6589 Discussions
How can I solve this problem? [ ERROR ] Device with "MYRIAD" name is not registered in the InferenceEngine
DWeiH1
Run ./classification_sample_async -d MYRIAD -i /Users/tinywolf/intel/openvino/deployment_tools/demo/car.png -m /Users/tinywolf/openvino_models/ir/FP16//classification/squeezenet/1.1/caffe/squeezenet1.1.xml
[ INFO ] InferenceEngine:
API version ............ 2.0
Build .................. 27579
Description ....... API
[ INFO ] Parsing input parameters
[ INFO ] Files were added: 1
[ INFO ]  /Users/tinywolf/intel/openvino/deployment_tools/demo/car.png
[ INFO ] Creating Inference Engine
Error on or near line 238; exiting with status 1
Sahira_Intel
Hi DWeiH1,
A couple questions for you:
  1. Can you provide more information about the system you're running on? Are you running OpenVINO inside a docker container?
  2. Can you please provide the command you used to convert the model to IR? Did you specify the data type in your command? (FP16 to deploy on Myriad, FP32 to deploy on the CPU)
If you would like to use Myriad as your target device, specify it as '-d MYRIAD' in your command to deploy your model.
Sahira
DWeiH1
Hi Sahira
1. I ran demo on MacBook Pro, MacOS Majove 10.14.6
2. The command is "./demo_security_barrier_camera.sh -d MYRIAD"
Sahira_Intel
Hi DWeiH1,
The current version of the Intel® Distribution of OpenVINO™ toolkit for macOS* supports inference on Intel CPUs only.
https://docs.openvinotoolkit.org/latest/_docs_install_guides_installing_openvino_macos.html
You can however run a VM (with Ubuntu 16.04) on a host Mac and you should be able to run inference on the NCS/NCS2.
Sahira
