Convert h5 to IR format Errors
倪__嘉旻
l have trained a YoloV3 model with keras and get the H5 format. Then l use the "keras_to_tf.py" file(shown as follows) to convert the H5 format to Pb format without any error.
import os
import sys
import argparse
from pathlib import Path
import tensorflow as tf
from tensorflow.python.framework import graph_util
from tensorflow.python.framework import graph_io
from keras import backend as K
from keras.models import load_model
from yolo3.model import yolo_head, box_iou
def setKerasOptions():
    K._LEARNING_PHASE = tf.constant(0)
    K.set_learning_phase(False)
    K.set_learning_phase(0)
    K.set_image_data_format('channels_last')
def getInputParameters():
    parser = argparse.ArgumentParser()
    parser.add_argument('--input_model', '-m', required=True, type=str, help='Path to Keras model.')
    parser.add_argument('--num_outputs', '-no', required=False, type=int, help='Number of outputs. 1 by default.', default=1)
    return parser
def export_keras_to_tf(input_model, output_model, num_output):
    print('Loading Keras model: ', input_model)
    keras_model = load_model(input_model,{"yolo_head":yolo_head, "tf":tf, "box_iou":box_iou,'<lambda>': lambda y_true, y_pred: y_pred})
    print(keras_model.summary())
    predictions = [None] * num_output
    predrediction_node_names = [None] * num_output
    for i in range(num_output):
        predrediction_node_names = 'output_node' + str(i)
        predictions = tf.identity(keras_model.outputs, name=predrediction_node_names)
    sess = K.get_session()
    constant_graph = graph_util.convert_variables_to_constants(sess, sess.graph.as_graph_def(), predrediction_node_names)
    infer_graph = graph_util.remove_training_nodes(constant_graph)
    graph_io.write_graph(infer_graph, '.', output_model, as_text=False)
def main():
    argv = getInputParameters().parse_args()
    input_model = argv.input_model
    num_output = argv.num_outputs
    output_model = str(Path(input_model).name) + '.pb'
    predrediction_node_names = export_keras_to_tf(input_model, output_model, num_output)
    print('Ouput nodes are:', predrediction_node_names)
    print('Saved as TF frozen model to: ', output_model)
if __name__ == '__main__':
  main()
But when l convert Pb format to IR format, some errors occurs.
I use the following code:
C:/Users/倪妹/Desktop/NJM_test/keras-yolo3-master/deployment_tools/model_optimizer>
python mo_tf.py --input_model C:/Users/倪妹/Desktop/NJM_test/keras-yolo3-master/trained_weights_final.h5.pb --input input_1,input_2,input_3,input_4  --input_shape [1,416,416,3],[1,13,13,3],[1,26,26,3],[1,52,52,3] --data_type=FP16 --log_level=DEBUG
The errors are as follows:
[ ERROR ]  Shape [ 1 52 52 -1] is not fully defined for output 0 of "yolo_loss/mul_30". Use --input_shape with positive integers to override model input shapes.
[ ERROR ]  Cannot infer shapes or values for node "yolo_loss/mul_30".
[ ERROR ]  Not all output shapes were inferred or fully defined for node "yolo_loss/mul_30".
Attached is the Pb format file and the screenshot of the error.
Look forward to your reply!
Kathryn
SIRIGIRI_V_Intel
You can try to specify the entry points in the yolov3.json located in the <path_to_model_optimizer>/extensions/front/tf and modify the parameters as per the requirements. You can refer the Documentation on the conversion of yolo model to IR.
There is a similar thread you can refer to.
Ram prasad
