Convert YOLOv3 Model to IR
verma__Ashish
I have followed this link to train yolov3 using Pascal VOC data
https://github.com/AlexeyAB/darknet#how-to-train-to-detect-your-custom-objects
finetuning using darknet53.conv.74 available weights.
after training I got yolov3.weights. I am trying to convert those weights to tensorflow using this link
https://github.com/mystic123/tensorflow-yolo-v3
and this command
python3 convert_weights_pb.py --class_names coco.names --data_format NHWC --weights_file yolov3.weights
But I am getting this error
Traceback (most recent call last):
  File "convert_weights_pb.py", line 53, in <module>
    tf.app.run()
  File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/platform/app.py", line 125, in run
    _sys.exit(main(argv))
  File "convert_weights_pb.py", line 43, in main
    load_ops = load_weights(tf.global_variables(scope='detector'), FLAGS.weights_file)
  File "/home/sr/yolo/tensorflow-yolo-v3/utils.py", line 114, in load_weights
    (shape[3], shape[2], shape[0], shape[1]))
ValueError: cannot reshape array of size 14583 into shape (78,256,1,1)
Do I have to specify yolo cfg file somewhere in flags or I am missing something else
Any help will be appreciated
Ashish
Hyodo__Katsuya
Innovator
Ummm...Sorry... At the moment it is difficult to identify the cause with my ability...
verma__Ashish
Thanks for your cooperation and instant replies
Ashish
Hyodo__Katsuya
Innovator
Oh, No...
Screenshot 2019-02-27 23:14:33.png
verma__Ashish
Oh, any progress??
Hyodo__Katsuya
Innovator
Yesterday, "Nan" was outputted in large quantity, so I went to bed with disappointment. But today, I got information in my Github repository. I will work on other projects today, so I will try to verify it later. https://github.com/PINTO0309/OpenVINO-YoloV3/issues/13#issuecomment-468203337
Hyodo__Katsuya
Innovator
verma__Ashish
For the time being I have to run it in cpu or gpu but since yolov3 needs libcpuextension.so as to be loaded , I am not able to run it in gpu also. Is there a way I can run standard yolov3 in gpu? NCS is not an option right now for me
Hyodo__Katsuya
Innovator
See 4.【Optional execution】 Additional installation steps for processor graphics (GPU).
https://github.com/PINTO0309/OpenVINO-YoloV3#1-work-with-laptoppc-ubuntu-1604
GPU is compatible with Intel Graphics HDxxx series only.
verma__Ashish
I thought yolov3 needs libcpuextension.so to be link while initializing, so after following
and loading this library, can we run it in gpu because that I library is for Target cpu only, correct me if I am wrong
Ashish
Hyodo__Katsuya
Innovator
"libcpuextension.so" generation command. $ cd /opt/intel/computer_vision_sdk/inference_engine/samples/ $ sudo ./build_samples.sh Path where "libcpuextension.so" is generated. ~/inference_engine_samples_build/intel64/Release/lib/libcpu_extension.so CPU Mode $ cd ~/inference_engine_samples_build/intel64/Release $ sudo ./object_detection_demo_yolov3_async -i cam -d CPU -m xxx GPU Mode $ sudo ./object_detection_demo_yolov3_async -i cam -d GPU -m xxx
verma__Ashish
That implies we can run yolov3 openvino version in GPU, Correct ?
If that so, then I will try to do that in parallel
Ashish
Hyodo__Katsuya
Innovator
It works unless the layer of "Not Supported" is included. I am using LattePanda Alpha (Intel Graphics HD 645) when testing GPUs. However, it takes time to remove the device from the warehouse, so I have not tried it now. Please be aware that it will not work with NVIDIA GPU. https://github.com/PINTO0309/OpenVINO-YoloV3#openvino-supported-layers-as-of-dec-25-2018
Hyodo__Katsuya
Innovator
Apart from whether the result is correct or not, the value is now output.
b920405@ubuntu:~/git/DW2TF$ python3 openvino_tiny-yolov3_test.py
{'yolov3-tiny/convolutional13/Conv2D': array([[[[-3.4440000e+03, -4.1920000e+03, -4.2800000e+03, ...,
          -5.8920000e+03, -5.6880000e+03, -2.4320000e+03],
         [-6.5480000e+03, -6.8280000e+03, -6.2720000e+03, ...,
          -8.4880000e+03, -7.4000000e+03, -1.6550000e+03],
         [-7.5680000e+03, -8.1880000e+03, -7.0560000e+03, ...,
          -6.4480000e+03, -6.0560000e+03, -1.7450000e+03],
         [-6.6240000e+03, -5.6600000e+03, -4.9600000e+03, ...,
          -5.2480000e+03, -4.4080000e+03, -1.3320000e+03],
         [-6.3520000e+03, -5.5080000e+03, -6.2560000e+03, ...,
          -4.8200000e+03, -4.4480000e+03, -3.0280000e+03],
         [-4.1000000e+03, -5.4800000e+03, -6.8280000e+03, ...,
          -4.6520000e+03, -4.7240000e+03, -2.1600000e+03]],
        [[-4.4200000e+03, -3.5360000e+03, -2.8040000e+03, ...,
          -3.5780000e+03, -2.5220000e+03, -3.3950000e+02],
         [-3.6440000e+03, -3.7980000e+03, -3.0300000e+03, ...,
          -9.2700000e+02, -6.2600000e+02, -1.1190000e+03],
         [-3.8820000e+03, -3.9780000e+03, -3.2780000e+03, ...,
          -1.8560000e+03, -9.9500000e+02, -6.0100000e+02],
         [-8.1950000e+02, -5.5440000e+03, -5.2000000e+03, ...,
          -2.6500000e+03, -2.3640000e+03,  7.3250000e+02],
         [-5.4050000e+02, -6.0960000e+03, -6.3840000e+03, ...,
          -2.1860000e+03, -4.0680000e+03,  1.1481250e+02],
         [-2.3800000e+03, -4.2120000e+03, -4.2080000e+03, ...,
           1.4000000e+03, -3.1550000e+02,  3.8375000e+01]],
        [[ 1.3890000e+03,  3.9840000e+03,  4.0600000e+03, ...,
           5.7680000e+03,  5.6680000e+03,  2.7060000e+03],
         [ 1.6370000e+03,  4.5240000e+03,  3.6580000e+03, ...,
           4.8560000e+03,  4.3920000e+03,  1.5030000e+03],
         [ 2.1340000e+03,  4.6480000e+03,  2.7660000e+03, ...,
           4.8840000e+03,  4.4760000e+03,  1.1830000e+03],
         [ 2.6740000e+03,  4.9560000e+03,  3.3560000e+03, ...,
           3.1920000e+03,  3.4980000e+03,  4.3375000e+02],
         [ 1.8990000e+03,  3.0440000e+03,  2.0350000e+03, ...,
           2.3440000e+03,  3.7800000e+03,  1.1190000e+03],
         [-1.6540000e+03, -1.0025000e+03, -3.0825000e+02, ...,
           1.4662500e+02,  1.1440000e+03,  4.3575000e+02]],
        [[ 2.3462500e+02, -1.5560000e+03, -1.5610000e+03, ...,
          -2.3860000e+03, -2.4000000e+03, -4.7280000e+03],
         [-1.2320000e+03, -3.5140000e+03, -2.9780000e+03, ...,
          -2.3840000e+03, -3.1380000e+03, -5.9480000e+03],
         [-1.5120000e+03, -2.9620000e+03, -2.5280000e+03, ...,
          -1.9790000e+03, -3.3500000e+03, -4.7400000e+03],
         [-1.2510000e+03, -3.0540000e+03, -3.1260000e+03, ...,
          -3.6920000e+03, -4.3680000e+03, -3.2760000e+03],
         [-1.9170000e+03, -3.4920000e+03, -2.7640000e+03, ...,
          -2.5380000e+03, -2.5380000e+03, -1.3880000e+03],
         [-1.8200000e+03, -2.0440000e+03, -1.4660000e+03, ...,
          -1.4720000e+03, -5.6000000e+02, -1.2410000e+03]],
        [[-2.8340000e+03, -4.6840000e+03, -5.2480000e+03, ...,
          -2.6560000e+03, -2.9860000e+03, -4.2000000e+03],
         [-7.2880000e+03, -9.0720000e+03, -9.5200000e+03, ...,
          -8.8400000e+03, -8.8720000e+03, -7.5520000e+03],
         [-6.7840000e+03, -9.2800000e+03, -9.8960000e+03, ...,
          -8.4800000e+03, -8.8160000e+03, -6.4800000e+03],
         [-7.7680000e+03, -8.7600000e+03, -8.4640000e+03, ...,
          -8.0840000e+03, -7.5560000e+03, -5.7200000e+03],
         [-7.6000000e+03, -9.6880000e+03, -8.3760000e+03, ...,
          -8.5360000e+03, -7.0320000e+03, -2.8780000e+03],
         [-7.2360000e+03, -1.0672000e+04, -9.4480000e+03, ...,
          -7.4280000e+03, -5.1120000e+03, -1.3212500e+02]],
        [[ 9.6800000e+02,  1.7340000e+03,  1.5060000e+03, ...,
           1.0060000e+03,  2.5550000e+02, -4.3600000e+02],
         [ 1.5350000e+03,  2.1340000e+03,  1.9410000e+03, ...,
           6.1650000e+02, -1.6525000e+02, -1.3820000e+03],
         [ 1.2550000e+03,  2.5840000e+03,  1.8450000e+03, ...,
           1.4087500e+02,  1.1308594e+00, -1.0900000e+03],
         [ 1.8040000e+03,  3.0340000e+03,  1.5590000e+03, ...,
          -2.5960000e+03, -1.6860000e+03, -2.1120000e+03],
         [ 3.5060000e+03,  3.3960000e+03,  7.5650000e+02, ...,
          -1.3170000e+03, -7.6500000e+02, -1.7440000e+03],
         [ 2.3840000e+03,  2.9920000e+03,  3.8600000e+02, ...,
          -4.6000000e+02, -1.1450000e+02, -8.7300000e+02]]]],
      dtype=float32), 'yolov3-tiny/convolutional10/Conv2D': array([[[[ 2.001600e+04,  1.956800e+04,  1.972800e+04, ...,
           1.985600e+04,  1.936000e+04,  2.046400e+04],
         [ 1.956800e+04,  2.161600e+04,  2.259200e+04, ...,
           2.137600e+04,  2.344000e+04,  2.099200e+04],
         [ 2.044800e+04,  2.275200e+04,  2.241600e+04, ...,
           2.366400e+04,  2.089600e+04,  2.100800e+04],
         [ 1.913600e+04,  2.153600e+04,  2.262400e+04, ...,
           2.536000e+04,  2.337600e+04,  2.017600e+04],
         [ 1.985600e+04,  2.024000e+04,  2.305600e+04, ...,
           2.449600e+04,  2.449600e+04,  2.428800e+04],
         [ 1.825600e+04,  2.179200e+04,  2.400000e+04, ...,
           2.625600e+04,  2.596800e+04,  2.771200e+04]],
        [[ 5.828000e+03,  4.068000e+03,  3.832000e+03, ...,
           4.024000e+03,  7.475000e+02, -5.925000e+02],
         [ 5.248000e+03, -3.508000e+03, -5.200000e+03, ...,
          -4.360000e+03, -3.940000e+02, -7.240000e+02],
         [ 5.760000e+03, -1.452000e+03, -2.112000e+03, ...,
          -2.606000e+03, -8.670000e+02, -3.310000e+03],
         [ 6.176000e+03,  3.195000e+02, -4.965625e+01, ...,
          -5.460000e+03, -1.678000e+03, -4.596000e+03],
         [ 5.108000e+03, -6.305000e+02, -1.342000e+03, ...,
          -6.005000e+02, -2.190000e+03, -4.520000e+03],
         [ 4.980000e+03, -1.668750e+02,  4.870000e+02, ...,
          -1.472000e+03, -5.056000e+03, -8.624000e+03]],
        [[ 5.400000e+03,  8.992000e+03,  7.708000e+03, ...,
           8.336000e+03,  8.760000e+03,  6.648000e+03],
         [ 9.080000e+03,  1.444000e+04,  1.332000e+04, ...,
           1.140000e+04,  1.077600e+04,  9.976000e+03],
         [ 7.432000e+03,  1.050400e+04,  1.070400e+04, ...,
           1.114400e+04,  1.234400e+04,  1.127200e+04],
         [ 8.600000e+03,  1.412800e+04,  1.365600e+04, ...,
           1.200800e+04,  1.211200e+04,  1.210400e+04],
         [ 7.552000e+03,  1.082400e+04,  1.087200e+04, ...,
           7.900000e+03,  1.100000e+04,  7.892000e+03],
         [ 5.108000e+03,  8.084000e+03,  8.664000e+03, ...,
           7.032000e+03,  8.208000e+03,  4.812000e+03]],
        [[ 2.265600e+04,  2.817600e+04,  2.507200e+04, ...,
           1.705600e+04,  2.280000e+03, -5.414400e+04],
         [ 3.134400e+04,  3.344000e+04,  2.300800e+04, ...,
           2.806400e+04,  9.792000e+03, -5.747200e+04],
         [ 1.872000e+04,  1.575200e+04, -8.110000e+02, ...,
           1.071200e+04, -1.637000e+03, -5.408000e+04],
         [ 1.995200e+04,  1.948800e+04,  1.809600e+04, ...,
           1.894400e+04,  1.533600e+04, -3.753600e+04],
         [ 2.201600e+04,  1.360800e+04,  1.889600e+04, ...,
           2.196800e+04, -1.566400e+04, -2.739200e+04],
         [-3.030000e+03,  5.876000e+03,  7.700000e+03, ...,
          -5.124000e+03, -2.694400e+04, -4.772000e+03]],
        [[ 8.320000e+03,  1.628800e+04,  1.777600e+04, ...,
           1.076800e+04, -7.492000e+03, -5.305600e+04],
         [ 3.217600e+04,  5.276800e+04,  4.796800e+04, ...,
           3.404800e+04,  2.358400e+04, -3.875200e+04],
         [ 1.784000e+04,  3.275200e+04,  2.931200e+04, ...,
           4.016000e+04,  2.123200e+04, -4.432000e+04],
         [ 2.470400e+04,  4.473600e+04,  4.688000e+04, ...,
           4.886400e+04,  3.036800e+04, -3.468800e+04],
         [ 2.620800e+04,  4.460800e+04,  5.462400e+04, ...,
           4.748800e+04,  8.856000e+03, -3.881600e+04],
         [ 1.984000e+04,  3.449600e+04,  3.795200e+04, ...,
           3.033600e+04, -1.886400e+04, -3.240000e+04]],
        [[-2.160000e+03,  4.512000e+03,  5.612000e+03, ...,
          -3.686000e+03, -1.883200e+04, -5.164800e+04],
         [ 1.363200e+04,  3.179200e+04,  2.388800e+04, ...,
           8.520000e+03,  4.168000e+03, -3.721600e+04],
         [ 7.715000e+02,  6.044000e+03,  7.520000e+03, ...,
           1.365600e+04,  3.748000e+03, -3.824000e+04],
         [ 5.676000e+03,  1.705600e+04,  1.776000e+04, ...,
           2.241600e+04,  6.552000e+03, -3.051200e+04],
         [ 9.408000e+03,  2.260800e+04,  3.664000e+04, ...,
           2.979200e+04,  3.600000e+02, -3.472000e+04],
         [ 9.504000e+03,  2.672000e+04,  2.547200e+04, ...,
           1.897600e+04, -1.737600e+04, -3.014400e+04]]]], dtype=float32)}
verma__Ashish
Hi, there is no unsupported layer in the model but I am not able to run with GPU.
And what have you changed to get some values other than Nan?
Ashish
Hyodo__Katsuya
Innovator
Please see "Edit" frozen_yolov3-tiny.xml "manually" in the following URL. https://github.com/PINTO0309/OpenVINO-YoloV3/wiki/Reference-repository#conversion-success-2 I referred to the posts below. https://software.intel.com/en-us/forums/computer-vision/topic/805425 I still need fine adjustments to "negative_slope".
verma__Ashish
I am still worried about running the converted model with openvino as my first aim is to reduce the detection time of yolov3, if you are able to run openvino converted version of yolov3 for custom model with correct outputs, kindly update.
Ashish
Batra__Dhruv
Hyodo, Katsuya wrote:
It may be that the operation overflows while converting the model.
If the following command is executed, will an overflow warning be displayed?
$ sudo python3 /opt/intel/computer_vision_sdk/deployment_tools/model_optimizer/mo_tf.py \
--input_model data/frozen_yolov3.pb \
--output_dir . \
--data_type FP32 \
--batch 1 \
--input yolov3/net1 \
--output yolov3/convolutional59/BiasAdd,yolov3/convolutional67/BiasAdd,yolov3/convolutional75/BiasAdd \
--log_level WARNING
or
--output_dir . \
--data_type FP32 \
--batch 1 \
--log_level DEBUG
Does the same procedure works on yolov3-tiny?
Please share the Json file of yolov3-tiny
Hyodo__Katsuya
Innovator
@Batra, Dhruv
I did all the work with tiny-YoloV3.
JSON file is unnecessary.
However, I still need to adjust "negative_slope".
If you follow Intel's standard tutorial, please refer to the following URL.
https://github.com/PINTO0309/OpenVINO-YoloV3/blob/master/script.txt
verma__Ashish
I tried to adjust negative_slope on full yolo but no success. I think Json file is necessary for Full Yolo because without it, I am not able to convert it in xml and bin format.
Did you got any success running converted yolov3 model with correct outputs?
verma__Ashish
@Hyodo, katsuya
Any updates ??
Hyodo__Katsuya
Innovator
@verma, Ashish
sorry. I was absorbed in the Google Edge TPU Accelerator and I completely forgot it.
I will tackle it when I calm down.
