6605 Discussions
Can we install the Compute Stick on an existing Pi/sd card?
Or is it best we get a fresh install with the latest Raspbian Stretch. The reason I'm asking is that as a student, we are limited with supplies and want to test the compute stick on an existing sd card/device.
If we decide to just install it on the sd card we have, will this somehow alter our existing configurations? We have no virtual environments installed. Any guidance would be extremely helpful.
yes you can, the NCSDK fully support arm architecture
@iba You can install on both a fresh RPi with Raspbian Stretch or an existing SD card with Raspian Stretch. I've found more success with a fresh install. You don't need to have any virtual environment software. More information on installation can be found at https://movidius.github.io/ncsdk/install.html.
Thank you!
