DL workbench
Besma_Guesmi
Hello
Is there any way to use DL workbench with Yolov5?
Peh_Intel
Hi Besma,
YOLOv5 is currently not an officially supported topology by OpenVINO toolkit. Hence, there is no option to select and use YOLOv5 in DL Workbench.
Peh
Andrej
Thank you for reaching out!
As it was stated YOLOv5 is currently not an officially supported topology by the OpenVINO toolkit. Yet you can import and convert it in DL Workbench. Then, you can infer the model and see the performance metrics (FPS & latency), profile and find the best combination of the streams and batches. As YOLOv5 is not officially supported by the OpenVINO toolkit, only the default optimization algorithm can be used for the INT8 calibration. Accuracy evaluation is not supported at the moment.
Andrej
DL Workbench QA
Peh_Intel
Thanks Andrej for providing a clearer clarification.
Sincerely,
Peh
Peh_Intel
Hi Besma,
This thread will no longer be monitored since we have provided answers. If you need any additional information from Intel, please submit a new question.
Peh
