6574 Discussions
Cannot setup environment for course AI From the Data Center to the Edge
pr0
I'm having trouble setting up the environment.yml on Mac OS Catalina. I have Anaconda and everything installed. I read a similar post on the Intel forum and it was suggested that one should try creating a virtual environment using conda. I was able to do that but I'm not able to find and install the packages in the default channels required for this course (please see attached image). Please advise thank you.
David_C_Intel
Hi pr0,
Thank you for posting in our community.
Could you please tell us the following:
  • Which python version do you have?
  • Could you provide us with the commands you are using?
David C.
A Contingent Worker at Intel
pr0
Hi David,
I'm using Python 3.7.
I used the following commands in the terminal:
cd path_to_course_folder/Notebooks
conda update conda
conda env create -f environment.yml
After I try the last command in bold I got the errors in the screenshot I added in my previous post:
Collecting package metadata (repodata.json): done
Solving environment: failed
ResolvePackageNotFound:
 - libgfortran-ng==7.3.0
 - libgcc-ng==8.2.0
 - libstdcxx-ng==8.2.0
David_C_Intel
Hi pr0,
Thank you for your reply.
In order to get an accurate response, please go to the following forum and post your questions there.
David C.
