Different inference result between Movidius 1 and Movidius 2
junyi
OS Platform: Ubuntu 16.04.5 LTS
OpenVINO Version: 2018 R5 (Build date:17 Dec 2018)
When running classification_sample, I got unexpected result when using different hardware
I using following command to run classification_sample on CPU
./classification_sample -d CPU -m model.xml -i image.png
and following command on Movidius 1 and Movidius 2
./classification_sample -d MYRIAD -m model.xml -i image.png
I was satisfied that OpenVINO could give me consistent result when using different hardware,
but when I test with Movidius 2 I got unexpected result that didn't align to CPU & Movidius 1
CPU Top 5 results
4 1.0000000 label #4
1 0.0000000 label #1
8 0.0000000 label #8
9 0.0000000 label #9
7 0.0000000 label #7
Movidius 1 Top 5 results
Movidius 2 Top 5 results
3 0.3332520 label #3
8 0.3332520 label #8
9 0.3332520 label #9
My question is what cause the inconsistent result
anchor__jiang
I met the save problem!
Tikhostoup__Dmitri
We have similar problem, certainly some NN models compute different, where NCS v2 delivers incorrect results.
My colleague posted detailed description of the problem here: https://software.intel.com/en-us/forums/computer-vision/topic/801760
almost a month ago, still no reply from Intel.
Jakub
I also faced the problem of incorrect predictions using NCS2 (described at https://software.intel.com/en-us/forums/computer-vision/topic/802216). In my case, I found a workaround of manually editing the XML file generated by the Model Optimizer, but it only works if the model is placed on CPU, not MYRIAD.
