6582 Discussions
Darknet Yolov4 object detection .weight and .cfg to IR representation.
KarthickM
I have been exploring on converting darknet yolov4 .weight file .cfg to tensorflow (.pb) and used mo.py to convert to IR .bin and .XML file.
I followed the instructions from here (https://docs.openvinotoolkit.org/latest/openvino_docs_MO_DG_prepare_model_convert_model_tf_specific_Convert_YOLO_From_Tensorflow.html ) for yolov3 and object detection worked fine however with less accuracy.
Now, I tried the procedure mentioned for yolov4 :
  1. Download YOLOv4 weights from yolov4.weights.
  2. Clone the repository with the YOLOv4 model.
    content_copy
    git clone https://github.com/Ma-Dan/keras-yolo4.git       ==========>  did not work.
    git clone  https://github.com/Runist/YOLOv4/  ==> Used this link to convert to .pb
  3. Convert the model to the TensorFlow 2* format. Save the code below to the converter.py file in the same folder as you downloaded yolov4.weights and run it.
    content_copy
    from keras-yolo4.model import Mish
    model = tf.keras.models.load_model('yolo4_weight.h5', custom_objects={'Mish': Mish})
    tf.saved_model.save(model, 'yolov4')
content_copy
python converter.py
  1. Run Model Optimizer to converter the model from the TensorFlow 2 format to an IR:
NOTE: Before you run the convertion, make sure you have installed all the Model Optimizer dependencies for TensorFlow 2.
content_copy
python mo.py --saved_model_dir yolov4 --output_dir models/IRs --input_shape [1,608,608,3] --model_name yolov4
It created yolov4 .bin and .XML files and when I used those files in demo object_detection_demo_yolov3_async application. Firstly, I encountered the problem because 'yoloregion' was not found from the XML. To resolve the issue, I provided classes, anchor, and mask values manually. Later while parsing output yoloregion, I did not see a valid threshold, confidence, and threshold values from the output blob.
I used a similar parse-yolo-region function in yolov3 (ParseYOLOV3Output) and as I mentioned above, it did not work.
Do I have to use different rendering output object details for yolov4?
Thanks & Regards,
Karthick
IntelSupport
Community Manager
Hi Karthick,
Thanks for reaching out. Can I know which version of the OpenVINO toolkit you are using? Please share the screenshot of any error or issue that you got.
Aznie
IntelSupport
Community Manager
Hi Karthick,
Thank you for your question. If you need any additional information from Intel, please submit a new question as this thread is no longer being monitored.
Aznie
