6598 Discussions
Pretrained Model UNet-CamVid-Onnx-0001 does not predict correctly
franva
Hi there,
I downloaded the Intel pre-trained Unet model  from the OpenVINO Model Zoo Github repo without any modifications.
But it does not seem working, please have a look the below prediction on the right side.
I am expecting to see correct segmentation with different color marks, but it just shows darker image.
Here is my code, please let me know if you found anything wrong in it, otherwise, the model should be updated:
from logging import exception
import cv2
import numpy as np
from openvino.inference_engine import IECore
class ColorMap:
    SKY=[28,51,71]
    BUILDING=[28,28,28]
    POLE=[60,60,60]
    ROAD=[50,25,50]
    PAVEMENT=[95,14,91]
    FENCE=[74,60,60]
    VEHICLE=[0,0,56]
    PEDESTRIAN=[86,8,23]
    BIKE=[47,5,13]
    UNLABELED = [17,18,21]
    TREE=[40,40,61]
    SIGNSYMBOL=[86,86,0]
    COLORS = []
    COLORS_BGR = []
    COLOR_MAP = {}
    # the sequence of colors in this arrar matters!!! as it maps to the prediction classes
    COLORS.append(SKY)
    COLORS.append(BUILDING)
    COLORS.append(POLE)
    COLORS.append(ROAD)
    COLORS.append(PAVEMENT)
    COLORS.append(TREE)
    COLORS.append(SIGNSYMBOL)
    COLORS.append(FENCE)
    COLORS.append(VEHICLE)
    COLORS.append(PEDESTRIAN)
    COLORS.append(BIKE)
    COLORS.append(UNLABELED)
    for color in COLORS:
        np_color = np.array(color)
        COLORS_BGR.append(np_color[[2,1,0]])
def crop_to_square(frame):
    height = frame.shape[0]
    width  = frame.shape[1]
    delta = int((width-height) / 2)
    return frame[0:height, delta:width-delta]
model_xml = 'unet-camvid-onnx-0001.xml'
model_bin = "unet-camvid-onnx-0001.bin"
shape = (480, 368)
ie = IECore()
print("Available devices:", ie.available_devices)
net = ie.read_network(model=model_xml, weights=model_bin)
input_blob = next(iter(net.input_info))
# You can select device_name="CPU" to run on CPU
# exec_net = ie.load_network(network=net, device_name='MYRIAD')
exec_net = ie.load_network(network=net, device_name='CPU')
# Get video from the computers webcam
cap = cv2.VideoCapture('/media/winstonfan/Workspace/Learning/Github/depthai/videos/CamVid.mp4')
while cap.isOpened():
    ret, raw_image = cap.read()
    if not ret:
        continue
    image = crop_to_square(raw_image)
    image = cv2.resize(image, shape)
    cv2.imshow('Video ', image)
    image = image.astype(np.float32)
    image = np.expand_dims(image, axis=0)
    image = image.transpose((0, 3, 1, 2))
    image = image / 127.5 - 1.0
    # Do the inference on the MYRIAD device
    output = exec_net.infer(inputs={input_blob: image})
    output = np.squeeze(output['206'])
    data = np.argmax(output, axis=0)
    if data.shape != (368, 480):
        raise exception('unexpected shape of data from decode() method in handler.py');
    class_colors = ColorMap.COLORS
    class_colors = np.asarray(class_colors, dtype=np.uint8)
    output_colors = np.take(class_colors, data, axis=0)
    max_value = output_colors.max()
    output_colors = (output_colors /(max_value/2.0) - 1.0).astype(np.float32)
    sqz_img = np.moveaxis(np.squeeze(image), 0, 2)
    overlayed = cv2.addWeighted(sqz_img, 1, output_colors, 0.2, 0)
    cv2.imshow('Output', overlayed)
    if cv2.waitKey(1) == ord('q'):
        break
Winston
IntelSupport
Community Manager
Hi Winston,
Thanks for reaching out.
We experienced the same output as you. I will investigate this issue with our developer and will update you with the information soon.
Meanwhile, the model output of unet-camvid-onnx-0001 is the per-pixel probabilities of each input pixel of the 12 classes of the CamVid dataset. You can find the RGB value of the classes in this directory:
INSTALL_DIR\deployment_tools\open_model_zoo\data\palettes
Aznie
franva
Hi @IntelSupport
Thank you for your update.
I am looking forward to your update soon.
I am actually looking for a fast segmentation model on Raspberry Pi 4 (4GB).
After digging a while, I found that the DeepLabV3Plus-MobileNetV2 or DeepLabV3Plus-MobileNetV3(timm-mobilenetv3_small_075) can be a better fit.
Is it possible for Intel to provide this model?
As it's for the portable devices, it would have a huge popularity.
Winston
IntelSupport
Community Manager
Hi Winston,
OpenVINO does have deeplabv3 supported but not the Plus version of the model. Currently, we cannot provide any model that is not yet validated in the OpenVINO toolkit.
Aznie
franva
Hi @IntelSupport
Thanks for the update.
Do you have the model which is constructed with DeepLabV3(not plus) as the head part + MobileNetV3_Small_x75( as backbone) ?
Or
SFNet + MobileNetV3_Small_x75 model?
I need one of these 2 models to run on my edge device for just the road segmentation.
Could you please share the link to these 2 models if they exist?
Many thanks,
Winston
IntelSupport
Community Manager
Hi Winston,
Thank you for your patience. I have validated unet-camvid-onnx-0001 model using our Open Model Zoo segmentation demo and the result is not as it should be. I will escalate this to our development team for further clarification and it might take some time. I will provide you with the latest updates once available from their end.
Also, I did try running the segmentation demo using other supported models (icnet-camvid-ava-0001, icnet-camvid-ava-sparse-30-0001,icnet-camvid-ava-sparse-60-0001) and the result is slightly better compared to unet model. I would suggest you try these models for your custom code and see if the result can meet your requirement. You might need to change your custom code.
Meanwhile, we do not have such models available regarding the DeepLabV3 model + MobileNetV3_Small_x75 (as backbone) or SFNet _ MobileNetV3_Small_x75 model. I suggest you use our Open Model Zoo models( road-segmentation-adas-0001 and semantic-segmentation-adas-0001) that validate and test for road segmentation purposes.
Aznie
franva
Thanks @IntelSupport for the update and confitmation.
In my requirements, I only need 1 class for the segmentation which is road and the input size should be small e.g. 224x224.
I would like to train it myself, since I don't think I'd be able to find any model like this.
Could you please provide a tutorial for how to train a model for segmentation with PyTorch?
Aleksei
Hello, @franva.
If you are interested in road segmentation, I suggest you use the following models:
  1. road-segmentation-adas-0001 (classify each pixel into four classes: BG, road, curb, mark.)
  2. semantic-segmentation-adas-0001
  3. deeplabv3
These models are the lightest and fastest.
Also I would  recommend you use segmentation_demo from Open Model Zoo, because it contains the correct pre- and postprocessing:
  1. Preprocessing  - is only resize image to the input shape of model. Crop don't needed. Normalization is done automatically while inference of model.
  2. Postprocessing - to get color map from output and mixed it with original (input) image. Your postprocessing is normal, but alpha and beta in cv2.addWeighted are strange. (alp + beta = 1)
So, your code will look like this:
import cv2
import numpy as np
class ColorMap:
    SKY=(0,   0,   0)
    BUILDING=(128, 0,   0)
    POLE=(0,   128, 0)
    ROAD=(128, 128, 0)
    PAVEMENT=(0,   0,   128)
    FENCE=(128, 0,   128)
    VEHICLE=(0,   128, 128)
    PEDESTRIAN=(128, 128, 128)
    BIKE=(64,  0,   0)
    UNLABELED = (192, 0,   0)
    TREE=(64,  128, 0)
    SIGNSYMBOL=(192, 128, 0)
    COLORS = []
    COLORS_BGR = []
    COLOR_MAP = {}
    COLORS.append(SKY)
    COLORS.append(POLE)
    COLORS.append(ROAD)
    COLORS.append(TREE)
    COLORS.append(BIKE)
model_xml = '<seg_model>.xml'
model_bin = '<seg_model>.bin'
shape = (input_w, input_h)
ie = IECore()
output_blob = next(iter(net.outputs))
cap = cv2.VideoCapture('video.mp4')
    if not ret:
        continue
    image = cv2.resize(raw_image, shape)
    output = np.squeeze(output[output_blob])
    if len(output.shape) > 2:
        output = np.argmax(output, axis=0)
    output_colors = np.take(class_colors, output, axis=0)
    overlayed = cv2.addWeighted(sqz_img, 0.5, output_colors, 0.5, 0)
        break
franva
Hi @Aleksei , Thanks for your sharing.
Yep, I have tried it, it works
But I'm on a limited edge device, OAK-D so I'd prefer to be able to re-train the model myself which requires smaller input size e.g. 224x224 and only has 2 classes: the road and everything else.
Is it possible?
IntelSupport
Community Manager
Hi Winston,
There are trainable models in OpenVINO Training Extension that show how to train a model for segmentation. You might use the instance segmentation models.
Aznie
IntelSupport
Community Manager
Hi Winston,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Aznie
