6577 Discussions
Cannot use YOLOV3 with CPU after optimizing
Carlyon__Shane
I swear that I have exactly followed the official instruction - https://docs.openvinotoolkit.org/latest/_docs_MO_DG_prepare_model_convert_model_tf_specific_Convert_YOLO_From_Tensorflow.html
Of course, I didn't add `--data_type=FP16` as I wanted to use this model on my CPU.
But unfortunately this replies with an error message:
exec_net = plugin.load(network=net, num_requests=2)
  File "ie_api.pyx", line 547, in openvino.inference_engine.ie_api.IEPlugin.load
  File "ie_api.pyx", line 557, in openvino.inference_engine.ie_api.IEPlugin.load
RuntimeError: Unsupported primitive of type: Resample name: detector/yolo-v3/ResizeNearestNeighbor
Any idea?
P.S.
- Ubuntu 18.04
- Python3.6
- Tensorflow 1.12.0
Sahira_Intel
Hi Shane,
If you're getting the unsupported primitive error, try adding -I <PATH_TO cpu_extension.dll> (or cpu_extension.so)
Please let me know if this is helpful.
Sahira
Carlyon__Shane
@Sahira
        device = "CPU"
        model_bin = os.path.splitext(model_xml)[0] + ".bin"
        self.plugin = IEPlugin(device=device)
        self.net = IENetwork(model=model_xml, weights=model_bin)
        ie = IECore()
        ie.add_extension(
            "/opt/intel/openvino/deployment_tools/inference_engine/lib/intel64/libcpu_extension_sse4.so", "CPU")
        supported_layers = ie.query_network(self.net, "CPU")
        not_supported_layers = [l for l in self.net.layers.keys() if l not in supported_layers]
        if len(not_supported_layers) != 0:
            logger.error(f"Following layers are not supported by the plugin for specified "
                         f"device {device}:\n {', '.join(not_supported_layers)}")
        assert len(self.net.inputs.keys()) == 1, "Sample supports only YOLO V3 based single input topologies"
        assert len(self.net.outputs) == 3, "Sample supports only YOLO V3 based triple output topologies"
I added ie.add_extension() function as your suggestion, but same result... :/
Sahira_Intel
Hi Shane,
Can you please provide your model so I can take a look at it? If you'd rather share your model over a PM please let me know.
Sahira
