6605 Discussions
DeepLab v3 custom trained model convert error
Tinon__John
python3 mo.py --input_model ${MODEL} --output ArgMax --input 1:mul_1 --input_shape "(1,513,513,3)" --log_level=DEBUG
Works without any issues on the xception model OS=8/16 "xception65_coco_voc_trainaug"  from model_zoo.
https://github.com/tensorflow/models/blob/master/research/deeplab/g3doc/.
However when using the checkpoint to train new classes my newly exported "frozen_inference" is throwing the following error.
mo.utils.error.Error: Exception occurred during running replacer "REPLACEMENT_ID" (<class 'extensions.front.user_data_repack.UserDataRepack'>): No node with name mul_1.
I found some similar issues with custom trained mask-rcnn though I'm not quite sure how to fix it for deeplab.
https://software.intel.com/en-us/forums/computer-vision/topic/809407
Any help would be appreciated
I'm using  2019.1.144, thanks in advance
HemanthKum_G_Intel
Shubha R. (Intel) wrote:
Ryan for the TensorFlow DeepLab model please try the following command (it works for me):
python mo.py --scale 1 --model_name test_deeplabv3_mobilenet_v2_argmax_tfFP32CPU1Truesync --input_shape "(1,513,513,3)" --input 1:mul_1 --input_model  "c:\Users\sdramani\Downloads\deeplabv3_mnv2_pascal_train_aug\frozen_inference_graph.pb" --framework tf --output_dir c:\Users\sdramani\Downloads\out_dir --data_type FP32 --output ArgMax
In the output_dir you should see the following 3 files created:
test_deeplabv3_mobilenet_v2_argmax_tfFP32CPU1Truesync.xml
test_deeplabv3_mobilenet_v2_argmax_tfFP32CPU1Truesync.mapping
test_deeplabv3_mobilenet_v2_argmax_tfFP32CPU1Truesync.bin
As for Fast Style Transfer we are still investigating this. Stay tuned.
Thanks for using OpenVino !
Shubha
