6593 Discussions
Device with "CPU" name is not registered in the inference's on CPU
ROCK
Hi,i'm trying to run gesture_recognition_detection on raspberry pi 4 by using NCS2.
gesture_recognition_detection is combine of two xml download on https://download.01.org/opencv/2020/openvinotoolkit/2020.4/open_model_zoo/models_bin/1
and the model i use are:
1. asl-recognition-0004
2.person-detection-asl-0001
and type following to execute:
python3 gesture_recognition_demo.py \
-m_a /home/user/asl-recognition-0004.xml \
-m_d /home/user/person-detection-asl-0001.xml \
-i 0 \
-c ./msasl100-classes.json
i have check that PATH is currect. But it keep showing error "Device with "CPU" name is not registered in the inference's on CPU"
do anyone know why error occur?
ROCK
btw i have change the code like this:
-i 0 \
-d MYRIAD -c ./msasl100-classes.json
and the problem would be:
RuntimeError:Failed to compile layer "376/variance/Fused_Add_" : number of biased must equal to number of output channels per group, but :channels per group=1,biased=16
Rizal_Intel
Hi Rock,
You would need to add the argument
-d MYRIAD
for it to work.
It would then select the Neural Compute Stick 2 as to perform the inference. The default device is CPU but the Pi 4 is using ARM architecture which is not compatible with OpenVINO CPU plugin which focuses on Intel processors (which use the x86/AMD64 architecture).
Rizal
ROCK
Thanks for your reply.
I had already add the argument in  code like :
-i 0 \
do anyone know how to deal with it ?
ROCK
Sorry again...
I found that the new one reply in 10:02 PM is incorrect. Can MOD help me to delet it?
And th reply that i posted in 09:40 PM was the truely problem i got.
Adli
Hi ROCK 123,
I have replicated this case and got the same error. We are investigating this issue and will come back to you soon.
Adli
Adli
Hi ROCK 123,
Thank you for waiting. The 'asl-recognition' model and 'person-detection-asl' model are not supported on MYRIAD. The models are only supported on CPU and GPU. I apologize for the inconvenience.
Adli
Adli
Hi ROCK 123,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Adli
