Convert torch vision maskrcnn to IR format
Abdulsathar
Is it possible to convert a trained torch vision maskrcnn model to OpenVINO model. I am encountering different errors. if not, which maskrcnn is supported by OpenVINO currently?
IntelSupport
Community Manager
Hi Abdul Sathar,
Thanks for reaching out.
Pytorch framework is supported in OpenVINO by exporting the model into ONNX format. Refer Converting a PyTorch* Model for more details on the conversion.
Apart from that, you can find the list of Mask R-CNN models from OpenVINO™ Toolkit Public Pre-Trained Models.
Below is the example of converting Mask R-CNN Inception ResNet V2 1024x1024 from TensorFlow 2 Detection Model Zoo. Here is the command that I used:
mo --saved_model_dir <PATH_TO_SAVED_MODEL>\saved_model --transformations_config <INSTALL_DIR>\openvino\tools\mo\front\tf\mask_rcnn_support_api_v2.0.json --tensorflow_object_detection_api_pipeline_config <PATH_TO_PIPELINE_CONFIG>\pipeline.config --reverse_input_channels
Aznie
IntelSupport
Community Manager
Hi Abdul Sathar,
This thread will no longer be monitored since we have provided the information. If you need any additional information from Intel, please submit a new question.
Aznie
