6595 Discussions
Cannot import cv2 when running a python sample
Aschuch
After downloading openvino and initializing the openvino environment using the setupvars.bat, I tried running the sample code for classification_sample.py and got the following error:
Traceback (most recent call last):
File "classification_sample.py", line 21, in <module>
import cv2
ImportError: DLL load failed: The specified module could not be found.
I'm not sure how to fix this error.
Thank you!
Aschuch
Hi!
I updated python from version 3.7.9 to 3.8.10 and the issue was fixed! Thank you for the help.
Ana
Wan_Intel
Hi Aschuch,
Could you please run the sample code in a Python Virtual Environment and see if the issue can be resolved? The steps to set up the Python Virtual Environment and install the OpenVINO™ Development Tools Package are available here.
Hope it helps.
Wan
Aschuch
Hi!
Ana
Wan_Intel
Hi Aschuch,
Thanks for sharing the answer.
This thread will no longer be monitored since this issue has been resolved.
If you need any additional information from Intel, please submit a new question.
Wan
