6577 Discussions
Convert Pipeline to run from CPU to VPU
wcheemasynsor
Hi we have a Openvino Python API based pipeline (Model Optimizer/converter and then Inference Engine) that currently runs on the CPU but we want to test it on Myriad VPUs. How would one make this switch ?
Labels (2)
Syamimi_Intel
Hi Waqar Cheema,
Thank you for reaching out. You can just add -d MYRIAD to the command line.
Refer to Build the Code Samples and Demo Applications to get ideas on how to run the demo using CPU, GPU, and MYRIAD.
Syamimi
Syamimi_Intel
Hi Waqar Cheema,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Syamimi
