Converting yolo v3 weights
goh__richard
Hi
When I try to convert I got the following errors
Advise much appreciated
>python2 convert_weights_pb.py --class_names voc.names --data_format NHWC --weights_file latest.weights
Traceback (most recent call last):
  File "convert_weights_pb.py", line 5, in <module>
    import yolo_v3
  File "/deeplearning/tensorflow-yolo-v3/yolo_v3.py", line 75
    def _fixed_padding(inputs, kernel_size, *args, mode='CONSTANT', **kwargs):
SyntaxError: invalid syntax
stratton:root:/deep/tensorflow-yolo-v3
         * USING PYTHON3 *
>python3 convert_weights_pb.py --class_names voc.names --data_format NHWC --weights_file latest.weights
    import yolo_v3
  File "/deeplearning/tensorflow-yolo-v3/yolo_v3.py", line 6, in <module>
    slim = tf.contrib.slim
AttributeError: module 'tensorflow' has no attribute 'contrib'
JAIVIN_J_Intel
Hi Richard,
Which version of Tensorflow are you using? Try installing Tensorflow version 1.14.0. and then run the converter (convert_weights_pb.py) using Python3
Jaivin
goh__richard
Hi Jaivin
Did try to downgrade tensorflow but could not.
How can I install version 1.14.0
Pardon my ignorance, newbie to this different versions
pip install tensorflow==1.14.1
ERROR: Could not find a version that satisfies the requirement tensorflow==1.14.1 (from versions: 1.13.0rc1, 1.13.0rc2, 1.13.1, 1.13.2, 1.14.0rc0, 1.14.0rc1, 1.14.0, 1.15.0rc0, 1.15.0rc1, 1.15.0rc2, 1.15.0rc3, 1.15.0, 1.15.2, 2.0.0a0, 2.0.0b0, 2.0.0b1, 2.0.0rc0, 2.0.0rc1, 2.0.0rc2, 2.0.0, 2.0.1, 2.1.0rc0, 2.1.0rc1, 2.1.0rc2, 2.1.0, 2.2.0rc0, 2.2.0rc1, 2.2.0rc2)
ERROR: No matching distribution found for tensorflow==1.14.1
WARNING: You are using pip version 20.0.1; however, version 20.0.2 is available.
You should consider upgrading via the '/deeplearning/openvino_training_extensions/tensorflow_toolkit/ssd_detector/venv/bin/python3 -m pip install --upgrade pip' command.
goh__richard
Sorry
installed 1.14.0
now the error is
No module named 'PIL'?
Update: solve it by
pip install image
thanks
goh__richard
exporting failed
my cfg file is this format
mask = 6,7,8
anchors = 10,13,  16,30,  33,23,  30,61,  62,45,  59,119,  116,90,  156,198,  373,326
classes=1
num=9
jitter=.3
ignore_thresh = .5
truth_thresh = 1
random=1
what is wanted is this format
      "anchors": [10, 13, 16, 30, 33, 23, 30, 61, 62, 45, 59, 119, 116, 90, 156, 198, 373, 326],
      "coords": 4,
      "num": 9,
      "masks":[[6, 7, 8], [3, 4, 5], [0, 1, 2]],
      "entry_points": ["detector/yolo-v3/Reshape", "detector/yolo-v3/Reshape_4", "detector/yolo-v3/Reshape_8"
Appreciate greatly any advise.
Coffee too
JAIVIN_J_Intel
Hi Richard,
I assume that you are following the documentation to Convert YOLOv3 Model to the IR
Please refer to this and this which are discussions on this forum regarding replacing the values in custom_attributes with the parameters in the configuration file.
Hope this helps.
Jaivin
