Docker OpenVINO installation "install_openvino_dependencies.sh: not found"
Kobu_Intel
Docker OpenVINO build caused "install_openvino_dependencies.sh: not found" error using the default Dockerfile in the web below, would you please check this issue?
-- 2594k
/bin/sh: 1: /install_dependencies/install_openvino_dependencies.sh: not found
The command '/bin/sh -c curl -LOJ "${DOWNLOAD_LINK}" &&     tar -xzf ./*.tgz &&     cd l_openvino_toolkit* &&     sed -i 's/decline/accept/g' silent.cfg &&     ./install.sh -s silent.cfg &&     rm -rf /tmp/* &&     $INSTALL_DIR/install_dependencies/install_openvino_dependencies.sh' returned a non-zero code: 127
kobu@kobu-old:~/docker$
Thanks a lot,
BR/Kobu
SIRIGIRI_V_Intel
Hi Ryosuke,
The variable name INSTALL_DIR in line 32 and INSTALLDIR in line 33 are different variables. Make sure the names of these variables are same.
Replace INSTALLDIR variable to line 26 as mentioned below and build the Docker:
WORKDIR /tmp
ENV INSTALLDIR /opt/intel/openvino
RUN curl -LOJ "${DOWNLOAD_LINK}" && \
    tar -xzf ./*.tgz && \
    cd l_openvino_toolkit* && \
    sed -i 's/decline/accept/g' silent.cfg && \
    ./install.sh -s silent.cfg && \
    rm -rf /tmp/* && \
    $INSTALLDIR/install_dependencies/install_openvino_dependencies.sh
Hope this helps.
Ram prasad
SIRIGIRI_V_Intel
Hi Ryosuke,
WORKDIR /tmp
    rm -rf /tmp/* && \
Hope this helps.
Ram prasad
Kobu_Intel
Hi Ram,
Successfully done!
It should be good to modify the original instruction in the web.
Thanks!
BR/Kobu
SIRIGIRI_V_Intel
Thank you for your feedback. We will take your comments into consideration.
Ram prasad
