6595 Discussions
How can I compile a static openvino library?
xiaoxiongli
Hi, Dear all,
      Please help me...
      I wanna to compile a static openvino library in windows 10(Visual Studio verison is 16.11.3
),  and I use version 'releases/2021/3', my step is:
1) cmake -G "Visual Studio 16 2019" -A x64 -DCMAKE_BUILD_TYPE=Release -DBUILD_SHARED_LIBS=OFF ..
2) cmake --build . --config Release --verbose -j8
and then a lot of compile error occur:
ngraph_reference.lib(eval_helpers.obj) : error LNK2019: 无法解析的外部符号 "__declspec(dllimport) public: __cdecl ngraph::elemen
t::Type::operator enum ngraph::element::Type_t(void)const " (__imp_??BType@element@ngraph@@QEBA?AW4Type_t@12@XZ),函数 "cl
ass std::vector<__int64,class std::allocator<__int64> > __cdecl host_tensor_2_vector<__int64>(class std::shared_ptr<cla
ss ngraph::runtime::HostTensor>)" (??$host_tensor_2_vector@_J@@YA?AV?$vector@_JV?$allocator@_J@std@@@std@@V?$shared_ptr
@VHostTensor@runtime@ngraph@@@1@@Z) 中引用了该符号 [D:\SR\openvino_2021_3\build\inference-engine\src\transformations\inference
_engine_transformations.vcxproj]
ngraph_reference.lib(loop.obj) : error LNK2019: 无法解析的外部符号 "__declspec(dllimport) public: static class ngraph::Dimension
__cdecl ngraph::Dimension::dynamic(void)" (__imp_?dynamic@Dimension@ngraph@@SA?AV12@XZ),函数 "void __cdecl ngraph::runti
me::reference::loop(class std::shared_ptr<class ngraph::Function> const &,class std::vector<class std::shared_ptr<class
ngraph::op::util::SubGraphOp::OutputDescription>,class std::allocator<class std::shared_ptr<class ngraph::op::util::Su
bGraphOp::OutputDescription> > > const &,class std::vector<class std::shared_ptr<class ngraph::op::util::SubGraphOp::In
putDescription>,class std::allocator<class std::shared_ptr<class ngraph::op::util::SubGraphOp::InputDescription> > > co
nst &,struct ngraph::op::v5::Loop::SpecialBodyPorts const &,class std::vector<class std::shared_ptr<class ngraph::runti
me::HostTensor>,class std::allocator<class std::shared_ptr<class ngraph::runtime::HostTensor> > > const &,class std::ve
ctor<class std::shared_ptr<class ngraph::runtime::HostTensor>,class std::allocator<class std::shared_ptr<class ngraph::
runtime::HostTensor> > > const &)" (?loop@reference@runtime@ngraph@@YAXAEBV?$shared_ptr@VFunction@ngraph@@@std@@AEBV?$v
ector@V?$shared_ptr@VOutputDescription@SubGraphOp@util@op@ngraph@@@std@@V?$allocator@V?$shared_ptr@VOutputDescription@S
ubGraphOp@util@op@ngraph@@@std@@@2@@5@AEBV?$vector@V?$shared_ptr@VInputDescription@SubGraphOp@util@op@ngraph@@@std@@V?$
allocator@V?$shared_ptr@VInputDescription@SubGraphOp@util@op@ngraph@@@std@@@2@@5@AEBUSpecialBodyPorts@Loop@v5@op@3@AEBV
?$vector@V?$shared_ptr@VHostTensor@runtime@ngraph@@@std@@V?$allocator@V?$shared_ptr@VHostTensor@runtime@ngraph@@@std@@@
2@@5@4@Z) 中引用了该符号 [D:\SR\openvino_2021_3\build\inference-engine\src\transformations\inference_engine_transformations.vc
xproj]
已定义且可能匹配的符号上的提示:
"__declspec(dllimport) public: static class ngraph::PartialShape __cdecl ngraph::PartialShape::dynamic(class ngra
ph::Dimension)" (__imp_?dynamic@PartialShape@ngraph@@SA?AV12@VDimension@2@@Z)
ngraph_builders.lib(reshape.obj) : error LNK2001: 无法解析的外部符号 "__declspec(dllimport) public: __cdecl ngraph::bfloat16::bf
loat16(float)" (__imp_??0bfloat16@ngraph@@QEAA@M@Z) [D:\SR\openvino_2021_3\build\inference-engine\src\transformations\i
nference_engine_transformations.vcxproj]
ngraph_builders.lib(split.obj) : error LNK2001: 无法解析的外部符号 "__declspec(dllimport) public: __cdecl ngraph::bfloat16::bflo
at16(float)" (__imp_??0bfloat16@ngraph@@QEAA@M@Z) [D:\SR\openvino_2021_3\build\inference-engine\src\transformations\inf
ngraph_builders.lib(reduce_ops.obj) : error LNK2001: 无法解析的外部符号 "__declspec(dllimport) public: __cdecl ngraph::bfloat16:
:bfloat16(float)" (__imp_??0bfloat16@ngraph@@QEAA@M@Z) [D:\SR\openvino_2021_3\build\inference-engine\src\transformation
s\inference_engine_transformations.vcxproj]
ngraph_reference.lib(loop.obj) : error LNK2001: 无法解析的外部符号 "__declspec(dllimport) public: __cdecl ngraph::bfloat16::bflo
ngraph_builders.lib(autobroadcast.obj) : error LNK2001: 无法解析的外部符号 "__declspec(dllimport) public: __cdecl ngraph::bfloat
16::bfloat16(float)" (__imp_??0bfloat16@ngraph@@QEAA@M@Z) [D:\SR\openvino_2021_3\build\inference-engine\src\transformat
ions\inference_engine_transformations.vcxproj]
ngraph_builders.lib(make_constant.obj) : error LNK2001: 无法解析的外部符号 "__declspec(dllimport) public: __cdecl ngraph::bfloat
ngraph_builders.lib(norm.obj) : error LNK2001: 无法解析的外部符号 "__declspec(dllimport) public: __cdecl ngraph::bfloat16::bfloa
t16(float)" (__imp_??0bfloat16@ngraph@@QEAA@M@Z) [D:\SR\openvino_2021_3\build\inference-engine\src\transformations\infe
ngraph_reference.lib(loop.obj) : error LNK2019: 无法解析的外部符号 "__declspec(dllimport) public: void __cdecl ngraph::op::v0::P
arameter::set_partial_shape(class ngraph::PartialShape const &)" (__imp_?set_partial_shape@Parameter@v0@op@ngraph@@QEAA
XAEBVPartialShape@4@@Z),函数 "void __cdecl ngraph::runtime::reference::loop(class std::shared_ptr<class ngraph::Function>
const &,class std::vector<class std::shared_ptr<class ngraph::op::util::SubGraphOp::OutputDescription>,class std::allo
cator<class std::shared_ptr<class ngraph::op::util::SubGraphOp::OutputDescription> > > const &,class std::vector<class
std::shared_ptr<class ngraph::op::util::SubGraphOp::InputDescription>,class std::allocator<class std::shared_ptr<class
ngraph::op::util::SubGraphOp::InputDescription> > > const &,struct ngraph::op::v5::Loop::SpecialBodyPorts const &,class
std::vector<class std::shared_ptr<class ngraph::runtime::HostTensor>,class std::allocator<class std::shared_ptr<class
ngraph::runtime::HostTensor> > > const &,class std::vector<class std::shared_ptr<class ngraph::runtime::HostTensor>,cla
ss std::allocator<class std::shared_ptr<class ngraph::runtime::HostTensor> > > const &)" (?loop@reference@runtime@ngrap
h@@YAXAEBV?$shared_ptr@VFunction@ngraph@@@std@@AEBV?$vector@V?$shared_ptr@VOutputDescription@SubGraphOp@util@op@ngraph@
@@std@@V?$allocator@V?$shared_ptr@VOutputDescription@SubGraphOp@util@op@ngraph@@@std@@@2@@5@AEBV?$vector@V?$shared_ptr@@
VInputDescription@SubGraphOp@util@op@ngraph@@@std@@V?$allocator@V?$shared_ptr@VInputDescription@SubGraphOp@util@op@ngra
ph@@@std@@@2@@5@AEBUSpecialBodyPorts@Loop@v5@op@3@AEBV?$vector@V?$shared_ptr@VHostTensor@runtime@ngraph@@@std@@V?$alloc
ator@V?$shared_ptr@VHostTensor@runtime@ngraph@@@std@@@2@@5@4@Z) 中引用了该符号 [D:\SR\openvino_2021_3\build\inference-engine\s
rc\transformations\inference_engine_transformations.vcxproj]
ngraph_reference.lib(loop.obj) : error LNK2019: 无法解析的外部符号 "__declspec(dllimport) public: class std::vector<class std::s
hared_ptr<class ngraph::op::v0::Result>,class std::allocator<class std::shared_ptr<class ngraph::op::v0::Result> > > co
nst & __cdecl ngraph::Function::get_results(void)const " (__imp_?get_results@Function@ngraph@@QEBAAEBV?$vector@V?$share
d_ptr@VResult@v0@op@ngraph@@@std@@V?$allocator@V?$shared_ptr@VResult@v0@op@ngraph@@@std@@@2@@std@@XZ),函数 "void __cdecl
ngraph::runtime::reference::loop(class std::shared_ptr<class ngraph::Function> const &,class std::vector<class std::sha
red_ptr<class ngraph::op::util::SubGraphOp::OutputDescription>,class std::allocator<class std::shared_ptr<class ngraph:
:op::util::SubGraphOp::OutputDescription> > > const &,class std::vector<class std::shared_ptr<class ngraph::op::util::S
ubGraphOp::InputDescription>,class std::allocator<class std::shared_ptr<class ngraph::op::util::SubGraphOp::InputDescri
ption> > > const &,struct ngraph::op::v5::Loop::SpecialBodyPorts const &,class std::vector<class std::shared_ptr<class
ngraph::runtime::HostTensor>,class std::allocator<class std::shared_ptr<class ngraph::runtime::HostTensor> > > const &,
class std::vector<class std::shared_ptr<class ngraph::runtime::HostTensor>,class std::allocator<class std::shared_ptr<c
lass ngraph::runtime::HostTensor> > > const &)" (?loop@reference@runtime@ngraph@@YAXAEBV?$shared_ptr@VFunction@ngraph@@
@std@@AEBV?$vector@V?$shared_ptr@VOutputDescription@SubGraphOp@util@op@ngraph@@@std@@V?$allocator@V?$shared_ptr@VOutput
Description@SubGraphOp@util@op@ngraph@@@std@@@2@@5@AEBV?$vector@V?$shared_ptr@VInputDescription@SubGraphOp@util@op@ngra
ph@@@std@@V?$allocator@V?$shared_ptr@VInputDescription@SubGraphOp@util@op@ngraph@@@std@@@2@@5@AEBUSpecialBodyPorts@Loop
@v5@op@3@AEBV?$vector@V?$shared_ptr@VHostTensor@runtime@ngraph@@@std@@V?$allocator@V?$shared_ptr@VHostTensor@runtime@ng
raph@@@std@@@2@@5@4@Z) 中引用了该符号 [D:\SR\openvino_2021_3\build\inference-engine\src\transformations\inference_engine_trans
formations.vcxproj]
ngraph_builders.lib(reshape.obj) : error LNK2001: 无法解析的外部符号 "__declspec(dllimport) protected: void * __cdecl ngraph::op
::v0::Constant::get_data_ptr_nc(void)" (__imp_?get_data_ptr_nc@Constant@v0@op@ngraph@@IEAAPEAXXZ) [D:\SR\openvino_2021_
3\build\inference-engine\src\transformations\inference_engine_transformations.vcxproj]
ngraph_builders.lib(split.obj) : error LNK2001: 无法解析的外部符号 "__declspec(dllimport) protected: void * __cdecl ngraph::op::
v0::Constant::get_data_ptr_nc(void)" (__imp_?get_data_ptr_nc@Constant@v0@op@ngraph@@IEAAPEAXXZ) [D:\SR\openvino_2021_3\
ngraph_builders.lib(reduce_ops.obj) : error LNK2001: 无法解析的外部符号 "__declspec(dllimport) protected: void * __cdecl ngraph:
:op::v0::Constant::get_data_ptr_nc(void)" (__imp_?get_data_ptr_nc@Constant@v0@op@ngraph@@IEAAPEAXXZ) [D:\SR\openvino_20
21_3\build\inference-engine\src\transformations\inference_engine_transformations.vcxproj]
ngraph_reference.lib(loop.obj) : error LNK2001: 无法解析的外部符号 "__declspec(dllimport) protected: void * __cdecl ngraph::op::
ngraph_builders.lib(autobroadcast.obj) : error LNK2001: 无法解析的外部符号 "__declspec(dllimport) protected: void * __cdecl ngra
ph::op::v0::Constant::get_data_ptr_nc(void)" (__imp_?get_data_ptr_nc@Constant@v0@op@ngraph@@IEAAPEAXXZ) [D:\SR\openvino
_2021_3\build\inference-engine\src\transformations\inference_engine_transformations.vcxproj]
ngraph_builders.lib(make_constant.obj) : error LNK2001: 无法解析的外部符号 "__declspec(dllimport) protected: void * __cdecl ngra
ngraph_builders.lib(norm.obj) : error LNK2001: 无法解析的外部符号 "__declspec(dllimport) protected: void * __cdecl ngraph::op::v
0::Constant::get_data_ptr_nc(void)" (__imp_?get_data_ptr_nc@Constant@v0@op@ngraph@@IEAAPEAXXZ) [D:\SR\openvino_2021_3\b
ngraph_builders.lib(split.obj) : error LNK2001: 无法解析的外部符号 "__declspec(dllimport) public: __cdecl ngraph::Output<class n
graph::Node>::Output<class ngraph::Node>(void)" (__imp_??0?$Output@VNode@ngraph@@@ngraph@@QEAA@XZ) [D:\SR\openvino_2021
ngraph_builders.lib(reduce_ops.obj) : error LNK2001: 无法解析的外部符号 "__declspec(dllimport) public: __cdecl ngraph::Output<cl
ass ngraph::Node>::Output<class ngraph::Node>(void)" (__imp_??0?$Output@VNode@ngraph@@@ngraph@@QEAA@XZ) [D:\SR\openvino
ngraph_builders.lib(autobroadcast.obj) : error LNK2001: 无法解析的外部符号 "__declspec(dllimport) public: __cdecl ngraph::Output
<class ngraph::Node>::Output<class ngraph::Node>(void)" (__imp_??0?$Output@VNode@ngraph@@@ngraph@@QEAA@XZ) [D:\SR\openv
ino_2021_3\build\inference-engine\src\transformations\inference_engine_transformations.vcxproj]
ngraph_builders.lib(make_constant.obj) : error LNK2001: 无法解析的外部符号 "__declspec(dllimport) public: __cdecl ngraph::Output
ngraph_builders.lib(norm.obj) : error LNK2001: 无法解析的外部符号 "__declspec(dllimport) public: __cdecl ngraph::Output<class ng
raph::Node>::Output<class ngraph::Node>(void)" (__imp_??0?$Output@VNode@ngraph@@@ngraph@@QEAA@XZ) [D:\SR\openvino_2021_
ngraph_builders.lib(reshape.obj) : error LNK2001: 无法解析的外部符号 "__declspec(dllimport) public: __cdecl ngraph::Output<class
ngraph::Node>::Output<class ngraph::Node>(void)" (__imp_??0?$Output@VNode@ngraph@@@ngraph@@QEAA@XZ) [D:\SR\openvino_20
ngraph_builders.lib(autobroadcast.obj) : error LNK2019: 无法解析的外部符号 "__declspec(dllimport) public: __cdecl ngraph::Output
<class ngraph::Node>::Output<class ngraph::Node>(class ngraph::Output<class ngraph::Node> const &)" (__imp_??0?$Output@
VNode@ngraph@@@ngraph@@QEAA@AEBV01@@Z),函数 "public: __cdecl std::vector<class ngraph::Output<class ngraph::Node>,class s
td::allocator<class ngraph::Output<class ngraph::Node> > >::vector<class ngraph::Output<class ngraph::Node>,class std::
allocator<class ngraph::Output<class ngraph::Node> > >(class std::vector<class ngraph::Output<class ngraph::Node>,class
std::allocator<class ngraph::Output<class ngraph::Node> > > const &)" (??0?$vector@V?$Output@VNode@ngraph@@@ngraph@@V?
$allocator@V?$Output@VNode@ngraph@@@ngraph@@@std@@@std@@QEAA@AEBV01@@Z) 中引用了该符号 [D:\SR\openvino_2021_3\build\inference-
raph::Node>::Output<class ngraph::Node>(class ngraph::Output<class ngraph::Node> const &)" (__imp_??0?$Output@VNode@ngr
aph@@@ngraph@@QEAA@AEBV01@@Z) [D:\SR\openvino_2021_3\build\inference-engine\src\transformations\inference_engine_transf
ormations.vcxproj]
ngraph::Node>::Output<class ngraph::Node>(class ngraph::Output<class ngraph::Node> const &)" (__imp_??0?$Output@VNode@
ngraph@@@ngraph@@QEAA@AEBV01@@Z) [D:\SR\openvino_2021_3\build\inference-engine\src\transformations\inference_engine_tra
ass ngraph::Node>::Output<class ngraph::Node>(class ngraph::Output<class ngraph::Node> const &)" (__imp_??0?$Output@VNo
de@ngraph@@@ngraph@@QEAA@AEBV01@@Z) [D:\SR\openvino_2021_3\build\inference-engine\src\transformations\inference_engine_
graph::Node>::Output<class ngraph::Node>(class ngraph::Output<class ngraph::Node> &&)" (__imp_??0?$Output@VNode@ngraph@
@@ngraph@@QEAA@$$QEAV01@@Z) [D:\SR\openvino_2021_3\build\inference-engine\src\transformations\inference_engine_transfor
mations.vcxproj]
ass ngraph::Node>::Output<class ngraph::Node>(class ngraph::Output<class ngraph::Node> &&)" (__imp_??0?$Output@VNode@ng
raph@@@ngraph@@QEAA@$$QEAV01@@Z) [D:\SR\openvino_2021_3\build\inference-engine\src\transformations\inference_engine_tra
<class ngraph::Node>::Output<class ngraph::Node>(class ngraph::Output<class ngraph::Node> &&)" (__imp_??0?$Output@VNode
@ngraph@@@ngraph@@QEAA@$$QEAV01@@Z) [D:\SR\openvino_2021_3\build\inference-engine\src\transformations\inference_engine_
raph::Node>::Output<class ngraph::Node>(class ngraph::Output<class ngraph::Node> &&)" (__imp_??0?$Output@VNode@ngraph@@
@ngraph@@QEAA@$$QEAV01@@Z) [D:\SR\openvino_2021_3\build\inference-engine\src\transformations\inference_engine_transform
ations.vcxproj]
ngraph::Node>::Output<class ngraph::Node>(class ngraph::Output<class ngraph::Node> &&)" (__imp_??0?$Output@VNode@ngrap
h@@@ngraph@@QEAA@$$QEAV01@@Z) [D:\SR\openvino_2021_3\build\inference-engine\src\transformations\inference_engine_transf
ormations.vcxproj]
ngraph_builders.lib(autobroadcast.obj) : error LNK2019: 无法解析的外部符号 "__declspec(dllimport) public: virtual __cdecl ngraph
::op::v1::Broadcast::~Broadcast(void)" (__imp_??1Broadcast@v1@op@ngraph@@UEAA@XZ),函数 "public: virtual void * __cdecl ng
raph::op::v1::Broadcast::`scalar deleting destructor'(unsigned int)" (??_GBroadcast@v1@op@ngraph@@UEAAPEAXI@Z) 中引用了该符号
[D:\SR\openvino_2021_3\build\inference-engine\src\transformations\inference_engine_transformations.vcxproj]
ngraph_builders.lib(norm.obj) : error LNK2019: 无法解析的外部符号 "__declspec(dllimport) public: virtual __cdecl ngraph::op::v0:
:Abs::~Abs(void)" (__imp_??1Abs@v0@op@ngraph@@UEAA@XZ),函数 "public: virtual void * __cdecl ngraph::op::v0::Abs::`scalar
deleting destructor'(unsigned int)" (??_GAbs@v0@op@ngraph@@UEAAPEAXI@Z) 中引用了该符号 [D:\SR\openvino_2021_3\build\inference-
ngraph_builders.lib(norm.obj) : error LNK2019: 无法解析的外部符号 "__declspec(dllimport) public: virtual __cdecl ngraph::op::v1:
:Add::~Add(void)" (__imp_??1Add@v1@op@ngraph@@UEAA@XZ),函数 "public: virtual void * __cdecl ngraph::op::v1::Add::`scalar
deleting destructor'(unsigned int)" (??_GAdd@v1@op@ngraph@@UEAAPEAXI@Z) 中引用了该符号 [D:\SR\openvino_2021_3\build\inference-
ngraph_builders.lib(reshape.obj) : error LNK2001: 无法解析的外部符号 "__declspec(dllimport) public: virtual __cdecl ngraph::op::
v1::Add::~Add(void)" (__imp_??1Add@v1@op@ngraph@@UEAA@XZ) [D:\SR\openvino_2021_3\build\inference-engine\src\transformat
:Convert::~Convert(void)" (__imp_??1Convert@v0@op@ngraph@@UEAA@XZ),函数 "public: virtual void * __cdecl ngraph::op::v0::C
onvert::`scalar deleting destructor'(unsigned int)" (??_GConvert@v0@op@ngraph@@UEAAPEAXI@Z) 中引用了该符号 [D:\SR\openvino_202
ngraph_builders.lib(reduce_ops.obj) : error LNK2001: 无法解析的外部符号 "__declspec(dllimport) public: virtual __cdecl ngraph::o
p::v0::Convert::~Convert(void)" (__imp_??1Convert@v0@op@ngraph@@UEAA@XZ) [D:\SR\openvino_2021_3\build\inference-engine\
:Maximum::~Maximum(void)" (__imp_??1Maximum@v1@op@ngraph@@UEAA@XZ),函数 "public: virtual void * __cdecl ngraph::op::v1::M
aximum::`scalar deleting destructor'(unsigned int)" (??_GMaximum@v1@op@ngraph@@UEAAPEAXI@Z) 中引用了该符号 [D:\SR\openvino_202
:Multiply::~Multiply(void)" (__imp_??1Multiply@v1@op@ngraph@@UEAA@XZ),函数 "public: virtual void * __cdecl ngraph::op::v1
::Multiply::`scalar deleting destructor'(unsigned int)" (??_GMultiply@v1@op@ngraph@@UEAAPEAXI@Z) 中引用了该符号 [D:\SR\openvin
p::v1::Multiply::~Multiply(void)" (__imp_??1Multiply@v1@op@ngraph@@UEAA@XZ) [D:\SR\openvino_2021_3\build\inference-engi
:Power::~Power(void)" (__imp_??1Power@v1@op@ngraph@@UEAA@XZ),函数 "public: virtual void * __cdecl ngraph::op::v1::Power::
`scalar deleting destructor'(unsigned int)" (??_GPower@v1@op@ngraph@@UEAAPEAXI@Z) 中引用了该符号 [D:\SR\openvino_2021_3\build\
:ReduceSum::~ReduceSum(void)" (__imp_??1ReduceSum@v1@op@ngraph@@UEAA@XZ),函数 "public: virtual void * __cdecl ngraph::op:
:v1::ReduceSum::`scalar deleting destructor'(unsigned int)" (??_GReduceSum@v1@op@ngraph@@UEAAPEAXI@Z) 中引用了该符号 [D:\SR\op
p::v1::ReduceSum::~ReduceSum(void)" (__imp_??1ReduceSum@v1@op@ngraph@@UEAA@XZ) [D:\SR\openvino_2021_3\build\inference-e
:Sqrt::~Sqrt(void)" (__imp_??1Sqrt@v0@op@ngraph@@UEAA@XZ),函数 "public: virtual void * __cdecl ngraph::op::v0::Sqrt::`sca
lar deleting destructor'(unsigned int)" (??_GSqrt@v0@op@ngraph@@UEAAPEAXI@Z) 中引用了该符号 [D:\SR\openvino_2021_3\build\infer
ngraph_builders.lib(reshape.obj) : error LNK2019: 无法解析的外部符号 "__declspec(dllimport) public: virtual __cdecl ngraph::op::
v1::ReduceProd::~ReduceProd(void)" (__imp_??1ReduceProd@v1@op@ngraph@@UEAA@XZ),函数 "public: virtual void * __cdecl ngrap
h::op::v1::ReduceProd::`scalar deleting destructor'(unsigned int)" (??_GReduceProd@v1@op@ngraph@@UEAAPEAXI@Z) 中引用了该符号 [
p::v1::ReduceProd::~ReduceProd(void)" (__imp_??1ReduceProd@v1@op@ngraph@@UEAA@XZ) [D:\SR\openvino_2021_3\build\inferenc
v1::Reshape::~Reshape(void)" (__imp_??1Reshape@v1@op@ngraph@@UEAA@XZ),函数 "public: virtual void * __cdecl ngraph::op::v1
::Reshape::`scalar deleting destructor'(unsigned int)" (??_GReshape@v1@op@ngraph@@UEAAPEAXI@Z) 中引用了该符号 [D:\SR\openvino_
v0::Squeeze::~Squeeze(void)" (__imp_??1Squeeze@v0@op@ngraph@@UEAA@XZ),函数 "public: virtual void * __cdecl ngraph::op::v0
::Squeeze::`scalar deleting destructor'(unsigned int)" (??_GSqueeze@v0@op@ngraph@@UEAAPEAXI@Z) 中引用了该符号 [D:\SR\openvino_
v1::Transpose::~Transpose(void)" (__imp_??1Transpose@v1@op@ngraph@@UEAA@XZ),函数 "public: virtual void * __cdecl ngraph::
op::v1::Transpose::`scalar deleting destructor'(unsigned int)" (??_GTranspose@v1@op@ngraph@@UEAAPEAXI@Z) 中引用了该符号 [D:\SR
v1::VariadicSplit::~VariadicSplit(void)" (__imp_??1VariadicSplit@v1@op@ngraph@@UEAA@XZ),函数 "public: virtual void * __cd
ecl ngraph::op::v1::VariadicSplit::`scalar deleting destructor'(unsigned int)" (??_GVariadicSplit@v1@op@ngraph@@UEAAPEA
XI@Z) 中引用了该符号 [D:\SR\openvino_2021_3\build\inference-engine\src\transformations\inference_engine_transformations.vcxpro
j]
ngraph_builders.lib(split.obj) : error LNK2001: 无法解析的外部符号 "__declspec(dllimport) public: virtual __cdecl ngraph::op::v1
::VariadicSplit::~VariadicSplit(void)" (__imp_??1VariadicSplit@v1@op@ngraph@@UEAA@XZ) [D:\SR\openvino_2021_3\build\infe
v0::Range::~Range(void)" (__imp_??1Range@v0@op@ngraph@@UEAA@XZ),函数 "public: virtual void * __cdecl ngraph::op::v0::Rang
e::`scalar deleting destructor'(unsigned int)" (??_GRange@v0@op@ngraph@@UEAAPEAXI@Z) 中引用了该符号 [D:\SR\openvino_2021_3\bui
Peh_Intel
Hi XiaoXiong,
We are still investigating this issue and will get back to you at the earliest.
Peh
xiaoxiongli
Hi, @Peh_Intel
Thank you for your reply!
it seems very hard to compile a pure static openvino library now, I use version 'releases/2021/3'.
And I find that the openvino use a conception named "plugin", for example, for "GPU" device, it use a plugin named "clDNNPlugin.dll", in the openvino code, it hard code that  load clDNNPlugin.dll, but what I want is that it should be have a static library named  clDNNPlugin.lib,  I do not want use clDNNPlugin.dll because it is so big (about 7M+ Bytes),  such a big dll, it is not allowed in my product, So please help...
shaoxiong
Peh_Intel
Hi shaoxiong,
Thanks for your patience.
I’ve checked with our development teams about compiling static library. We are sorry to inform you that currently compiling static library is not possible. They are still working this in progress.
Peh
xiaoxiongli
Hi, @Peh_Intel
I really want this feature:  static link the openvino library,  so if this feature is release in the future, please let me know...
shaoxiong
Peh_Intel
Hi shaoxiong,
Okay. We will update you once this feature is available.
Peh
Peh_Intel
Hi shaoxiong,
Thank you for your question. If you need any additional information from Intel, please submit a new question as this thread is no longer being monitored.
However, we will keep tracking on the updates and update you in this thread once compiling OpenVINO™ as static library is available.
Peh
