6585 Discussions
Docker container built on intel and to run on ARM
aliraza51
I have a Docker container created on intel pc but I have the necessity to run on ARM cpu.
Is there a system in order to convert this container or to add a layer in order to bypass this problem?
Iffa_Intel
These are the possible workaround for you:
  1. Follow the installation steps for ARM (validated on Raspberry Pi with Raspbian): Install OpenVINO toolkit for Raspbian OS
  2. Build from source for ARM: Build for Raspbian Stretch OS
  3. This thread might help (however, this is not officially validated)
  4. Use the OpenVINO Deployment Manager. (The operating system on the target system must be the same as the development system on which you are creating the package)
Sincerely,
Iffa
aliraza51
Sincerely,
Iffa
Thanks, have you a complete example. I have some container that I can see by docker container ls -a but I don't understand how to use buildx on it
Iffa_Intel
Greetings,
Intel will no longer monitor this thread since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Sincerely,
Iffa
