6574 Discussions
Conversion from Tensorflow model to Intel Movidius Graph error
Hello! I've got problem with conversion of tensorflow model to movidius graph. Initially model was designed in keras then I convert it to tensorflow and finally to movidius graph. I' ve got following error:
[Error 5] Toolkit Error: Stage Details Not Supported: IsVariableInitialized
Here is the code for conversion:
import nn import os square_width = 16 square_height = 16 classes_num = 9 model = nn.alexnet_model((square_width, square_height, 3)) model.load_weights('weights.h5') with open("model.json", "w") as file: file.write(model.to_json()) from keras.models import model_from_json from keras import backend as K import tensorflow as tf model_file = "model.json" weights_file = "weights.h5" with open(model_file, "r") as file: config = file.read() K.set_learning_phase(0) model = model_from_json(config) model.load_weights(weights_file) saver = tf.train.Saver() sess = K.get_session() saver.save(sess, "./TF_Model/tf_model") fw = tf.summary.FileWriter('logs', sess.graph) fw.close() os.system('mvNCCompile ./TF_Model/tf_model.meta -in=conv2d_1_input -on=activation_7/Softmax') # get Movidius graph
That's how I define the model:
def alexnet_model(img_shape=(256, 256, 3), n_classes=9, l2_reg=0.,weights=None): ### taken from https://github.com/eweill/keras-deepcv/blob/master/models/classification/alexnet.py ### # Initialize model alexnet = Sequential() # Layer 1 alexnet.add(Conv2D(96, (11, 11), input_shape=img_shape, padding='same', kernel_regularizer=l2(l2_reg))) alexnet.add(BatchNormalization()) alexnet.add(Activation('relu')) alexnet.add(MaxPooling2D(pool_size=(2, 2))) # Layer 2 alexnet.add(Conv2D(256, (5, 5), padding='same')) alexnet.add(BatchNormalization()) alexnet.add(Activation('relu')) alexnet.add(MaxPooling2D(pool_size=(2, 2))) # Layer 3 alexnet.add(ZeroPadding2D((1, 1))) alexnet.add(Conv2D(512, (3, 3), padding='same')) alexnet.add(BatchNormalization()) alexnet.add(Activation('relu')) alexnet.add(MaxPooling2D(pool_size=(2, 2))) # Layer 4 alexnet.add(ZeroPadding2D((1, 1))) alexnet.add(Conv2D(1024, (3, 3), padding='same')) alexnet.add(BatchNormalization()) alexnet.add(Activation('relu')) # Layer 5 #alexnet.add(ZeroPadding2D((1, 1))) #alexnet.add(Conv2D(1024, (3, 3), padding='same')) #alexnet.add(BatchNormalization()) #alexnet.add(Activation('relu')) #alexnet.add(MaxPooling2D(pool_size=(2, 2))) # Layer 6 alexnet.add(Flatten()) alexnet.add(Dense(3072)) alexnet.add(BatchNormalization()) alexnet.add(Activation('relu')) alexnet.add(Dropout(0.5)) # Layer 7 alexnet.add(Dense(4096)) alexnet.add(BatchNormalization()) alexnet.add(Activation('relu')) alexnet.add(Dropout(0.5)) # Layer 8 alexnet.add(Dense(n_classes)) alexnet.add(BatchNormalization()) alexnet.add(Activation('softmax')) if weights is not None: alexnet.load_weights(weights) return alexnet
OS: Ubuntu 16.04
Pyhon version: 3.5.2
Tensorflow version 1.12.0
Keras version: 2.2.0
NCSDK version: 1.12.01.01
