6595 Discussions
Compile errors with OpenVINO 2019 on MacOS 10.14
Dang_Tran__Frederic
Hi:
I'm trying to install OpenVINO 2019 on a macOS 10.14.6 machine following the instructions provided on this page:
https://docs.openvinotoolkit.org/latest/_docs_install_guides_installing_openvino_macos.html
But when I execute the  image classification verification script (demo_squeezenet_download_convert_run.sh), I see a flurry of C++ compile errors (see attached file). There is definitely something wrong with my environment but I cannot figure out what.
cmake version: 3.0.2
xcode 11.3
Apple clang version 11.0.0
Any help would be appreciated....
JesusE_Intel
Hi Frederic,
Thanks for reaching out. The following error makes me believe there is an issue with your CMakeversion, could you install CMake 3.4 or higher? See the software requirements on the Getting Started Guide for OpenVINO Toolkit for Mac OS.
CMake Warning (dev): Policy CMP0042 is not set: MACOSX_RPATH is enabled by default. Run "cmake --help-policy CMP0042" for policy details. Use the cmake_policy command to set the policy and suppress this warning.
MACOSX_RPATH is not specified for the following targets:
format_reader
ie_cpu_extension
Please let me know if this works for you.
Jesus
JesusE_Intel
Hi Frederic,
format_reader
ie_cpu_extension
Jesus
Dang_Tran__Frederic
I upgraded cmake to version 3.16 and the problem is settled.
Thanks !
JesusE_Intel
I'm glad that worked for you, thanks for reporting back!
Jesus
Ibecheozor__Ugochukw
Hi:
I'm also trying to install OpenVINO 2019 on a macOS Catalina 10.15.2  machine following the instructions provided on this page:
When I execute the  image classification verification script (demo_squeezenet_download_convert_run.sh), I see a flurry of C++ compile errors (see attached file). There is definitely something wrong with my environment but I cannot figure out what.
cmake version 3.16.2
Wang__Yuan
Hi
You can try to update the code on
/opt/intel/openvino_2019.1.133/deployment_tools/inference_engine/ samples/common/samples/common.hpp:64:
change these two lines
s.erase(s.begin(), std::find_if(s.begin(), s.end(), std::not1(std::ptr_fun<int, int>(std::isspace))));
s.erase(std::find_if(s.rbegin(), s.rend(), std::not1(std::ptr_fun<int, int>(std::isspace))).base(), s.end());
to:
s.erase(s.begin(), std::find_if(s.begin(), s.end(), [](int c) { return !std::isspace(c); }));
s.erase(std::find_if(s.rbegin(), s.rend(), [](int c) { return !std::isspace(c); }).base(), s.end());
