I use the macro "_CRTDBG_MAP_ALLOC" to detect memory leak with my simple test program. I should conclude that there were memory leaks from "inference_engined.dll".
How is the impact of such memory leak?
Below please find relevant information (1. dump of leaked memory blocks; 2. call stack of the last leaked memory block at its malloc-time; 3. call stack of the first leaked memory block at its malloc-time; 4. address range of inference_engined.dll in the process for locating memory leaking codes) for your identification of the root cause.
1. Dump of leaked memory blocks
Detected memory leaks!
Dumping objects ->
{8677} normal block at 0x00000000044B03E0, 16 bytes long.
Data: < FK > A8 46 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8676} normal block at 0x00000000044B4690, 64 bytes long.
Data: < > D8 0B C1 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8672} normal block at 0x00000000044B0390, 16 bytes long.
Data: <(FK > 28 46 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8671} normal block at 0x00000000044B4610, 64 bytes long.
Data: < > 90 0B C1 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8667} normal block at 0x00000000044B0340, 16 bytes long.
Data: < EK > A8 45 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8666} normal block at 0x00000000044B4590, 64 bytes long.
Data: <H > 48 0B C1 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8662} normal block at 0x00000000044B02F0, 16 bytes long.
Data: <(EK > 28 45 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8661} normal block at 0x00000000044B4510, 64 bytes long.
{8657} normal block at 0x00000000044B02A0, 16 bytes long.
Data: < DK > A8 44 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8656} normal block at 0x00000000044B4490, 64 bytes long.
{8652} normal block at 0x00000000044B0250, 16 bytes long.
Data: <(DK > 28 44 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8651} normal block at 0x00000000044B4410, 64 bytes long.
{8647} normal block at 0x00000000044B0200, 16 bytes long.
Data: < CK > A8 43 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8646} normal block at 0x00000000044B4390, 64 bytes long.
{8642} normal block at 0x00000000044B01B0, 16 bytes long.
Data: <(CK > 28 43 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8641} normal block at 0x00000000044B4310, 64 bytes long.
{8637} normal block at 0x00000000044B0160, 16 bytes long.
Data: < BK > A8 42 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8636} normal block at 0x00000000044B4290, 64 bytes long.
{8632} normal block at 0x00000000044B0110, 16 bytes long.
Data: <(BK > 28 42 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8631} normal block at 0x00000000044B4210, 64 bytes long.
{8627} normal block at 0x00000000044B00C0, 16 bytes long.
Data: < AK > A8 41 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8626} normal block at 0x00000000044B4190, 64 bytes long.
{8622} normal block at 0x00000000044B0070, 16 bytes long.
Data: <(AK > 28 41 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8621} normal block at 0x00000000044B4110, 64 bytes long.
{8617} normal block at 0x00000000044B0020, 16 bytes long.
Data: < @K > A8 40 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8616} normal block at 0x00000000044B4090, 64 bytes long.
{8612} normal block at 0x00000000044AFFD0, 16 bytes long.
Data: < ?K > A8 3F 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8611} normal block at 0x00000000044B3F90, 64 bytes long.
{8607} normal block at 0x00000000044AFF80, 16 bytes long.
Data: <(?K > 28 3F 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8606} normal block at 0x00000000044B3F10, 64 bytes long.
Data: < > 00 0B C1 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8602} normal block at 0x00000000044AFF30, 16 bytes long.
Data: < >K > A8 3E 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8601} normal block at 0x00000000044B3E90, 64 bytes long.
{8597} normal block at 0x00000000044AFEE0, 16 bytes long.
Data: <(>K > 28 3E 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8596} normal block at 0x00000000044B3E10, 64 bytes long.
{8592} normal block at 0x00000000044AFE90, 16 bytes long.
Data: < =K > A8 3D 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8591} normal block at 0x00000000044B3D90, 64 bytes long.
{8587} normal block at 0x00000000044AFE40, 16 bytes long.
Data: <(=K > 28 3D 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8586} normal block at 0x00000000044B3D10, 64 bytes long.
{8582} normal block at 0x00000000044AFDF0, 16 bytes long.
Data: < <K > A8 3C 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8581} normal block at 0x00000000044B3C90, 64 bytes long.
{8577} normal block at 0x00000000044AFDA0, 16 bytes long.
Data: <(<K > 28 3C 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8576} normal block at 0x00000000044B3C10, 64 bytes long.
{8572} normal block at 0x00000000044AFD50, 16 bytes long.
Data: < ;K > A8 3B 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8571} normal block at 0x00000000044B3B90, 64 bytes long.
{8567} normal block at 0x00000000044AFD00, 16 bytes long.
Data: <(;K > 28 3B 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8566} normal block at 0x00000000044B3B10, 64 bytes long.
{8562} normal block at 0x00000000044AFCB0, 16 bytes long.
Data: < :K > A8 3A 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8561} normal block at 0x00000000044B3A90, 64 bytes long.
{8557} normal block at 0x00000000044AFC60, 16 bytes long.
Data: <(:K > 28 3A 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8556} normal block at 0x00000000044B3A10, 64 bytes long.
{8552} normal block at 0x00000000044AFC10, 16 bytes long.
Data: < 9K > A8 39 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8551} normal block at 0x00000000044B3990, 64 bytes long.
{8547} normal block at 0x00000000044AFBC0, 16 bytes long.
Data: <(9K > 28 39 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8546} normal block at 0x00000000044B3910, 64 bytes long.
{8542} normal block at 0x00000000044AFB70, 16 bytes long.
Data: < 8K > A8 38 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8541} normal block at 0x00000000044B3890, 64 bytes long.
{8537} normal block at 0x00000000044AFB20, 16 bytes long.
Data: <(8K > 28 38 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8536} normal block at 0x00000000044B3810, 64 bytes long.
{8532} normal block at 0x00000000044AFAD0, 16 bytes long.
Data: < 7K > A8 37 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8531} normal block at 0x00000000044B3790, 64 bytes long.
{8527} normal block at 0x00000000044AFA80, 16 bytes long.
Data: <(7K > 28 37 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8526} normal block at 0x00000000044B3710, 64 bytes long.
{8522} normal block at 0x00000000044AFA30, 16 bytes long.
Data: < 6K > A8 36 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8521} normal block at 0x00000000044B3690, 64 bytes long.
{8517} normal block at 0x00000000044AF9E0, 16 bytes long.
Data: <(6K > 28 36 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8516} normal block at 0x00000000044B3610, 64 bytes long.
{8512} normal block at 0x00000000044AF990, 16 bytes long.
Data: < 5K > A8 35 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8511} normal block at 0x00000000044B3590, 64 bytes long.
{8507} normal block at 0x00000000044AF940, 16 bytes long.
Data: <(5K > 28 35 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8506} normal block at 0x00000000044B3510, 64 bytes long.
{8502} normal block at 0x00000000044B1880, 16 bytes long.
Data: <(TK > 28 54 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8501} normal block at 0x00000000044B5410, 64 bytes long.
{8497} normal block at 0x000000000449BA30, 16 bytes long.
Data: < I > B8 14 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{8496} normal block at 0x00000000044914A0, 64 bytes long.
{8490} normal block at 0x000000000447B540, 32 bytes long.
Data: <BinaryConvolutio> 42 69 6E 61 72 79 43 6F 6E 76 6F 6C 75 74 69 6F
{8489} normal block at 0x00000000044AF8A0, 16 bytes long.
Data: <(4K > 28 34 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8488} normal block at 0x00000000044B3410, 64 bytes long.
Data: < > B8 0A C1 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8483} normal block at 0x00000000044B1830, 16 bytes long.
Data: < SK > A8 53 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8482} normal block at 0x00000000044B5390, 64 bytes long.
Data: <p > 70 0A C1 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8478} normal block at 0x00000000044AF800, 16 bytes long.
Data: <(3K > 28 33 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8477} normal block at 0x00000000044B3310, 64 bytes long.
Data: <( > 28 0A C1 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8473} normal block at 0x00000000044B17E0, 16 bytes long.
Data: <(SK > 28 53 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8472} normal block at 0x00000000044B5310, 64 bytes long.
Data: < > E0 09 C1 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8468} normal block at 0x00000000044B1790, 16 bytes long.
Data: < RK > A8 52 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8467} normal block at 0x00000000044B5290, 64 bytes long.
Data: < > 98 09 C1 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8463} normal block at 0x00000000044B1740, 16 bytes long.
Data: <(RK > 28 52 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8462} normal block at 0x00000000044B5210, 64 bytes long.
Data: <P > 50 09 C1 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8458} normal block at 0x00000000044B16F0, 16 bytes long.
Data: < QK > A8 51 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8457} normal block at 0x00000000044B5190, 64 bytes long.
Data: < > 08 09 C1 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8453} normal block at 0x00000000044B16A0, 16 bytes long.
Data: <(QK > 28 51 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8452} normal block at 0x00000000044B5110, 64 bytes long.
Data: < > C0 08 C1 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8448} normal block at 0x00000000044AF620, 16 bytes long.
Data: <(0K > 28 30 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8447} normal block at 0x00000000044B3010, 64 bytes long.
Data: <x > 78 08 C1 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8443} normal block at 0x00000000044AF5D0, 16 bytes long.
Data: < /K > A8 2F 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8442} normal block at 0x00000000044B2F90, 64 bytes long.
Data: <0 > 30 08 C1 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8438} normal block at 0x00000000044AF580, 16 bytes long.
Data: <(/K > 28 2F 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8437} normal block at 0x00000000044B2F10, 64 bytes long.
Data: < > E8 07 C1 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8433} normal block at 0x00000000044AF530, 16 bytes long.
Data: < .K > A8 2E 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8432} normal block at 0x00000000044B2E90, 64 bytes long.
Data: < > A0 07 C1 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8428} normal block at 0x00000000044AF4E0, 16 bytes long.
Data: <(.K > 28 2E 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8427} normal block at 0x00000000044B2E10, 64 bytes long.
Data: <X > 58 07 C1 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8423} normal block at 0x00000000044AF490, 16 bytes long.
Data: < -K > A8 2D 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8422} normal block at 0x00000000044B2D90, 64 bytes long.
Data: < > 10 07 C1 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8418} normal block at 0x00000000044AF440, 16 bytes long.
Data: <(-K > 28 2D 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8417} normal block at 0x00000000044B2D10, 64 bytes long.
Data: < > C8 06 C1 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8413} normal block at 0x00000000044AF3F0, 16 bytes long.
Data: < ,K > A8 2C 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8412} normal block at 0x00000000044B2C90, 64 bytes long.
Data: < > 80 06 C1 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8408} normal block at 0x00000000044AF3A0, 16 bytes long.
Data: <(,K > 28 2C 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8407} normal block at 0x00000000044B2C10, 64 bytes long.
Data: <8 > 38 06 C1 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8403} normal block at 0x00000000044AF350, 16 bytes long.
Data: < +K > A8 2B 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8402} normal block at 0x00000000044B2B90, 64 bytes long.
Data: < > F0 05 C1 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8398} normal block at 0x00000000044AF300, 16 bytes long.
Data: <(+K > 28 2B 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8397} normal block at 0x00000000044B2B10, 64 bytes long.
Data: < > A8 05 C1 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8393} normal block at 0x00000000044B1650, 16 bytes long.
Data: < PK > A8 50 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8392} normal block at 0x00000000044B5090, 64 bytes long.
Data: <` > 60 05 C1 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8388} normal block at 0x00000000044B1600, 16 bytes long.
Data: <(PK > 28 50 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8387} normal block at 0x00000000044B5010, 64 bytes long.
Data: < > 18 05 C1 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8383} normal block at 0x00000000044AF210, 16 bytes long.
Data: < )K > A8 29 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8382} normal block at 0x00000000044B2990, 64 bytes long.
Data: < > D0 04 C1 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8378} normal block at 0x00000000044AF1C0, 16 bytes long.
Data: <()K > 28 29 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8377} normal block at 0x00000000044B2910, 64 bytes long.
Data: < > 88 04 C1 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8373} normal block at 0x00000000044AF170, 16 bytes long.
Data: < (K > A8 28 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8372} normal block at 0x00000000044B2890, 64 bytes long.
Data: <@ > 40 04 C1 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8368} normal block at 0x00000000044B15B0, 16 bytes long.
Data: < OK > A8 4F 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8367} normal block at 0x00000000044B4F90, 64 bytes long.
Data: < > F8 03 C1 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8363} normal block at 0x00000000044AF120, 16 bytes long.
Data: <((K > 28 28 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8362} normal block at 0x00000000044B2810, 64 bytes long.
Data: < > B0 03 C1 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8358} normal block at 0x00000000044AF0D0, 16 bytes long.
Data: < 'K > A8 27 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8357} normal block at 0x00000000044B2790, 64 bytes long.
Data: <h > 68 03 C1 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8353} normal block at 0x00000000044AF080, 16 bytes long.
Data: <('K > 28 27 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8352} normal block at 0x00000000044B2710, 64 bytes long.
Data: < > 20 03 C1 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8348} normal block at 0x00000000044AF030, 16 bytes long.
Data: < &K > A8 26 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8347} normal block at 0x00000000044B2690, 64 bytes long.
{8341} normal block at 0x000000000447B4E0, 32 bytes long.
Data: <SpatialTransform> 53 70 61 74 69 61 6C 54 72 61 6E 73 66 6F 72 6D
{8340} normal block at 0x00000000044AEFE0, 16 bytes long.
Data: <(&K > 28 26 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8339} normal block at 0x00000000044B2610, 64 bytes long.
Data: < > D8 02 C1 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8334} normal block at 0x00000000044AEF90, 16 bytes long.
Data: < %K > A8 25 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8333} normal block at 0x00000000044B2590, 64 bytes long.
Data: < > 90 02 C1 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8329} normal block at 0x00000000044AEF40, 16 bytes long.
Data: <(%K > 28 25 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8328} normal block at 0x00000000044B2510, 64 bytes long.
Data: <H > 48 02 C1 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8324} normal block at 0x00000000044B1560, 16 bytes long.
Data: <(OK > 28 4F 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8323} normal block at 0x00000000044B4F10, 64 bytes long.
Data: < > 00 02 C1 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8319} normal block at 0x00000000044AEEA0, 16 bytes long.
Data: <($K > 28 24 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8318} normal block at 0x00000000044B2410, 64 bytes long.
{8314} normal block at 0x00000000044AEE50, 16 bytes long.
Data: < #K > A8 23 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8313} normal block at 0x00000000044B2390, 64 bytes long.
Data: < > B8 01 C1 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8309} normal block at 0x00000000044AEE00, 16 bytes long.
Data: <(#K > 28 23 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8308} normal block at 0x00000000044B2310, 64 bytes long.
Data: <p > 70 01 C1 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8304} normal block at 0x00000000044AEDB0, 16 bytes long.
Data: < "K > A8 22 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8303} normal block at 0x00000000044B2290, 64 bytes long.
{8299} normal block at 0x00000000044AED60, 16 bytes long.
Data: <("K > 28 22 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8298} normal block at 0x00000000044B2210, 64 bytes long.
Data: <( > 28 01 C1 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8294} normal block at 0x00000000044AED10, 16 bytes long.
Data: < !K > A8 21 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8293} normal block at 0x00000000044B2190, 64 bytes long.
Data: < > E0 00 C1 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8289} normal block at 0x00000000044AECC0, 16 bytes long.
Data: <(!K > 28 21 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8288} normal block at 0x00000000044B2110, 64 bytes long.
Data: < > 98 00 C1 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8284} normal block at 0x00000000044AEC70, 16 bytes long.
Data: < K > A8 20 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8283} normal block at 0x00000000044B2090, 64 bytes long.
Data: <P > 50 00 C1 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8279} normal block at 0x00000000044AEC20, 16 bytes long.
Data: < I > A8 7F 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{8278} normal block at 0x0000000004497F90, 64 bytes long.
Data: < > 08 00 C1 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8274} normal block at 0x00000000044AEBD0, 16 bytes long.
Data: <( I > 28 7F 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{8273} normal block at 0x0000000004497F10, 64 bytes long.
Data: < > C0 FF C0 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8269} normal block at 0x00000000044B1510, 16 bytes long.
Data: < NK > A8 4E 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8268} normal block at 0x00000000044B4E90, 64 bytes long.
Data: <x > 78 FF C0 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8264} normal block at 0x00000000044AEB30, 16 bytes long.
Data: <(~I > 28 7E 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{8263} normal block at 0x0000000004497E10, 64 bytes long.
Data: <0 > 30 FF C0 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8257} normal block at 0x000000000447B7E0, 32 bytes long.
Data: <PriorBoxClustere> 50 72 69 6F 72 42 6F 78 43 6C 75 73 74 65 72 65
{8256} normal block at 0x00000000044AEAE0, 16 bytes long.
Data: < }I > A8 7D 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{8255} normal block at 0x0000000004497D90, 64 bytes long.
Data: < > E8 FE C0 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8250} normal block at 0x00000000044AEA90, 16 bytes long.
Data: <(}I > 28 7D 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{8249} normal block at 0x0000000004497D10, 64 bytes long.
Data: < > A0 FE C0 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8245} normal block at 0x00000000044AEA40, 16 bytes long.
Data: < |I > A8 7C 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{8244} normal block at 0x0000000004497C90, 64 bytes long.
Data: <X > 58 FE C0 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8240} normal block at 0x00000000044AE9F0, 16 bytes long.
Data: <(|I > 28 7C 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{8239} normal block at 0x0000000004497C10, 64 bytes long.
Data: < > 10 FE C0 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8235} normal block at 0x00000000044AE9A0, 16 bytes long.
Data: < {I > A8 7B 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{8234} normal block at 0x0000000004497B90, 64 bytes long.
Data: < > C8 FD C0 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8230} normal block at 0x00000000044AE950, 16 bytes long.
Data: <({I > 28 7B 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{8229} normal block at 0x0000000004497B10, 64 bytes long.
Data: < > 80 FD C0 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8225} normal block at 0x00000000044AE900, 16 bytes long.
Data: < zI > A8 7A 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{8224} normal block at 0x0000000004497A90, 64 bytes long.
Data: <8 > 38 FD C0 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8220} normal block at 0x00000000044AE8B0, 16 bytes long.
Data: <(zI > 28 7A 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{8219} normal block at 0x0000000004497A10, 64 bytes long.
Data: < > F0 FC C0 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8215} normal block at 0x00000000044AE860, 16 bytes long.
Data: < yI > A8 79 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{8214} normal block at 0x0000000004497990, 64 bytes long.
Data: < > A8 FC C0 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8210} normal block at 0x00000000044AE810, 16 bytes long.
Data: <(yI > 28 79 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{8209} normal block at 0x0000000004497910, 64 bytes long.
{8205} normal block at 0x00000000044AE7C0, 16 bytes long.
Data: < xI > A8 78 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{8204} normal block at 0x0000000004497890, 64 bytes long.
Data: <` > 60 FC C0 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8200} normal block at 0x00000000044AE770, 16 bytes long.
Data: <(xI > 28 78 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{8199} normal block at 0x0000000004497810, 64 bytes long.
Data: < > 18 FC C0 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8195} normal block at 0x00000000044AE720, 16 bytes long.
Data: < wI > A8 77 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{8194} normal block at 0x0000000004497790, 64 bytes long.
Data: < > D0 FB C0 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8190} normal block at 0x00000000044B14C0, 16 bytes long.
Data: <(NK > 28 4E 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8189} normal block at 0x00000000044B4E10, 64 bytes long.
Data: < > 88 FB C0 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8185} normal block at 0x00000000044AE680, 16 bytes long.
Data: < vI > A8 76 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{8184} normal block at 0x0000000004497690, 64 bytes long.
Data: <@ > 40 FB C0 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8180} normal block at 0x00000000044AE630, 16 bytes long.
Data: <(vI > 28 76 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{8179} normal block at 0x0000000004497610, 64 bytes long.
Data: < > F8 FA C0 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8175} normal block at 0x00000000044AE5E0, 16 bytes long.
Data: < uI > A8 75 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{8174} normal block at 0x0000000004497590, 64 bytes long.
{8170} normal block at 0x00000000044AE590, 16 bytes long.
Data: <(uI > 28 75 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{8169} normal block at 0x0000000004497510, 64 bytes long.
Data: < > B0 FA C0 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8165} normal block at 0x00000000044AE540, 16 bytes long.
Data: < tI > A8 74 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{8164} normal block at 0x0000000004497490, 64 bytes long.
Data: <h > 68 FA C0 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8160} normal block at 0x00000000044AE4F0, 16 bytes long.
Data: <(tI > 28 74 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{8159} normal block at 0x0000000004497410, 64 bytes long.
Data: < > 20 FA C0 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8153} normal block at 0x000000000447AB80, 32 bytes long.
Data: <DeformableConvol> 44 65 66 6F 72 6D 61 62 6C 65 43 6F 6E 76 6F 6C
{8152} normal block at 0x00000000044AE4A0, 16 bytes long.
Data: < sI > A8 73 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{8151} normal block at 0x0000000004497390, 64 bytes long.
Data: < > D8 F9 C0 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8146} normal block at 0x00000000044B1470, 16 bytes long.
Data: < MK > A8 4D 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8145} normal block at 0x00000000044B4D90, 64 bytes long.
Data: < > 90 F9 C0 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8141} normal block at 0x00000000044B1420, 16 bytes long.
Data: <(MK > 28 4D 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8140} normal block at 0x00000000044B4D10, 64 bytes long.
Data: <H > 48 F9 C0 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8136} normal block at 0x00000000044AE3B0, 16 bytes long.
Data: <(rI > 28 72 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{8135} normal block at 0x0000000004497210, 64 bytes long.
Data: < > 00 F9 C0 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8131} normal block at 0x00000000044AE360, 16 bytes long.
Data: < qI > A8 71 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{8130} normal block at 0x0000000004497190, 64 bytes long.
Data: < > B8 F8 C0 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8126} normal block at 0x00000000044AE310, 16 bytes long.
Data: <(qI > 28 71 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{8125} normal block at 0x0000000004497110, 64 bytes long.
Data: <p > 70 F8 C0 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8121} normal block at 0x00000000044AE2C0, 16 bytes long.
Data: < pI > A8 70 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{8120} normal block at 0x0000000004497090, 64 bytes long.
Data: <( > 28 F8 C0 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8116} normal block at 0x00000000044AE270, 16 bytes long.
Data: <(pI > 28 70 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{8115} normal block at 0x0000000004497010, 64 bytes long.
Data: < > E0 F7 C0 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8109} normal block at 0x000000000447B660, 32 bytes long.
Data: <CTCGreedyDecoder> 43 54 43 47 72 65 65 64 79 44 65 63 6F 64 65 72
{8108} normal block at 0x00000000044B13D0, 16 bytes long.
Data: < LK > A8 4C 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8107} normal block at 0x00000000044B4C90, 64 bytes long.
Data: < > 98 F7 C0 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8100} normal block at 0x000000000447B600, 32 bytes long.
Data: <BatchNormalizati> 42 61 74 63 68 4E 6F 72 6D 61 6C 69 7A 61 74 69
{8099} normal block at 0x00000000044B0520, 16 bytes long.
Data: < HK > A8 48 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8098} normal block at 0x00000000044B4890, 64 bytes long.
Data: <P > 50 F7 C0 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8093} normal block at 0x00000000044B04D0, 16 bytes long.
Data: <(HK > 28 48 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8092} normal block at 0x00000000044B4810, 64 bytes long.
Data: < > 08 F7 C0 AE FE 07 00 00 01 00 00 00 01 00 00 00
{8088} normal block at 0x00000000044B0480, 16 bytes long.
Data: < GK > A8 47 4B 04 00 00 00 00 00 00 00 00 00 00 00 00
{8087} normal block at 0x00000000044B4790, 64 bytes long.
Data: < > C0 F6 C0 AE FE 07 00 00 01 00 00 00 01 00 00 00
{1770} normal block at 0x000000000448FEA0, 16 bytes long.
Data: < I > D0 86 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1769} normal block at 0x00000000044986C0, 72 bytes long.
Data: <p G I > 70 C4 47 04 00 00 00 00 A0 85 49 04 00 00 00 00
{1761} normal block at 0x000000000448FE00, 16 bytes long.
Data: <@ I > 40 86 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1760} normal block at 0x0000000004498630, 72 bytes long.
Data: < I I > B0 20 49 04 00 00 00 00 20 20 49 04 00 00 00 00
{1752} normal block at 0x000000000448FD60, 16 bytes long.
Data: < I > B0 85 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1751} normal block at 0x00000000044985A0, 72 bytes long.
Data: < I I > C0 86 49 04 00 00 00 00 80 84 49 04 00 00 00 00
{1743} normal block at 0x000000000448FCC0, 16 bytes long.
Data: < I > 20 85 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1742} normal block at 0x0000000004498510, 72 bytes long.
Data: <`+I *I > 60 2B 49 04 00 00 00 00 D0 2A 49 04 00 00 00 00
{1734} normal block at 0x000000000448FC20, 16 bytes long.
Data: < I > 90 84 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1733} normal block at 0x0000000004498480, 72 bytes long.
Data: < I I > A0 85 49 04 00 00 00 00 F0 83 49 04 00 00 00 00
{1725} normal block at 0x000000000448FB80, 16 bytes long.
Data: < I > 00 84 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1724} normal block at 0x00000000044983F0, 72 bytes long.
Data: < I ` I > 80 84 49 04 00 00 00 00 60 83 49 04 00 00 00 00
{1716} normal block at 0x000000000448FAE0, 16 bytes long.
Data: <p I > 70 83 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1715} normal block at 0x0000000004498360, 72 bytes long.
Data: < I I > F0 83 49 04 00 00 00 00 D0 82 49 04 00 00 00 00
{1707} normal block at 0x000000000448FA40, 16 bytes long.
Data: < I > E0 82 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1706} normal block at 0x00000000044982D0, 72 bytes long.
Data: <` I I > 60 83 49 04 00 00 00 00 B0 81 49 04 00 00 00 00
{1698} normal block at 0x000000000448F9A0, 16 bytes long.
Data: <P I > 50 82 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1697} normal block at 0x0000000004498240, 72 bytes long.
Data: < G G > 90 C5 47 04 00 00 00 00 00 C5 47 04 00 00 00 00
{1689} normal block at 0x000000000448F900, 16 bytes long.
Data: < I > C0 81 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1688} normal block at 0x00000000044981B0, 72 bytes long.
Data: < I ?I > D0 82 49 04 00 00 00 00 10 3F 49 04 00 00 00 00
{1680} normal block at 0x000000000448F860, 16 bytes long.
Data: <0 I > 30 81 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1679} normal block at 0x0000000004498120, 72 bytes long.
Data: < +I `+I > F0 2B 49 04 00 00 00 00 60 2B 49 04 00 00 00 00
{1671} normal block at 0x000000000448F7C0, 16 bytes long.
Data: < I > A0 80 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1670} normal block at 0x0000000004498090, 72 bytes long.
Data: < %I $I > C0 25 49 04 00 00 00 00 A0 24 49 04 00 00 00 00
{1662} normal block at 0x000000000448F720, 16 bytes long.
Data: < ?I > 20 3F 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1661} normal block at 0x0000000004493F10, 72 bytes long.
Data: < I =I > B0 81 49 04 00 00 00 00 F0 3D 49 04 00 00 00 00
{1653} normal block at 0x000000000448F680, 16 bytes long.
Data: < >I > 90 3E 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1652} normal block at 0x0000000004493E80, 72 bytes long.
Data: < -I -I > A0 2D 49 04 00 00 00 00 10 2D 49 04 00 00 00 00
{1644} normal block at 0x000000000448F5E0, 16 bytes long.
Data: < >I > 00 3E 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1643} normal block at 0x0000000004493DF0, 72 bytes long.
Data: < ?I `=I > 10 3F 49 04 00 00 00 00 60 3D 49 04 00 00 00 00
{1635} normal block at 0x000000000448F540, 16 bytes long.
Data: <p=I > 70 3D 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1634} normal block at 0x0000000004493D60, 72 bytes long.
Data: < =I <I > F0 3D 49 04 00 00 00 00 D0 3C 49 04 00 00 00 00
{1626} normal block at 0x000000000448F4A0, 16 bytes long.
Data: < <I > E0 3C 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1625} normal block at 0x0000000004493CD0, 72 bytes long.
Data: <`=I ;I > 60 3D 49 04 00 00 00 00 B0 3B 49 04 00 00 00 00
{1617} normal block at 0x000000000448F400, 16 bytes long.
Data: <P<I > 50 3C 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1616} normal block at 0x0000000004493C40, 72 bytes long.
Data: <@ G G > 40 D9 47 04 00 00 00 00 B0 D8 47 04 00 00 00 00
{1608} normal block at 0x000000000448F360, 16 bytes long.
Data: < ;I > C0 3B 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1607} normal block at 0x0000000004493BB0, 72 bytes long.
Data: < <I ;I > D0 3C 49 04 00 00 00 00 20 3B 49 04 00 00 00 00
{1599} normal block at 0x000000000448F2C0, 16 bytes long.
Data: <0;I > 30 3B 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1598} normal block at 0x0000000004493B20, 72 bytes long.
Data: < ;I :I > B0 3B 49 04 00 00 00 00 90 3A 49 04 00 00 00 00
{1590} normal block at 0x000000000448F220, 16 bytes long.
Data: < :I > A0 3A 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1589} normal block at 0x0000000004493A90, 72 bytes long.
Data: < ;I 8I > 20 3B 49 04 00 00 00 00 E0 38 49 04 00 00 00 00
{1581} normal block at 0x000000000448F180, 16 bytes long.
Data: < :I > 10 3A 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1580} normal block at 0x0000000004493A00, 72 bytes long.
Data: < 4I p G > F0 34 49 04 00 00 00 00 70 C4 47 04 00 00 00 00
{1572} normal block at 0x000000000448F0E0, 16 bytes long.
Data: < 9I > 80 39 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1571} normal block at 0x0000000004493970, 72 bytes long.
Data: < G 0 G > C0 CB 47 04 00 00 00 00 30 CB 47 04 00 00 00 00
{1563} normal block at 0x000000000448F040, 16 bytes long.
Data: < 8I > F0 38 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1562} normal block at 0x00000000044938E0, 72 bytes long.
Data: < :I P8I > 90 3A 49 04 00 00 00 00 50 38 49 04 00 00 00 00
{1554} normal block at 0x000000000448EFA0, 16 bytes long.
Data: <`8I > 60 38 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1553} normal block at 0x0000000004493850, 72 bytes long.
Data: < 8I 7I > E0 38 49 04 00 00 00 00 C0 37 49 04 00 00 00 00
{1545} normal block at 0x000000000448EF00, 16 bytes long.
Data: < 7I > D0 37 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1544} normal block at 0x00000000044937C0, 72 bytes long.
Data: <P8I 07I > 50 38 49 04 00 00 00 00 30 37 49 04 00 00 00 00
{1536} normal block at 0x000000000448EE60, 16 bytes long.
Data: <@7I > 40 37 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1535} normal block at 0x0000000004493730, 72 bytes long.
Data: < 7I 6I > C0 37 49 04 00 00 00 00 10 36 49 04 00 00 00 00
{1527} normal block at 0x000000000448EDC0, 16 bytes long.
Data: < 6I > B0 36 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1526} normal block at 0x00000000044936A0, 72 bytes long.
Data: < G @ G > 20 C6 47 04 00 00 00 00 40 C7 47 04 00 00 00 00
{1518} normal block at 0x000000000448ED20, 16 bytes long.
Data: < 6I > 20 36 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1517} normal block at 0x0000000004493610, 72 bytes long.
Data: <07I 5I > 30 37 49 04 00 00 00 00 80 35 49 04 00 00 00 00
{1509} normal block at 0x000000000448EC80, 16 bytes long.
Data: < 5I > 90 35 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1508} normal block at 0x0000000004493580, 72 bytes long.
Data: < 6I `4I > 10 36 49 04 00 00 00 00 60 34 49 04 00 00 00 00
{1500} normal block at 0x000000000448EBE0, 16 bytes long.
Data: < 5I > 00 35 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1499} normal block at 0x00000000044934F0, 72 bytes long.
Data: < G :I > C0 D4 47 04 00 00 00 00 00 3A 49 04 00 00 00 00
{1491} normal block at 0x000000000448EB40, 16 bytes long.
Data: <p4I > 70 34 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1490} normal block at 0x0000000004493460, 72 bytes long.
Data: < 5I @3I > 80 35 49 04 00 00 00 00 40 33 49 04 00 00 00 00
{1482} normal block at 0x000000000448EAA0, 16 bytes long.
Data: < 3I > E0 33 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1481} normal block at 0x00000000044933D0, 72 bytes long.
Data: < )I "I > 20 29 49 04 00 00 00 00 F0 22 49 04 00 00 00 00
{1473} normal block at 0x000000000448EA00, 16 bytes long.
Data: <P3I > 50 33 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1472} normal block at 0x0000000004493340, 72 bytes long.
Data: <`4I 2I > 60 34 49 04 00 00 00 00 B0 32 49 04 00 00 00 00
{1464} normal block at 0x000000000448E960, 16 bytes long.
Data: < 2I > C0 32 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1463} normal block at 0x00000000044932B0, 72 bytes long.
Data: <@3I 2I > 40 33 49 04 00 00 00 00 20 32 49 04 00 00 00 00
{1455} normal block at 0x000000000448E8C0, 16 bytes long.
Data: <02I > 30 32 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1454} normal block at 0x0000000004493220, 72 bytes long.
Data: < 2I 1I > B0 32 49 04 00 00 00 00 90 31 49 04 00 00 00 00
{1446} normal block at 0x000000000448E820, 16 bytes long.
Data: < 1I > A0 31 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1445} normal block at 0x0000000004493190, 72 bytes long.
Data: < 2I 1I > 20 32 49 04 00 00 00 00 00 31 49 04 00 00 00 00
{1435} normal block at 0x000000000447AFA0, 32 bytes long.
{1434} normal block at 0x000000000448E780, 16 bytes long.
Data: < 1I > 10 31 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1433} normal block at 0x0000000004493100, 72 bytes long.
Data: < 1I p0I > 90 31 49 04 00 00 00 00 70 30 49 04 00 00 00 00
{1421} normal block at 0x000000000448E6E0, 16 bytes long.
Data: < 0I > 80 30 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1420} normal block at 0x0000000004493070, 72 bytes long.
Data: < 1I /I > 00 31 49 04 00 00 00 00 E0 2F 49 04 00 00 00 00
{1412} normal block at 0x000000000448E640, 16 bytes long.
Data: < /I > F0 2F 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1411} normal block at 0x0000000004492FE0, 72 bytes long.
Data: <p0I 0.I > 70 30 49 04 00 00 00 00 30 2E 49 04 00 00 00 00
{1403} normal block at 0x000000000448E5A0, 16 bytes long.
Data: <`/I > 60 2F 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1402} normal block at 0x0000000004492F50, 72 bytes long.
Data: < G G > 80 DB 47 04 00 00 00 00 F0 DA 47 04 00 00 00 00
{1394} normal block at 0x000000000448E500, 16 bytes long.
Data: < .I > D0 2E 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1393} normal block at 0x0000000004492EC0, 72 bytes long.
Data: < (I P G > 90 28 49 04 00 00 00 00 50 CC 47 04 00 00 00 00
{1385} normal block at 0x000000000448E460, 16 bytes long.
Data: <@.I > 40 2E 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1384} normal block at 0x0000000004492E30, 72 bytes long.
Data: < /I -I > E0 2F 49 04 00 00 00 00 A0 2D 49 04 00 00 00 00
{1376} normal block at 0x000000000448E3C0, 16 bytes long.
Data: < -I > B0 2D 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1375} normal block at 0x0000000004492DA0, 72 bytes long.
Data: <0.I >I > 30 2E 49 04 00 00 00 00 80 3E 49 04 00 00 00 00
{1367} normal block at 0x000000000448E320, 16 bytes long.
Data: < -I > 20 2D 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1366} normal block at 0x0000000004492D10, 72 bytes long.
Data: < >I ,I > 80 3E 49 04 00 00 00 00 80 2C 49 04 00 00 00 00
{1358} normal block at 0x000000000448E280, 16 bytes long.
Data: < ,I > 90 2C 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1357} normal block at 0x0000000004492C80, 72 bytes long.
Data: < -I +I > 10 2D 49 04 00 00 00 00 F0 2B 49 04 00 00 00 00
{1349} normal block at 0x000000000448E1E0, 16 bytes long.
Data: < ,I > 00 2C 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1348} normal block at 0x0000000004492BF0, 72 bytes long.
Data: < ,I I > 80 2C 49 04 00 00 00 00 20 81 49 04 00 00 00 00
{1340} normal block at 0x000000000448E140, 16 bytes long.
Data: <p+I > 70 2B 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1339} normal block at 0x0000000004492B60, 72 bytes long.
Data: < I I > 20 81 49 04 00 00 00 00 10 85 49 04 00 00 00 00
{1331} normal block at 0x000000000448E0A0, 16 bytes long.
Data: < *I > E0 2A 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1330} normal block at 0x0000000004492AD0, 72 bytes long.
Data: < I )I > 10 85 49 04 00 00 00 00 B0 29 49 04 00 00 00 00
{1184} normal block at 0x0000000004493FF0, 8239 bytes long.
Data: < ?I > FA FA FA FA FA FA FA FA F0 3F 49 04 00 00 00 00
{1181} normal block at 0x000000000448E000, 16 bytes long.
Data: <P*I > 50 2A 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1180} normal block at 0x0000000004492A40, 72 bytes long.
Data: < &I P&I > E0 26 49 04 00 00 00 00 50 26 49 04 00 00 00 00
{1172} normal block at 0x000000000448DF60, 16 bytes long.
Data: < )I > C0 29 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1171} normal block at 0x00000000044929B0, 72 bytes long.
Data: < *I p'I > D0 2A 49 04 00 00 00 00 70 27 49 04 00 00 00 00
{1163} normal block at 0x000000000448DEC0, 16 bytes long.
Data: <0)I > 30 29 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1162} normal block at 0x0000000004492920, 72 bytes long.
Data: < #I 3I > 80 23 49 04 00 00 00 00 D0 33 49 04 00 00 00 00
{1154} normal block at 0x000000000448DE20, 16 bytes long.
Data: < (I > A0 28 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1153} normal block at 0x0000000004492890, 72 bytes long.
Data: < G .I > E0 CC 47 04 00 00 00 00 C0 2E 49 04 00 00 00 00
{1145} normal block at 0x000000000448DD80, 16 bytes long.
Data: < (I > 10 28 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1144} normal block at 0x0000000004492800, 72 bytes long.
Data: < G G > A0 CA 47 04 00 00 00 00 10 CA 47 04 00 00 00 00
{1136} normal block at 0x000000000448DCE0, 16 bytes long.
Data: < 'I > 80 27 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1135} normal block at 0x0000000004492770, 72 bytes long.
Data: < )I &I > B0 29 49 04 00 00 00 00 E0 26 49 04 00 00 00 00
{1127} normal block at 0x000000000448DC40, 16 bytes long.
Data: < &I > F0 26 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1126} normal block at 0x00000000044926E0, 72 bytes long.
Data: <p'I @*I > 70 27 49 04 00 00 00 00 40 2A 49 04 00 00 00 00
{1118} normal block at 0x000000000448DBA0, 16 bytes long.
Data: <`&I > 60 26 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1117} normal block at 0x0000000004492650, 72 bytes long.
Data: <@*I %I > 40 2A 49 04 00 00 00 00 C0 25 49 04 00 00 00 00
{1109} normal block at 0x000000000448DB00, 16 bytes long.
Data: < %I > D0 25 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1108} normal block at 0x00000000044925C0, 72 bytes long.
Data: <P&I I > 50 26 49 04 00 00 00 00 90 80 49 04 00 00 00 00
{1100} normal block at 0x000000000448DA60, 16 bytes long.
Data: <@%I > 40 25 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1099} normal block at 0x0000000004492530, 72 bytes long.
Data: < G G > B0 CF 47 04 00 00 00 00 A0 DC 47 04 00 00 00 00
{1091} normal block at 0x000000000448D9C0, 16 bytes long.
Data: < $I > B0 24 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1090} normal block at 0x00000000044924A0, 72 bytes long.
Data: < I $I > 90 80 49 04 00 00 00 00 10 24 49 04 00 00 00 00
{1082} normal block at 0x000000000448D920, 16 bytes long.
Data: < $I > 20 24 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1081} normal block at 0x0000000004492410, 72 bytes long.
Data: < $I #I > A0 24 49 04 00 00 00 00 80 23 49 04 00 00 00 00
{1073} normal block at 0x000000000448D880, 16 bytes long.
Data: < #I > 90 23 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1072} normal block at 0x0000000004492380, 72 bytes long.
Data: < $I )I > 10 24 49 04 00 00 00 00 20 29 49 04 00 00 00 00
{1064} normal block at 0x000000000448D7E0, 16 bytes long.
Data: < #I > 00 23 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1063} normal block at 0x00000000044922F0, 72 bytes long.
Data: < 3I !I > D0 33 49 04 00 00 00 00 D0 21 49 04 00 00 00 00
{1055} normal block at 0x000000000448D740, 16 bytes long.
Data: <p"I > 70 22 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1054} normal block at 0x0000000004492260, 72 bytes long.
Data: <@!I G > 40 21 49 04 00 00 00 00 C0 CB 47 04 00 00 00 00
{1046} normal block at 0x000000000448D6A0, 16 bytes long.
Data: < !I > E0 21 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1045} normal block at 0x00000000044921D0, 72 bytes long.
Data: < "I I > F0 22 49 04 00 00 00 00 B0 20 49 04 00 00 00 00
{1037} normal block at 0x000000000448D600, 16 bytes long.
Data: <P!I > 50 21 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1036} normal block at 0x0000000004492140, 72 bytes long.
Data: < G `"I > C0 DD 47 04 00 00 00 00 60 22 49 04 00 00 00 00
{1026} normal block at 0x000000000447AEE0, 32 bytes long.
{1025} normal block at 0x000000000448D560, 16 bytes long.
Data: < I > C0 20 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1024} normal block at 0x00000000044920B0, 72 bytes long.
Data: < !I 0 I > D0 21 49 04 00 00 00 00 30 86 49 04 00 00 00 00
{1012} normal block at 0x000000000448D4C0, 16 bytes long.
Data: <0 I > 30 20 49 04 00 00 00 00 00 00 00 00 00 00 00 00
{1011} normal block at 0x0000000004492020, 72 bytes long.
Data: <0 I P G > 30 86 49 04 00 00 00 00 50 DE 47 04 00 00 00 00
{1003} normal block at 0x000000000448D420, 16 bytes long.
Data: <` G > 60 DE 47 04 00 00 00 00 00 00 00 00 00 00 00 00
{1002} normal block at 0x000000000447DE50, 72 bytes long.
Data: < I 0 G > 20 20 49 04 00 00 00 00 30 DD 47 04 00 00 00 00
{994} normal block at 0x000000000448D380, 16 bytes long.
Data: < G > D0 DD 47 04 00 00 00 00 00 00 00 00 00 00 00 00
{993} normal block at 0x000000000447DDC0, 72 bytes long.
Data: <P G @!I > 50 CC 47 04 00 00 00 00 40 21 49 04 00 00 00 00
{985} normal block at 0x000000000448D2E0, 16 bytes long.
Data: <@ G > 40 DD 47 04 00 00 00 00 00 00 00 00 00 00 00 00
{984} normal block at 0x000000000447DD30, 72 bytes long.
Data: <P G G > 50 DE 47 04 00 00 00 00 10 DC 47 04 00 00 00 00
{976} normal block at 0x000000000448D240, 16 bytes long.
Data: < G > B0 DC 47 04 00 00 00 00 00 00 00 00 00 00 00 00
{975} normal block at 0x000000000447DCA0, 72 bytes long.
Data: <0%I G > 30 25 49 04 00 00 00 00 00 CE 47 04 00 00 00 00
{967} normal block at 0x000000000448D1A0, 16 bytes long.
Data: < G > 20 DC 47 04 00 00 00 00 00 00 00 00 00 00 00 00
{966} normal block at 0x000000000447DC10, 72 bytes long.
Data: <0 G G > 30 DD 47 04 00 00 00 00 80 DB 47 04 00 00 00 00
{958} normal block at 0x000000000448D100, 16 bytes long.
Data: < G > 90 DB 47 04 00 00 00 00 00 00 00 00 00 00 00 00
{957} normal block at 0x000000000447DB80, 72 bytes long.
Data: < G P/I > 10 DC 47 04 00 00 00 00 50 2F 49 04 00 00 00 00
{949} normal block at 0x000000000448D060, 16 bytes long.
Data: < G > 00 DB 47 04 00 00 00 00 00 00 00 00 00 00 00 00
{948} normal block at 0x000000000447DAF0, 72 bytes long.
Data: <P/I G > 50 2F 49 04 00 00 00 00 D0 D9 47 04 00 00 00 00
{940} normal block at 0x000000000448CFC0, 16 bytes long.
Data: <p G > 70 DA 47 04 00 00 00 00 00 00 00 00 00 00 00 00
{939} normal block at 0x000000000447DA60, 72 bytes long.
Data: <p G P G > 70 D6 47 04 00 00 00 00 50 D5 47 04 00 00 00 00
{931} normal block at 0x000000000448CF20, 16 bytes long.
Data: < G > E0 D9 47 04 00 00 00 00 00 00 00 00 00 00 00 00
{930} normal block at 0x000000000447D9D0, 72 bytes long.
Data: < G @ G > F0 DA 47 04 00 00 00 00 40 D9 47 04 00 00 00 00
{922} normal block at 0x000000000448CE80, 16 bytes long.
Data: <P G > 50 D9 47 04 00 00 00 00 00 00 00 00 00 00 00 00
{921} normal block at 0x000000000447D940, 72 bytes long.
Data: < G @<I > D0 D9 47 04 00 00 00 00 40 3C 49 04 00 00 00 00
{913} normal block at 0x000000000448CDE0, 16 bytes long.
Data: < G > C0 D8 47 04 00 00 00 00 00 00 00 00 00 00 00 00
{912} normal block at 0x000000000447D8B0, 72 bytes long.
Data: <@<I G > 40 3C 49 04 00 00 00 00 20 D8 47 04 00 00 00 00
{904} normal block at 0x000000000448CD40, 16 bytes long.
Data: <0 G > 30 D8 47 04 00 00 00 00 00 00 00 00 00 00 00 00
{903} normal block at 0x000000000447D820, 72 bytes long.
Data: < G G > B0 D8 47 04 00 00 00 00 90 D7 47 04 00 00 00 00
{895} normal block at 0x000000000448CCA0, 16 bytes long.
Data: < G > A0 D7 47 04 00 00 00 00 00 00 00 00 00 00 00 00
{894} normal block at 0x000000000447D790, 72 bytes long.
Data: < G G > 20 D8 47 04 00 00 00 00 00 D7 47 04 00 00 00 00
{886} normal block at 0x000000000448CC00, 16 bytes long.
Data: < G > 10 D7 47 04 00 00 00 00 00 00 00 00 00 00 00 00
{885} normal block at 0x000000000447D700, 72 bytes long.
Data: < G p G > 90 D7 47 04 00 00 00 00 70 D6 47 04 00 00 00 00
{875} normal block at 0x000000000447AE20, 32 bytes long.
{874} normal block at 0x000000000448CB60, 16 bytes long.
Data: < G > 80 D6 47 04 00 00 00 00 00 00 00 00 00 00 00 00
{873} normal block at 0x000000000447D670, 72 bytes long.
Data: < G ` G > 00 D7 47 04 00 00 00 00 60 DA 47 04 00 00 00 00
{861} normal block at 0x000000000448CAC0, 16 bytes long.
Data: < G > F0 D5 47 04 00 00 00 00 00 00 00 00 00 00 00 00
{860} normal block at 0x000000000447D5E0, 72 bytes long.
Data: < G G > A0 D3 47 04 00 00 00 00 10 D3 47 04 00 00 00 00
{852} normal block at 0x000000000448CA20, 16 bytes long.
Data: <` G > 60 D5 47 04 00 00 00 00 00 00 00 00 00 00 00 00
{851} normal block at 0x000000000447D550, 72 bytes long.
Data: <` G G > 60 DA 47 04 00 00 00 00 A0 D3 47 04 00 00 00 00
{843} normal block at 0x000000000448C980, 16 bytes long.
Data: < G > D0 D4 47 04 00 00 00 00 00 00 00 00 00 00 00 00
{842} normal block at 0x000000000447D4C0, 72 bytes long.
Data: < G 4I > F0 C8 47 04 00 00 00 00 F0 34 49 04 00 00 00 00
{834} normal block at 0x000000000448C8E0, 16 bytes long.
Data: <@ G > 40 D4 47 04 00 00 00 00 00 00 00 00 00 00 00 00
{833} normal block at 0x000000000447D430, 72 bytes long.
Data: < G G > 00 C5 47 04 00 00 00 00 D0 C7 47 04 00 00 00 00
{825} normal block at 0x000000000448C840, 16 bytes long.
Data: < G > B0 D3 47 04 00 00 00 00 00 00 00 00 00 00 00 00
{824} normal block at 0x000000000447D3A0, 72 bytes long.
Data: <P G G > 50 D5 47 04 00 00 00 00 E0 D5 47 04 00 00 00 00
{816} normal block at 0x000000000448C7A0, 16 bytes long.
Data: < G > 20 D3 47 04 00 00 00 00 00 00 00 00 00 00 00 00
{815} normal block at 0x000000000447D310, 72 bytes long.
Data: < G ` G > E0 D5 47 04 00 00 00 00 60 D1 47 04 00 00 00 00
{807} normal block at 0x000000000448C700, 16 bytes long.
Data: < G > 90 D2 47 04 00 00 00 00 00 00 00 00 00 00 00 00
{806} normal block at 0x000000000447D280, 72 bytes long.
Data: <@ G G > 40 D0 47 04 00 00 00 00 20 CF 47 04 00 00 00 00
{798} normal block at 0x000000000448C660, 16 bytes long.
Data: < G > 00 D2 47 04 00 00 00 00 00 00 00 00 00 00 00 00
{797} normal block at 0x000000000447D1F0, 72 bytes long.
Data: <` G G > 60 D1 47 04 00 00 00 00 D0 D0 47 04 00 00 00 00
{789} normal block at 0x000000000448C5C0, 16 bytes long.
Data: <p G > 70 D1 47 04 00 00 00 00 00 00 00 00 00 00 00 00
{788} normal block at 0x000000000447D160, 72 bytes long.
Data: < G G > 10 D3 47 04 00 00 00 00 F0 D1 47 04 00 00 00 00
{780} normal block at 0x000000000448C520, 16 bytes long.
Data: < G > E0 D0 47 04 00 00 00 00 00 00 00 00 00 00 00 00
{779} normal block at 0x000000000447D0D0, 72 bytes long.
Data: < G @ G > F0 D1 47 04 00 00 00 00 40 D0 47 04 00 00 00 00
{771} normal block at 0x000000000448C480, 16 bytes long.
Data: <P G > 50 D0 47 04 00 00 00 00 00 00 00 00 00 00 00 00
{770} normal block at 0x000000000447D040, 72 bytes long.
Data: < G G > D0 D0 47 04 00 00 00 00 80 D2 47 04 00 00 00 00
{762} normal block at 0x000000000448C3E0, 16 bytes long.
Data: < G > C0 CF 47 04 00 00 00 00 00 00 00 00 00 00 00 00
{761} normal block at 0x000000000447CFB0, 72 bytes long.
Data: < G 0%I > 20 CF 47 04 00 00 00 00 30 25 49 04 00 00 00 00
{753} normal block at 0x000000000448C340, 16 bytes long.
Data: <0 G > 30 CF 47 04 00 00 00 00 00 00 00 00 00 00 00 00
{752} normal block at 0x000000000447CF20, 72 bytes long.
Data: < G G > 80 D2 47 04 00 00 00 00 B0 CF 47 04 00 00 00 00
{744} normal block at 0x000000000448C2A0, 16 bytes long.
Data: < G > A0 CE 47 04 00 00 00 00 00 00 00 00 00 00 00 00
{743} normal block at 0x000000000447CE90, 72 bytes long.
Data: <p G G > 70 CD 47 04 00 00 00 00 A0 CA 47 04 00 00 00 00
{735} normal block at 0x000000000448C200, 16 bytes long.
Data: < G > 10 CE 47 04 00 00 00 00 00 00 00 00 00 00 00 00
{734} normal block at 0x000000000447CE00, 72 bytes long.
Data: < G G > A0 DC 47 04 00 00 00 00 E0 CC 47 04 00 00 00 00
{726} normal block at 0x000000000448C160, 16 bytes long.
Data: < G > 80 CD 47 04 00 00 00 00 00 00 00 00 00 00 00 00
{725} normal block at 0x000000000447CD70, 72 bytes long.
Data: <0 G G > 30 CB 47 04 00 00 00 00 90 CE 47 04 00 00 00 00
{717} normal block at 0x000000000448C0C0, 16 bytes long.
Data: < G > F0 CC 47 04 00 00 00 00 00 00 00 00 00 00 00 00
{716} normal block at 0x000000000447CCE0, 72 bytes long.
Data: < G (I > 00 CE 47 04 00 00 00 00 90 28 49 04 00 00 00 00
{708} normal block at 0x000000000448C020, 16 bytes long.
Data: <` G > 60 CC 47 04 00 00 00 00 00 00 00 00 00 00 00 00
{707} normal block at 0x000000000447CC50, 72 bytes long.
Data: < .I G > C0 2E 49 04 00 00 00 00 C0 DD 47 04 00 00 00 00
{699} normal block at 0x0000000004465800, 16 bytes long.
Data: < G > D0 CB 47 04 00 00 00 00 00 00 00 00 00 00 00 00
{698} normal block at 0x000000000447CBC0, 72 bytes long.
Data: <`"I p9I > 60 22 49 04 00 00 00 00 70 39 49 04 00 00 00 00
{688} normal block at 0x000000000447AD60, 32 bytes long.
{687} normal block at 0x0000000004465760, 16 bytes long.
Data: <@ G > 40 CB 47 04 00 00 00 00 00 00 00 00 00 00 00 00
{686} normal block at 0x000000000447CB30, 72 bytes long.
Data: <p9I p G > 70 39 49 04 00 00 00 00 70 CD 47 04 00 00 00 00
{674} normal block at 0x00000000044656C0, 16 bytes long.
Data: < G > B0 CA 47 04 00 00 00 00 00 00 00 00 00 00 00 00
{673} normal block at 0x000000000447CAA0, 72 bytes long.
Data: < G (I > 90 CE 47 04 00 00 00 00 00 28 49 04 00 00 00 00
{665} normal block at 0x0000000004465620, 16 bytes long.
Data: < G > 20 CA 47 04 00 00 00 00 00 00 00 00 00 00 00 00
{664} normal block at 0x000000000447CA10, 72 bytes long.
Data: < (I G > 00 28 49 04 00 00 00 00 B0 C6 47 04 00 00 00 00
{633} normal block at 0x0000000004465580, 16 bytes long.
Data: < G > 90 C9 47 04 00 00 00 00 00 00 00 00 00 00 00 00
{632} normal block at 0x000000000447C980, 72 bytes long.
Data: <` G G > 60 C8 47 04 00 00 00 00 90 C5 47 04 00 00 00 00
{624} normal block at 0x00000000044654E0, 16 bytes long.
Data: < G > 00 C9 47 04 00 00 00 00 00 00 00 00 00 00 00 00
{623} normal block at 0x000000000447C8F0, 72 bytes long.
Data: < G G > D0 C7 47 04 00 00 00 00 C0 D4 47 04 00 00 00 00
{615} normal block at 0x0000000004465440, 16 bytes long.
Data: <p G > 70 C8 47 04 00 00 00 00 00 00 00 00 00 00 00 00
{614} normal block at 0x000000000447C860, 72 bytes long.
Data: <@ G G > 40 C7 47 04 00 00 00 00 80 C9 47 04 00 00 00 00
{606} normal block at 0x00000000044653A0, 16 bytes long.
Data: < G > E0 C7 47 04 00 00 00 00 00 00 00 00 00 00 00 00
{605} normal block at 0x000000000447C7D0, 72 bytes long.
Data: <0 G G > 30 D4 47 04 00 00 00 00 F0 C8 47 04 00 00 00 00
{597} normal block at 0x0000000004465300, 16 bytes long.
Data: <P G > 50 C7 47 04 00 00 00 00 00 00 00 00 00 00 00 00
{596} normal block at 0x000000000447C740, 72 bytes long.
Data: < 6I ` G > A0 36 49 04 00 00 00 00 60 C8 47 04 00 00 00 00
{586} normal block at 0x000000000447ACA0, 32 bytes long.
{585} normal block at 0x0000000004465260, 16 bytes long.
Data: < G > C0 C6 47 04 00 00 00 00 00 00 00 00 00 00 00 00
{584} normal block at 0x000000000447C6B0, 72 bytes long.
Data: < G G > 10 CA 47 04 00 00 00 00 20 C6 47 04 00 00 00 00
{570} normal block at 0x000000000447ABE0, 32 bytes long.
{569} normal block at 0x00000000044651C0, 16 bytes long.
Data: <0 G > 30 C6 47 04 00 00 00 00 00 00 00 00 00 00 00 00
{568} normal block at 0x000000000447C620, 72 bytes long.
Data: < G 6I > B0 C6 47 04 00 00 00 00 A0 36 49 04 00 00 00 00
{556} normal block at 0x0000000004465120, 16 bytes long.
Data: < G > A0 C5 47 04 00 00 00 00 00 00 00 00 00 00 00 00
{555} normal block at 0x000000000447C590, 72 bytes long.
Data: < G @ I > 80 C9 47 04 00 00 00 00 40 82 49 04 00 00 00 00
{547} normal block at 0x0000000004465080, 16 bytes long.
Data: < G > 10 C5 47 04 00 00 00 00 00 00 00 00 00 00 00 00
{546} normal block at 0x000000000447C500, 72 bytes long.
Data: <@ I 0 G > 40 82 49 04 00 00 00 00 30 D4 47 04 00 00 00 00
{540} normal block at 0x0000000004464FE0, 16 bytes long.
Data: < G > 00 C4 47 04 00 00 00 00 00 00 00 00 00 00 00 00
{539} normal block at 0x0000000004464F90, 16 bytes long.
Data: < G > E8 C3 47 04 00 00 00 00 00 00 00 00 00 00 00 00
{538} normal block at 0x000000000447C470, 72 bytes long.
Data: < :I I > 00 3A 49 04 00 00 00 00 C0 86 49 04 00 00 00 00
{537} normal block at 0x000000000447C3E0, 80 bytes long.
Data: < ? OF > 00 00 80 3F 00 00 00 00 90 4F 46 04 00 00 00 00
Object dump complete.
2. Call stack of the last leaked memory block at its malloc-time
ucrtbased.dll!heap_alloc_dbg_internal(const unsigned __int64 size=16, const int block_use=1, const char * const file_name=0x0000000000000000, const int line_number=0) Line 319 C++ ucrtbased.dll!heap_alloc_dbg(const unsigned __int64 size=16, const int block_use=1, const char * const file_name=0x0000000000000000, const int line_number=0) Line 450 C++ ucrtbased.dll!_malloc_dbg(unsigned __int64 size=16, int block_use=1, const char * file_name=0x0000000000000000, int line_number=0) Line 496 C++ ucrtbased.dll!malloc(unsigned __int64 size=16) Line 27 C++ inference_engined.dll!000007feb0f8a303() Unknown inference_engined.dll!000007feaf72a769() Unknown inference_engined.dll!000007feaf7805d0() Unknown inference_engined.dll!000007feaf7646c1() Unknown inference_engined.dll!000007feaf72bd67() Unknown inference_engined.dll!000007feaf72c410() Unknown inference_engined.dll!000007feaf72c64d() Unknown inference_engined.dll!000007feafa307d7() Unknown inference_engined.dll!000007feb02654c5() Unknown inference_engined.dll!000007feaf9f8c4a() Unknown inference_engined.dll!000007feafaab513() Unknown inference_engined.dll!000007feafa45962() Unknown inference_engined.dll!000007feb0758042() Unknown ucrtbased.dll!_initterm(void(*)() * first=0x000007feb0f94000, void(*)() * last=0x000007feb0f98098) Line 22 C++ inference_engined.dll!000007feb0f8c1a5() Unknown inference_engined.dll!000007feb0f8c097() Unknown inference_engined.dll!000007feb0f8c3b5() Unknown inference_engined.dll!000007feb0f8c5a1() Unknown ntdll.dll!LdrpRunInitializeRoutines() Unknown ntdll.dll!LdrpLoadDll() Unknown ntdll.dll!LdrLoadDll() Unknown KernelBase.dll!LoadLibraryExW() Unknown KernelBase.dll!LoadLibraryExA() Unknown kernel32.dll!LoadLibraryA() Unknown
3. Call stack of the first leaked memory block at its malloc-time
ucrtbased.dll!heap_alloc_dbg_internal(const unsigned __int64 size=80, const int block_use=1, const char * const file_name=0x0000000000000000, const int line_number=0) Line 319 C++ ucrtbased.dll!heap_alloc_dbg(const unsigned __int64 size=80, const int block_use=1, const char * const file_name=0x0000000000000000, const int line_number=0) Line 450 C++ ucrtbased.dll!_malloc_dbg(unsigned __int64 size=80, int block_use=1, const char * file_name=0x0000000000000000, int line_number=0) Line 496 C++ ucrtbased.dll!malloc(unsigned __int64 size=80) Line 27 C++ inference_engined.dll!000007feae30a303() Unknown inference_engined.dll!000007fead5ae4e0() Unknown inference_engined.dll!000007feacdbcca6() Unknown inference_engined.dll!000007feacc79ca8() Unknown ucrtbased.dll!_initterm(void(*)() * first=0x000007feae314000, void(*)() * last=0x000007feae318098) Line 22 C++ inference_engined.dll!000007feae30c1a5() Unknown inference_engined.dll!000007feae30c097() Unknown inference_engined.dll!000007feae30c3b5() Unknown inference_engined.dll!000007feae30c5a1() Unknown ntdll.dll!LdrpRunInitializeRoutines() Unknown ntdll.dll!LdrpLoadDll() Unknown ntdll.dll!LdrLoadDll() Unknown KernelBase.dll!LoadLibraryExW() Unknown KernelBase.dll!LoadLibraryExA() Unknown kernel32.dll!LoadLibraryA() Unknown
4. Address range of "inference_engined.dll" in the process for locating memory leaking codes
inference_engined.dll C:\Program Files (x86)\IntelSWTools\openvino_2019.2.242\deployment_tools\inference_engine\bin\intel64\Debug\inference_engined.dll N/A Yes Loading disabled by Include/Exclude setting. 137 7/19/2019 12:39 AM 000007FEACA40000-000007FEAF6B4000 [10336] ALG_Inference_Test.exe
Dear Wong, Jeremy,
Kindly attach your test program as a *.zip to this ticket and allow me to reproduce the issue.
Thanks for your cooperation !
Shubha
Shubha R. (Intel) wrote:Dear Wong, Jeremy,
Shubha
Dear Shubha,
Thanks for your reply. Unfortunately my original test program involves private modules (I should not disclose...). Additionally, I am not able to reproduce the issue after extract codes relevant to "inference_engined.dll" in a separate test program.
There is a few more observations...
1. The "memory leak" vanishes after removing CUDA (cuda 8.0) related codes in my original test program.
2. The "memory leak" vanishes if CUDA library (cuda 8.0) is unloaded before loading (using) inference_engined.dll
3. The "memory leak" appears if "Sleep(100)" is explicitly added between construction and destruction of an "InferenceEngine::Core" object
Finally, "inference_engined.dll" related codes only involve construction and destruction of an "InferenceEngine::Core" object (similar to the following)
InferenceEngine::Core *pCore = new InferenceEngine::Core; Sleep(100); delete pCore;
Dear Wong, Jeremy,
Wow. these are interesting observations. I respect and appreciate that you cannot share your private code. But if I understand you correctly, if you isolate OpenVino explicitly (keep it away from cuda), no memory leaks are observed ? But 3. The "memory leak" appears if "Sleep(100)" is explicitly added between construction and destruction of an "InferenceEngine::Core" object is interesting.
I will make a small demo program which is similar to your code snippet and file a bug if i can reproduce.
Thanks for your patience and interesting discussion !
Shubha
Dear Shubha,
Attached please find a small demo program (though I cannot repeat the problem with it)...
In addition, there are some more ways you could consider...
1. decode the addresses of "inference_engined.dll" on the call stacks to spot memory leaking codes
2. share with my relevant debug symbol of "inference_engined.dll" then I could decode relevant addresses on my own
3. I find out source codes of OpenVINO from git repo (open source already, right?) and build my own "inference_engined.dll" on my own......
Shubha
Dear Wong, Jeremy,
I'm sorry but I am confused. If you cannot repeat the problem with the attached demo program then how will it help me ?
Shubha
Let's make things simple. Just focus on the contents of my first message in this thread. The first message contains sufficient information to locate memory leaking codes. Competent software engineer should be capable to decode addresses on the call stacks based on the contents of my first message.
An alternate way is to share debug symbol (e.g. inference_engined.pdb) of the problem DLL (inference_engined.dll) for easy identification of memory leaking codes. OpenVINO is open source, why bother sharing debug symbol(s)?
Shubha
