta)
  File "/home/mostafa/intel/openvino-tensorflow_env/lib/python3.8/site-packages/openvino/model_zoo/model_api/models/yolo.py", line 224, in _parse_outputs
    detections += self._parse_yolo_region(out_blob, meta['resized_shape'], layer_params[1])
  File "/home/mostafa/intel/openvino-tensorflow_env/lib/python3.8/site-packages/openvino/model_zoo/model_api/models/yolo.py", line 130, in _parse_yolo_region
    predictions = permute_to_N_HWA_K(predictions, params.bbox_size, params.output_layout)
  File "/home/mostafa/intel/openvino-tensorflow_env/lib/python3.8/site-packages/openvino/model_zoo/model_api/models/yolo.py", line 44, in permute_to_N_HWA_K
    tensor = tensor.reshape(N, -1, K, H, W)
ValueError: cannot reshape array of size 43095 into shape (1,newaxis,85,13,255)
IntelSupport
Community Manager
Hi Mostafa,
Command used :
Aznie
Mostafa-
thank you, it works now
IntelSupport
Community Manager
Hi Mostafa,
This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Aznie
