Docker support on OpenVINO
Tay__Choonkiat
Hi intel,
I try to install OpenVINO on a docker container, the installer complains
1. 'cpio' tool could not be found
The setup program requires 'cpio' tool to complete installation. Please make sure this tool is installed and its location is present in 'PATH' environment variable.
2. Intel® GPU is not detected on this machine
Installation can continue; however, GPU optimization will not be available for the product.
Any advise on these ?
Seunghyuk_P_Intel
Hi Tay,
1. You can insall "cpio" first and run openVINO installation.
    $ sudo apt-get install cpio
2. Your host machine should have GPU and driver ready.
    and when you run docker either you should give privilege access or give driver path.
    Even though your host system is not ready to use GPU, you can install OpenVINO, and start investigating with CPU engine for now.
Peter.
Ukhupacha
Hello!
Is it possible for you to share the steps for the dockerization of openVino?
Or broadly explain how you managed to do this.
Kindly,
JD
neko
Hi Zuniga, you can checkout this repo
Joel_E_
I checked the repo and it was R3 being used, can R4 also be used for this docker image?
Joel
neko
Hi Joel,
Yes it should work with R4 as well. I have created a slightly different version which works with
python 3.6. You can modify it to python 3.5 and use it. However, for running tests in demo folder (demo_squeezenet_download_convert_run.sh) you better use python 3.5
