Convert mobilenetv2-SSD model to IR
longhao1995
tensorflow:1.15   openvino:2019.3
command:python mo_tf.py --input_model ssd/frozen_inference_graph.pb --data_type FP16 --tensorflow_use_custom_operations_config extensions/front/tf/ssd_v2_support.json --reverse_input_channels --tensorflow_object_detection_api_pipeline_config ssd/pipeline.config
The problem:[ ERROR ] Failed to match nodes from custom replacement description with id 'ObjectDetectionAPISSDPostprocessorReplacement':
It means model and custom replacement description are incompatible.
Try to correct custom replacement description according to documentation with respect to model node names
[ ERROR ] Cannot infer shapes or values for node "Postprocessor/Cast_1".
[ ERROR ] 0
[ ERROR ]
[ ERROR ] It can happen due to bug in custom shape infer function <function Cast.infer at 0x00000233344EBF28>.
[ ERROR ] Or because the node inputs have incorrect values/shapes.
[ ERROR ] Or because input shapes are incorrect (embedded to the model or passed via --input_shape).
[ ERROR ] Run Model Optimizer with --log_level=DEBUG for more information.
[ ERROR ] 0
Stopped shape/value propagation at "Postprocessor/Cast_1" node.
For more information please refer to Model Optimizer FAQ (https://docs.openvinotoolkit.org/latest/_docs_MO_DG_prepare_model_Model_Optimizer_FAQ.html), question #38.
Exception occurred during running replacer "REPLACEMENT_ID" (<class 'extensions.middle.PartialInfer.PartialInfer'>): 0
Wan_Intel
Hi Longhao1995,
Are you using ssd_mobilenet_v2_coco provided from Open Model Zoo?
I have validated the conversion of ssd_mobilenet_v2_coco with OpenVINO™ toolkit 2019.3.
Please install networkx version 2.3 before you convert the model:
pip install networkx==2.3
Please add these arguments when you execute mo_tf.py script:
python mo_tf.py --reverse_input_channels --input_shape=[1,300,300,3] --input=image_tensor --tensorflow_use_custom_operations_config=<INSTALL_DIR>/deployment_tools/model_optimizer/extensions/front/tf/ssd_v2_support.json --tensorflow_object_detection_api_pipeline_config=<path_to_ssd_mobilenet_v2_coco_dir>/ssd_mobilenet_v2_coco_2018_03_29/pipeline.config --output=detection_classes,detection_scores,detection_boxes,num_detections --input_model=<path_to_ssd_mobilenet_v2_coco_dir>/ssd_mobilenet_v2_coco_2018_03_29/frozen_inference_graph.pb
These arguments are also available here:
https://github.com/openvinotoolkit/open_model_zoo/blob/2019_R3.1/models/public/ssd_mobilenet_v2_coco/model.yml#L39
On the other hand, I would recommend you upgrade to the latest version of Intel® Distribution of OpenVINO™ toolkit 2021.3 for new capabilities and performance improvements.
Wan
Wan_Intel
Hi Longhao1995,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Wan
