Classid Labels
JVond
New to the compute stick.  I've been using the google coral and jetson nano.
I was running the alexnet and googlenet caffe model and got outputs with no labels.  Is there a list somewhere or a way to input labels?
googlenet
classid probability
616     0.4355762
50      0.1069827
836     0.0557207
36      0.0534245
429     0.0518655
494     0.0363212
452     0.0321387
544     0.0257031
600     0.0205605
772     0.0144706
alexnet
classid probability
88      0.9810570
12      0.0157526
7       0.0009286
90      0.0009172
14      0.0005626
136     0.0002139
92      0.0001659
129     0.0001552
91      0.0000463
17      0.0000393
HemanthKum_G_Intel
Hi James,
You should be able to search the internet for the associated labels and annotation files. But labels and annotation are not associated with the models, they are associated with the dataset which was used to train the models, for instance, Coco, ImageNet, etc...
Well, OpenVINO doesn't ship with labels file for all supported models, so, for example, you can pull the ILSVRC2012 sysnset_words.txt from http://dl.caffe.berkeleyvision.org/caffe_ilsvrc12.tar.gz and rename it as googlenet-v1.labels. Note that the ILSVRC2012 synset_words.txt won't work for GoogLeNet V2 since V2 was trained on ILSVRC2015, you'd have to fetch the 2015 labels file when running GoogLeNet V2.
You have to run the classification sample with --lables option followed by the lables file downloaded from respective sites.
