Converted yolo models crash on NCS
I have made my own tinyer yolo and trained it and it works with darknet without issues.
But when I compile it and run it on the stick I get a hug error I dont understand.
Can anyone guide me ?
I have attached the model and the weights here.
https://drive.google.com/open?id=1XnNkMyhZp0DBJvDqh_hzI1Fv_roY__r5
Here is the error I get
Found stale device, resetting Device 0 Address: 13.1 - VID/PID 03e7:2150 Starting wait for connect with 2000ms timeout Found Address: 13.1 - VID/PID 03e7:2150 Found EP 0x81 : max packet size is 512 bytes Found EP 0x01 : max packet size is 512 bytes Found and opened device Performing bulk write of 865212 bytes... Successfully sent 865212 bytes of data in 74.994229 ms (11.002586 MB/s) Boot successful, device address 13.1 Device 0 Address: 4.1 - VID/PID 03e7:f63b Found Address: 4.1 - VID/PID 03e7:f63b done Booted 4.1 -> VSC /usr/local/lib/python3.5/dist-packages/skimage/transform/_warps.py:84: UserWarning: The default mode, 'constant', will be changed to 'reflect' in skimage 0.15. warn("The default mode, 'constant', will be changed to 'reflect' in " *** Error in `python3': malloc(): memory corruption: 0x00000000027527d0 *** ======= Backtrace: ========= /lib/x86_64-linux-gnu/libc.so.6(+0x777e5)[0x7fc1c8cf07e5] /lib/x86_64-linux-gnu/libc.so.6(+0x8213e)[0x7fc1c8cfb13e] /lib/x86_64-linux-gnu/libc.so.6(__libc_malloc+0x54)[0x7fc1c8cfd184] /lib/x86_64-linux-gnu/libc.so.6(qsort_r+0x79)[0x7fc1c8cb2349] /media/anilas1/data/Ncs/YoloV2NCS/detectionExample/libpydetector.so(_ZN6Region13GetDetectionsEPfiiiiiiffiRSt6vectorI14DetectedObjectSaIS2_EE+0x56d)[0x7fc1b482225d] /media/anilas1/data/Ncs/YoloV2NCS/detectionExample/libpydetector.so(_ZN12YoloDetector6DetectEN5boost6python3api6objectEiiiiiiffi+0xe0)[0x7fc1b4825160] /media/anilas1/data/Ncs/YoloV2NCS/detectionExample/libpydetector.so(_ZN5boost6python6detail12caller_arityILj11EE4implIM12YoloDetectorFNS0_4listENS0_3api6objectEiiiiiiffiENS0_21default_call_policiesENS_3mpl8vector12IS6_RS5_S8_iiiiiiffiEEEclEP7_objectSI_+0x617)[0x7fc1b4825f17] /usr/lib/x86_64-linux-gnu/libboost_python-py35.so.1.58.0(_ZNK5boost6python7objects8function4callEP7_objectS4_+0x26d)[0x7fc1b3f6e00d] /usr/lib/x86_64-linux-gnu/libboost_python-py35.so.1.58.0(+0x29208)[0x7fc1b3f6e208] /usr/lib/x86_64-linux-gnu/libboost_python-py35.so.1.58.0(_ZN5boost6python21handle_exception_implENS_9function0IvEE+0x73)[0x7fc1b3f76053] /usr/lib/x86_64-linux-gnu/libboost_python-py35.so.1.58.0(+0x26409)[0x7fc1b3f6b409] python3(PyObject_Call+0x47)[0x5c1797] python3(PyEval_EvalFrameEx+0x4ec6)[0x53bba6] python3(PyEval_EvalFrameEx+0x4b04)[0x53b7e4] python3[0x540199] python3(PyEval_EvalCode+0x1f)[0x540e4f] python3[0x60c272] python3(PyRun_FileExFlags+0x9a)[0x60e71a] python3(PyRun_SimpleFileExFlags+0x1bc)[0x60ef0c] python3(Py_Main+0x456)[0x63fb26] python3(main+0xe1)[0x4cfeb1] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0)[0x7fc1c8c99830] python3(_start+0x29)[0x5d6049] ======= Memory map: ======== 00400000-007a9000 r-xp 00000000 fd:00 10485774 /usr/bin/python3.5 009a9000-009ab000 r--p 003a9000 fd:00 10485774 /usr/bin/python3.5 009ab000-00a42000 rw-p 003ab000 fd:00 10485774 /usr/bin/python3.5
@ashwinnair14, looks like the issue is @ the app level. I was able to successfully run your model through mvNCProfiler, which means that your graph file is 'syntactically correct'. I do not have your python app, so I tried loading your graph file into https://github.com/movidius/ncappzoo/blob/master/caffe/TinyYolo/run.py, but since the number of outputs in your network is different from the one that's on NCAppZoo I had to hack your 8.prototxt:
Last layer of your 8.prototxt
layer { name: "conv8" type: "Convolution" bottom: "scale7" top: "conv8" convolution_param { num_output: 45 kernel_size: 1 stride: 1 pad: 0 } }
I added an fc9 to your 8.prototxt
layer { name: "conv8" type: "Convolution" bottom: "scale7" top: "conv8" convolution_param { num_output: 45 kernel_size: 1 stride: 1 pad: 0 } } layer { name: "fc9" type: "InnerProduct" bottom: "conv8" top: "fc9" inner_product_param { num_output: 1470 } }
The app runs fine, but the network doesn't detect any objects (output is a matrix of zeros). As a sanity check, I would recommend retraining your model with an fc layer that has 1470 outputs, and use https://github.com/movidius/ncappzoo/blob/master/caffe/TinyYolo/run.py for inferencing.
Hello @AshwinVijayakumar ,
Thats some great insight Reading your answer I fell I had not given all details of the problem.
I had used the original darknet (https://github.com/pjreddie/darknet) to train my model with 4 classes which is why the last conv layer has 45 outputs.
I have used the scripts in github https://github.com/duangenquan/YoloV2NCS to convert the darknet to caffe model which is y they dont have last FC layer and use their YoloV2NCS/detectionExample/Main.py to run where I get the same error.
Is there an other way to convert the darknet models to NCS so that this is done automatically? Or do I need to train the network with some other framework?
I checked their code and found out that I get an error where the outputs are used to get bounding boxes and perform NMS.
I can probably try to find the error if not.
