6598 Discussions
Cannot open Installation set up of OpenVino
Sowjanya
I have downloaded the OpenVino toolkit executable file from the OpenVino website. The product package extraction is successful and the Installation window is launched for a few seconds and closes automatically. I have tried multiple times but could not be successful. Please let me know how to install  OpenVino successfully.
FYI, I use Windows 10 (64 bit) OS and I could install OpenVino earlier on my system successfully. I have attached the log file that is created while running the executable file.
Sowjanya
Hairul_Intel
Hi Sowjanya,
I've replicated your issue, downloaded OpenVINO 2021.4.1 LTS and ran the installer.
The installation succeeded on my side.
As a workaround, can you try to run the install.exe file manually? (It's located in the extracted directory: C:\Users\chennama\Downloads\Intel\w_openvino_toolkit_p_2021.4.689_2022-02-28_15-07-38\install.exe)
Alternatively, we recommend you give a try to freshly download and install OpenVINO Toolkit again.
Hairul
Matthias1102
Hi Hairul,
I have also tried to replicate Sowjanya's issue, but on my Windows 10 notebook the installer works as expected.
Then I have compared Sowjanya's install_log.txt file with the log file that was created by my installer. They are almost equivalent, but I see a "return code of the child process" of 4, whereas Sowjanya got -1073741571. Does her value of -1073741571 provide any hint for the root cause?
28.02.2022 15:07:44 : 11576 : The following child window found: Intel(R) Distribution of OpenVINO™ toolkit 2021.4.1 for Windows*
28.02.2022 15:07:44 : 11576 : Child window was found
28.02.2022 15:07:44 : 11576 : Waiting end of child process...
28.02.2022 15:07:48 : 11576 : Return Code of child process: -1073741571
28.02.2022 15:07:48 : 11576 : Setup.exe was launched
28.02.2022 15:07:48 : 11576 : Finish
28.02.2022 15:07:48 : 11576 : WARNING : Return Code is overwrited by Setup.exe return code. [ret code] = 1000 + [setup.exe ret code]
28.02.2022 15:07:48 : 11576 : Return Code: -1073740571
Matthias
Hairul_Intel
Hi Matthias,
From our replication, we can confirm that this is not related to OpenVINO or its dependencies.
I share this Stack Overflow case which might indicate some probable causes for this issue.
Hairul
Hairul_Intel
Hi Sowjanya,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Hairul
