6605 Discussions
Does OpenVINO support import/export feature with VPU?
Roxy1
Hello, I would like to know if the OpenVINO toolkit's VPU (Vision Processing Unit) supports the import/export feature. I know Feature Support Matrix and VPU devices support networks   page, but it doesn't list VPU on matrix. Could you please provide some information on this?
However, If VPU does not support import/export. I was wondering if it is possible to perform import/export on CPU instead and then perform inference on VPU within the same application(one process). Could you please advise if this is possible or if there are any potential issues I should be aware of? Thank you very much for your help.
Peh_Intel
Hi Roxy1,
Yes, OpenVINO Toolkit's VPU (Vision Processing Unit) supports the import/export feature.
You can run the following Python codes:
from openvino.runtime import Core
core = Core()
info = core.get_property("MYRIAD", "IMPORT_EXPORT_SUPPORT")
print(info)
Peh
Peh_Intel
Hi Roxy1,
This thread will no longer be monitored since we have provided answer. If you need any additional information from Intel, please submit a new question.
Peh
