6584 Discussions
Convert Pytorch to ONNX then to Openvino IR
kenfack
I have trained a mask rcnn model using transfers learning in PyTorch on the custom dataset.
num_classes = 4
model = models.detection.maskrcnn_resnet50_fpn(pretrained=True)
in_features = model.roi_heads.box_predictor.cls_score.in_features
model.roi_heads.box_predictor = FastRCNNPredictor(in_features, num_classes)
in_features_mask = model.roi_heads.mask_predictor.conv5_mask.in_channels
hidden_layer = 256
model.roi_heads.mask_predictor = MaskRCNNPredictor(in_features_mask,hidden_layer,num_classes)
Now I need to covert the resulted model into ONNX then from ONNX convert to Openvino IR. So I converted the model from torch to ONNX
# Export the model to ONNX model
batch_size = 1
x = torch.randn(1,3,1080,1080)
model.eval()
torch_out = model(x)
torch.onnx.export(
    model,
    x,
    "cocoa_diseasis_model.onnx",
    export_params=True,
    opset_version=11,
    verbose=False,
    do_constant_folding=True,
    input_names = ['input'],
    output_names = ['output'],
    dynamic_axes={'input' : {0 : 'batch_size'}, 'output' : {0 : 'batch_size'}}
but trying to get the IR of that model generates the following error.
py ./mo_onnx.py --input_model input_model\model.onnx --transformations_config ./extensions/front/onnx/mask_rcnn.json
[ ERROR ] -------------------------------------------------
[ ERROR ] ----------------- INTERNAL ERROR ----------------
[ ERROR ] Unexpected exception happened.
[ ERROR ] Please contact Model Optimizer developers and forward the following information:
[ ERROR ] Exception occurred during running replacer "ONNXMaskRCNNReplacement (<class 'extensions.front.onnx.mask_rcnn_conversion.ONNXMaskRCNNTransformation'>)": Attempt to access node 2751 that not in graph
[ ERROR ] Traceback (most recent call last):
File "C:\Program Files (x86)\Intel\openvino_2021\deployment_tools\model_optimizer\mo\utils\class_registration.py", line 278, in apply_transform
for_graph_and_each_sub_graph_recursively(graph, replacer.find_and_replace_pattern)
File "C:\Program Files (x86)\Intel\openvino_2021\deployment_tools\model_optimizer\mo\middle\pattern_match.py", line 46, in for_graph_and_each_sub_graph_recursively
func(graph)
File "C:\Program Files (x86)\Intel\openvino_2021\deployment_tools\model_optimizer\mo\front\tf\replacement.py", line 36, in find_and_replace_pattern
self.transform_graph(graph, desc._replacement_desc['custom_attributes'])
File "C:\Program Files (x86)\Intel\openvino_2021\deployment_tools\model_optimizer\extensions\front\onnx\mask_rcnn_conversion.py", line 38, in transform_graph
insert_ExperimentalDetectronROIFeatureExtractor2(graph, replacement_descriptions)
File "C:\Program Files (x86)\Intel\openvino_2021\deployment_tools\model_optimizer\extensions\front\onnx\mask_rcnn_conversion.py", line 103, in insert_ExperimentalDetectronROIFeatureExtractor2
old_output_node = Node(graph, replacement_descriptions['ROIFeatureExtractor2_output'])
File "C:\Program Files (x86)\Intel\openvino_2021\deployment_tools\model_optimizer\mo\graph\graph.py", line 25, in __init__
assert node in graph, "Attempt to access node {} that not in graph".format(node)
AssertionError: Attempt to access node 2751 that not in graph
The above exception was the direct cause of the following exception:
File "C:\Program Files (x86)\Intel\openvino_2021\deployment_tools\model_optimizer\mo\main.py", line 394, in main
ret_code = driver(argv)
File "C:\Program Files (x86)\Intel\openvino_2021\deployment_tools\model_optimizer\mo\main.py", line 356, in driver
ret_res = emit_ir(prepare_ir(argv), argv)
File "C:\Program Files (x86)\Intel\openvino_2021\deployment_tools\model_optimizer\mo\main.py", line 252, in prepare_ir
graph = unified_pipeline(argv)
File "C:\Program Files (x86)\Intel\openvino_2021\deployment_tools\model_optimizer\mo\pipeline\unified.py", line 13, in unified_pipeline
class_registration.apply_replacements(graph, [
File "C:\Program Files (x86)\Intel\openvino_2021\deployment_tools\model_optimizer\mo\utils\class_registration.py", line 328, in apply_replacements
apply_replacements_list(graph, replacers_order)
File "C:\Program Files (x86)\Intel\openvino_2021\deployment_tools\model_optimizer\mo\utils\class_registration.py", line 314, in apply_replacements_list
apply_transform(
File "C:\Program Files (x86)\Intel\openvino_2021\deployment_tools\model_optimizer\mo\utils\logger.py", line 111, in wrapper
function(*args, **kwargs)
File "C:\Program Files (x86)\Intel\openvino_2021\deployment_tools\model_optimizer\mo\utils\class_registration.py", line 302, in apply_transform
raise Exception('Exception occurred during running replacer "{} ({})": {}'.format(
Exception: Exception occurred during running replacer "ONNXMaskRCNNReplacement (<class 'extensions.front.onnx.mask_rcnn_conversion.ONNXMaskRCNNTransformation'>)": Attempt to access node 2751 that not in graph
[ ERROR ] ---------------- END OF BUG REPORT --------------
can someone help me to do that?
IntelSupport
Community Manager
Hi Kenfack,
Thanks for reaching out.
Which specific OpenVINO version you are using? Can you share your weight file or model for us to test at our end?
Meanwhile, you can try to use the Model Optimizer parameter from the documentation below to convert your model into Intermediate Representation (IR).
https://docs.openvinotoolkit.org/2021.4/openvino_docs_MO_DG_prepare_model_convert_model_onnx_specific_Convert_Mask_RCNN.html
Aznie
kenfack
Hi @Aznie_Intel ,
Thank you for your reply. I'm using the last version of the Openvino toolkit (v 2021.4.582).
The Pytorch fine-tuned model
The Converted model to ONNX using opset 11
The Converted model to ONNX using opset 13
Bruno
IntelSupport
Community Manager
Hi Bruno,
Can you share the source where you got the model?
Aznie
kenfack
Hi @IntelSupport ,
This is how I loaded the model, I'm following this tutorial
num_classes = 4
hidden_layer = 256
Find the notebook here
IntelSupport
Community Manager
Hi Bruno,
Thank you for your patience.
After a detailed checking on your model, we found that the issue is from the IF operation that is not yet supported. Meanwhile, for the latest OpenVINO, you can directly use .onnx to run OpenVINO inference, which means you do not require to convert to IR. You can directly use the benchmark app to check your model that already converted from Pytorch to ONNX by using the following command:
Python benchmark_app.py - cocoa_diseases_model.onnx
I have tested your model with the benchmark app and the error messages clearly state that the IF Operation is not supported. Hence, I would advise you either removed the IF operation or change the IF operation to another operation that is supported based on ONNX* Supported Operators.
Regard
Aznie
kenfack
Hi @Aznie_Intel ,
happy to hear from you. Thank you for your response.
  1. How to change or remove the IF operation? Please for a tutorial.
  2. I still need to convert my model into IR because I have a final conversion to do. From IR to Blob. So that the final model can be used in the DeepthAI device (OAK-D)
Bruno
IntelSupport
Community Manager
Hi Bruno,
Unfortunately, we don’t have the official tutorial from the OpenVINO perspective. I would advise you to go through or create a pull request on how to edit the ONNX model on the official Github ONNXruntime.
Aznie
IntelSupport
Community Manager
Hi Bruno,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Aznie
