6571 Discussions
How to import pickle data with accuracy_check
lantianguhong
Excuse me, I met a problem with accuracy_check. If anyone can help me, please reply! Thank you very much.
My yaml content is the following:
models:
- name: saved_model_int8
launchers:
- framework: dlsdk
device: CPU
model: out/FP32/saved_model.xml
weights: out/FP32/saved_model.bin
##adapter: classification
datasets:
- name: data
annotation: data.pickle
reader: pickle_reader
my command is :
#accuracy_check -c MA00_model_int8.yaml
but there is a problem,  I don't know how to configure my yaml file.
Zulkifli_Intel
Hello Lantianguhong,
Annotation Converters demonstrate how pickle file is used. Did you have a chance to look at Deep Learning accuracy validation framework? This document shows an example of dataset definition. Also, Intel provides predefined configuration files that you can refer to configure .ymal file for your model.
Sincerely,
Zulkifli
Zulkifli_Intel
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Sincerely,
Zulkifli
