[Q]openvino with multiple movidius sticks
nick_h_1
Hi there
For one just execute "xxx -d myriad" but anybody knows how to use multiple sticks in openvino??
thanks
Monique_J_Intel
Hi Nick,
Yes, it's possible but with the current samples in the package you will have to edit the source files to pass "KEY_VPU_FORCE_RESET" parameter the value "NO" in SetConfig which would look like this:
ExecutableNetwork executable_network = plugin.LoadNetwork (network,  {InferenceEngine::SetConfig(KEY_VPU_FORCE_RESET, "NO")
This doesn't allow you to specifically say exactly what device it the network will load but the way it works is the network will be executed on the device with the least workload.
Kind Regards,
Monique Jones
nick_h_1
Hi Monique Thanks your feedback,is that means no Python version available?Or Intel has plan for Python in the future?
nick_h_1
Hi Monique Forgot to ask if there any example or guide for using “KEY_VPU_FORCE_RESET” B.R. Nick Hsiao
nick_h_1
Hi Monique
I got errors trying modify object_detection_demo_ssd_async sample code
object_detection_demo_ssd_async/main.cpp:192:67: error: ‘SetConfig’ is not a member of ‘InferenceEngine’
object_detection_demo_ssd_async/main.cpp:192:94: error: ‘KEY_VPU_FORCE_RESET’ was not declared in this scope
B.R.
Nick Hsiao
Monique_J_Intel
Hi Nick,
If you are using the python inference engine api then it would be:
plugin = IEPlugin(device="CPU")
plugin.set_config({"VPU_FORCE_RESET": "NO"})
The guide for the Python Inference Engine API is here.
The in-package documentation has the C++ Inference Engine API in <INSTALL_DIR>/deployment_tools/documentation/docs/PluginMyriad.html where INSTALL_DIR is C:\intel\computer_vision_sdk*\ or /opt/intel/computer_vision_sdk/ depending on your OS.
Kind Regards,
Monique Jones
Xin_Z_Intel
Jones, Monique (Intel) wrote:
plugin = IEPlugin(device="MYRIAD")
plugin.set_config({"KEY_VPU_FORCE_RESET": "NO"})
Hi Monique,
Shouldn't the device be "MYRIAD"?
And adding the second line to code, the following error message is shown:
Exception ignored in: 'inference_engine.ie_api.IEPlugin.set_config'
/teamcity/work/scoring_engine_build/releases_openvino-2018-r3/ie_bridges/python/inference_engine/ie_api_impl.cpp:249
RuntimeError: [NOT_FOUND] KEY_VPU_FORCE_RESET key is not exist
And for the CPP code after adding this option the code cannot compile.
As shown in error log I'm using 2018-R3 package. How can I make it work? Thanks.
nick_h_1
Hi all
I found plugin.set_config({"VPU_FORCE_RESET""NO"}) works,need to remove "KEY"
Nick Hsiao
burlakin__vladimir
Hi Monique!
Please example or guide for using “KEY_VPU_FORCE_RESET” for c++
Vlad
ABoch5
Hi Nick,
Kind Regards,
Monique Jones
I changed this line: https://github.com/opencv/open_model_zoo/blob/e458c1f0407d0303e36be4828bb963a67d6d050a/demos/object_detection_demo_yolov3_async/main.cpp#L284-L287
ExecutableNetwork network = plugin.LoadNetwork(netReader.getNetwork(), {});
to this:
ExecutableNetwork network = plugin.LoadNetwork(netReader.getNetwork(), { InferenceEngine::SetConfig(KEY_VPU_FORCE_RESET, "NO") } );
And I get this error:
