6585 Discussions
DL Streamer: Unable to get detections from Yolov3 model
Shantanu_Bakare
I am working with DL streamer pipeline on openvino version '2021.3.394'.
When running the given python sample with the default detection model, i.e. face-detection-adas-0001,  I am able to get a tensor layer as 'detection_out'.
But in the same sample code, when I change this to 'yolo-v3-tf.xml', there are no tensor layers available. I also tried checking for different layer names for yolo from here:  yolo-v3
I also looked into yolo-v3-tf.xml file and searched for potential layer names, but couldn't find a working one.
How can I get detections from this sample code using yolo-v3-tf.xml model?
Zulkifli_Intel
Hello Shantanu_Bakare,
The Face Detection And Classification Python Sample uses the following pre-trained models from OpenVINO Open Model Zoo.
·      face-detection-adas-0001
·      age-gender-recognition-retail-0013
·      emotions-recognition-retail-0003
·      facial-landmarks-35-adas-0002-0009
·      head-pose-estimation-adas-0001
This sample is used to detect faces and it is not suitable to use with the yolo-v3-tf model as the model was trained to detect objects.
You can run the yolo-v3-tf model with dlstreamer directly using this command:
gst-launch-1.0 \
filesrc location=${VIDEO_EXAMPLE} ! decodebin ! \
gvadetect model=${DETECTION_MODEL} model_proc=${DETECTION_MODEL_PROC} device=CPU ! queue ! \
gvawatermark ! videoconvert ! fpsdisplaysink video-sink=xvimagesink sync=false
Replace VIDEO_EXAMPLE with your input sample, DETECTION_MODEL with the path to yolo-v3-tf model, and DETECTION_MODEL_PROC with /opt/intel/openvino_2021.3.394/data_processing/dl_streamer/samples/model_proc/yolo-v3-tf.json
I tested with a bottle-detection.mp4 sample video. This is my result:
Zulkifli_Intel
gst-launch-1.0 \
Zulkifli_Intel
Hello Shantanu Bakare.
This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Sincerely,
Zulkifli
