Convert keras SSD model to IR
Morishige__Akihito
I tried SSD by original data in keras. And I would like to change
trained model (.hdf5) to tensorflow model at first step to work this model
in open VINO.
But I can't convert keras model due to the follow problem.
ValueError: Invalid layer: Normalize
■keras_to_tensorflow
https://github.com/amir-abdi/keras_to_tensorflow
・Windows
・keras2.0.0
ssd.py in ssd_keras includes normalize layer. I think it is cause of
the problem. But I don't know how to change or revise this.
Could you tell me the good way to avoid this error ?
or could you tell me the way to change directly to IR model if there are any ?
-------------ssd.py------------------------------------------------
    # Last Pool
    net['pool6'] = GlobalAveragePooling2D(name='pool6')(net['conv8_2'])
    # Prediction from conv4_3
    net['conv4_3_norm'] = Normalize(20, name='conv4_3_norm')(net['conv4_3'])
    num_priors = 3
    x = Conv2D(num_priors * 4, (3, 3), padding='same',
                      name='conv4_3_norm_mbox_loc')(net['conv4_3_norm'])
    net['conv4_3_norm_mbox_loc'] = x
    flatten = Flatten(name='conv4_3_norm_mbox_loc_flat')
    net['conv4_3_norm_mbox_loc_flat'] = flatten(net['conv4_3_norm_mbox_loc'])
    name = 'conv4_3_norm_mbox_conf'
    if num_classes != 21:
        name += '_{}'.format(num_classes)
    x = Conv2D(num_priors * num_classes, (3, 3), padding='same',
                      name=name)(net['conv4_3_norm'])
    net['conv4_3_norm_mbox_conf'] = x
    flatten = Flatten(name='conv4_3_norm_mbox_conf_flat')
    net['conv4_3_norm_mbox_conf_flat'] = flatten(net['conv4_3_norm_mbox_conf'])
    priorbox = PriorBox(img_size, 30.0, aspect_ratios=[2],
                        variances=[0.1, 0.1, 0.2, 0.2],
                        name='conv4_3_norm_mbox_priorbox')
    net['conv4_3_norm_mbox_priorbox'] = priorbox(net['conv4_3_norm'])
Hyodo__Katsuya
Innovator
@Morishige, Akihito Is it possible to share the model file (.hdf5) you generated with us?
Morishige__Akihito
I uploaded the file, this is for share. So train data is very small, but the model architecture is the same.
Hyodo__Katsuya
Innovator
@Morishige, Akihito Thank you. Did you try the following? https://github.com/rykov8/ssd_keras/issues/83
Morishige__Akihito
Thanks. I tried follows.
Error is not occured at Normalize layer, but it has still a problem at PriorBox layer.
TypeError: __init__() missing 2 required positional arguments: 'img_size' and 'min_size'
Hyodo__Katsuya
Innovator
Is not it just that the number of parameters does not match?
Morishige__Akihito
Yes, that is.
At ssd.py I think the parameters are set, so the model includes these information.
I don't know where I should set. (My understanding for SSD isn't enough.)
Hyodo__Katsuya
Innovator
@Morishige, Akihito I understood. I will try it when I have time. Please tell me the URL of the repository you used when generating the model.
Morishige__Akihito
I appericiate your support. I uploaded the code.
Trained data is in the checkpoints folder, it is the file can't convert to IR.
 You use train.py when you use. This code is worked under keras2.
I'm sorry I can't share the original data, so its data is the test data. But code is the same.
Olivero__Alberto
Hyodo, Katsuya wrote:
@Morishige, Akihito
Thank you.
Hi, I'm also interested to keep working the conversion from keras to TF. I used the following line of code as for your comment but still do not work. May you elaborate your answer more ?
model = keras.models.load_model(input_model_path, custom_objects={'Normalize': Normalize, 'PriorBox': PriorBox})
