Convert BERT TF model.pb to IR
Tye__Stephen
Can you convert a tensorflow BERT model.pb to IR?
Munesh_Intel
Hi Stephen,
OpenVINO supports the following Bidirectional Encoder Representations from Transformers (BERT) models:
·       BERT-Base, Cased
·       BERT-Base, Uncased
·       BERT-Base, Multilingual Cased
·       BERT-Base, Multilingual Uncased
·       BERT-Base, Chinese
·       BERT-Large, Cased
·       BERT-Large, Uncased
Steps for converting BERT models to IR are available here:
Convert TensorFlow BERT Model to the Intermediate Representation
Munesh
Tye__Stephen
Thanks I have reviewed this page but I do not have a bert_model.ckpt.meta file, I have a bert_model.pb file.
Also on a separate note is the distilBERT model supported?
Stephen
Munesh_Intel
Hi Stephen,
We do have the following Intel pre-trained models ;
And also the following public pre-trained model:
IR files are provided for Intel pre-trained models. Meanwhile, the sole public pre-trained model, bert-base-ner, is a PyTorch model, which needs to be converted to ONNX, and subsequently to IR. You can use Model Converter to convert bert-base-ner model into IR format using Model Optimizer.
For your information, the Model Optimizer conversion arguments are given here:
https://github.com/openvinotoolkit/open_model_zoo/blob/master/models/public/bert-base-ner/model.yml#L86
I would suggest you try using similar arguments to convert your .pb file to IR.
For your second question, DistilBert is not yet supported, but we are working on including it in our future releases.
On another note, the ‘small’ Intel pre-trained models are distilled versions as well. For example, ‘bert-small-uncased-whole-word-masking-squad-0001’ is a small BERT-large like model distilled on SQuAD v1.1 training set from the original ‘bert-large-uncased-whole-word-masking-finetuned-squad’ provided by the Transformers library.
Perhaps you can give a try with these pre-trained models to see if they meet your requirements.
Munesh
Munesh_Intel
Hi Stephen,
This thread will no longer be monitored since we have provided suggestion and explanation. If you need any additional information from Intel, please submit a new question.
Munesh
