Custom kernels for VPU (NCS2).
SergeyMalykhin
I faced an issue with custom kernel implementation for VPU (NCS2) - probably you can advise anything.
I'm using Ubuntu 20.4 and OpenVINO 2021.4.689 (latest version) - demos running fine on NCS2.
But when I'm building custom kernel from github (https://github.com/openvinotoolkit/openvino/tree/master/inference-engine/src/vpu/custom_kernels) with OpenCL compiler I have issues:
Could not find first stage linker script! Check CMake configuration for SHAVE_LDSCRIPT_DIR or override it as an environment variable.
Could not find second stage linker script! Check CMake configuration for SHAVE_LDSCRIPT_DIR or override it as an environment variable.
Build command is:
clc st.cl -o st.bin -d ma2x8x
FYI - I installed everything as in docs - https://docs.openvinotoolkit.org/latest/openvino_docs_install_guides_installing_openvino_linux.html
and prepared for custom kernels implementation as here - https://docs.openvinotoolkit.org/latest/openvino_docs_IE_DG_Extensibility_DG_VPU_Kernel.html
Please let me know if it's some known issue or probably I missed something.
Sergey
JesusE_Intel
Hi SergeyMalykhin,
Could you try sourcing the cltools_setenv.sh script under /opt/intel/openvino_2021/deployment_tools/tools/cl_compiler/bin/?
I was able to compile st.cl without any issues after sourcing the cltools_setenv.sh script.
source /opt/intel/openvino_2021/bin/setupvars.sh
cd /opt/intel/openvino_2021/deployment_tools/tools/cl_compiler/bin/
source cltools_setenv.sh ma2x8x
./clc ~/Downloads/custom_kernels/st.cl -o ~/Downloads/custom_kernels/st.bin -d ma2x8x
Jesus
Peh_Intel
Hi Sergey,
We are still investigating this issue and will get back to you at the earliest.
Peh
JesusE_Intel
Hi SergeyMalykhin,
Jesus
SergeyMalykhin
Hi Jesus,
Thanks. That worked for me.
Sergey
Peh_Intel
Hello Sergey,
This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Peh
