6592 Discussions
Does OpenVINO2022.x support QuantizeLinear/DequantizeLinear?
North-man
My post is a similar issue to the post below.
https://community.intel.com/t5/Intel-Distribution-of-OpenVINO/openVino-inference-using-onnx-model/m-p/1460146
I believe OpenVINO supports QuantizeLinear/DeauantizeLinear layers and ONNX format models.
However, the model using QuantizeLinear/DeauantizeLinear layers (=Model1) gives different results depending on the OpenVINO 2021.4 and 2022.3.
For comparison, the model that does not use QuantizeLinear/DeauantizeLinear (=Models2) gives the same result for OpenVINO 2021.4 and 2022.3.
For further comparison, I also compared results when using different inference frameworks (e.g. TensorRT).
The conditions are as follows.
・model format is onnx.
・Windows10 and C++.
・output size = 1000 (using Generic imageNet)
The results are summarized below.
・The numbers in the table below are the first 10 of 1000
  OpenVINO
2021.4
OpenVINO
2022.3
Other framework
(TensorRT)
use QuantizeLinear/DeauantizeLinear (=Model1) 1.82228 2.83418 1.84796
-5.29731 -3.76114 -5.31353
-2.57535 -3.80294 -2.56074
0.815923 0.491049 0.816834
-5.83255 -4.85166 -5.85728
-3.84568 -1.81016 -3.84114
-4.65202 -5.18312 -4.6788
3.07942 1.29188 3.09532
2.51693 1.51579 2.54098
10.021 6.2427 10.0298
does not use
QuantizeLinear/DeauantizeLinear (=Model2)
1.92688 1.92688 1.92688
-4.5917 -4.5917 -4.5917
-3.09134 -3.09134 -3.09134
0.355102 0.355103 0.355103
-6.01955 -6.01955 -6.01955
-4.48821 -4.48821 -4.48821
-5.00235 -5.00235 -5.00235
2.16591 2.16591 2.16591
2.74276 2.74276 2.74276
11.9108 11.9108 11.9108
Only the combination of the model using QuantizeLinear/DeauantizeLinear and OpenVINO2022.3 has a large numerical difference.
Why is this?
Please let me know if you get similar results in your environment and if so what the problem is.
I wanted to attach the model and the input image, but it was not possible due to size restrictions. Please let me know if there is a better way.
Thank you for your support.
Hari_B_Intel
Hi North-man
Apology for the late response, as we are investigating the issue on the latest OpenVINO 2023.0, which causes the results not to be similar to the oldest version of OpenVINO.
For your information, this issue only seems for the oldest CPU, and we cannot reproduce it on Intel Gen 9 processors and above.
For your case, we suggest using the older version of OpenVINO, which is the OpenVINO 2021 LTS version based on your processor.
I hope this information helps, and we would like to thank you for bringing up this bug so that we can further improve.
Thank you
North-man
Hi Hari_B_Intel,
Thank you for your report.
Here's the CPU I'm using:
  • CPU : Intel(R) Xeon(R) W-2145 CPU @ 3.70GHz 3.70 GHz
It's a Xeon, so I don't know the generation number, but I think it's older than the Gen 9. (Gen 6?)
Ok, I'd like to check again with a Gen 9 processors and above.
North-man.
Wan_Intel
Hi North-man,
I hope everything is going well for you. Just wanted to know if the issue has been resolved when using Gen 9 processors and above.
Wan
North-man
Hi Wan,
Thank you for your response.
We are currently checking the behavior with the 10th generation Core (Intel (R) Core (TM) i7-10610U),
but the results look similar to the previous post (result of  old CPU).
Also, we are currently ordering 12th generation CPUs and will confirm once they are available.
After that, I would like to check the results again.
This may take about 2 weeks.
North-man.
Wan_Intel
Hi North-man,
Thanks for the update.
We'll wait for the inference result using Gen 12 from your end. Meanwhile, could you please share the inference script with us so that we can replicate the issue from our end?
Wan
North-man
Hi Wan,
OK,
I will email you the code, model, data, and results that I used for my evaluation.
Reagrds,
North-man.
Wan_Intel
Hello North-man,
I've received your email. We'll investigate the issue and update you at the earliest.
Wan
Wan_Intel
Hello North-man,
Thanks for your patience.
We've replicated the issue from our end using Gen 10 processors. We encountered the same issue as yours when using Gen 10 processors, and our developers are investigating the issue.
On another note, the inference results are correct when using Gen 11 processor and above. Please get back to us after you have checked with Gen 12 processors from your end.
Wan
Wan_Intel
Hello North-man,
Thanks for your patience. We've received feedback from relevant team.
Here are the root causes of the quantized model not showing the right results on older CPUs:
  1. We can have a saturation issue if the CPU doesn't have VVNI. In official documents, "the Intel® Deep Learning Boost (Intel® DL Boost)" is used instead of VVNI.
  2. The issue will be resolved if you use a not quantized model, which means using FP32 because INT8 will show a saturation issue on a CPU that doesn't have VVNI.
  3. Another workaround is to set up a DNNL_MAX_CPU_ISA=AVX2 environment during quantization (+ accuracy check algorithm) if the target platform is AVX2.
Here is the documentation on the saturation issue: https://docs.openvino.ai/2023.0/pot_saturation_issue.html. The issue is not OpenVINO runtime or CPU defect.
Wan
North-man
Hi Wan,
Thank you for the information on the cause of this issue.
I understand the root cause and occurrence conditions.
Preparations for the 12th generation CPU, which is my work, are delayed,
but I would like to close the issue if I can confirm it.
North-man.
Wan_Intel
Hello North-man,
Noted. We'll wait for your replication results. Please get back to us if you have the latest update.
Wan
North-man
Hi Wan,
Sorry for the late reply.
I checked the results on a 10th generation CPU and 12th generation CPU.
・Program : classification_sample_async.exe (C++ Sample)
・Model : Model1_softmax.onnx (QuantizeLinear/DequantizeLinear model)
・Input : Zebra-1_227x227.jpg or bmp
■Core i7-10610U 1.8GHz (10th Generation)
OpenVINO Version2021.4.7522022.3.02023.0.0
Top10 result(classId, value)5490.20408949040.12256329040.1246897
9220.09682764180.05088754180.0513055
4460.08067663180.04278333180.0437959
8150.05926035630.02251325630.0227482
7940.04992547720.01998047720.019438
9710.02520596970.01876016970.019129
5910.02288053110.01815063110.0184334
7210.0208825770.0178132770.017797
9160.01789643160.01601753160.016454
6110.01637767000.01495157000.0149051
■Core i7-12700 2.1GHz (12th Generation)
Top10 result(classId, value)5490.20408945490.20343925490.2034393
9220.09682769220.09148429220.0914842
4460.08067664460.0802964460.0802961
8150.05926038150.0598898150.059889
7940.04992547940.04737917940.0473791
9710.02520599710.02427559710.0242755
5910.02288055910.02397445910.0239744
7210.02088257210.01977067210.0197706
9160.01789649160.01753699160.0175369
6110.01637766110.0172266110.017226
12th generation CPUs have better results!
OpenVINO2022 and 2023 are almost the same result as 2021.
you are right!
Thank you for your help in resolving the problem!
Notrh-man.
North-man
The table was misaligned, so I reshaped it.
Top10 result
(classId, value)
549, 0.2040894904,
0.1225632
904,
0.1246897
 922, 0.0968276418,
0.0508875
418,
0.0513055
 446, 0.0806766318,
0.0427833
318,
0.0437959
 815,
0.0592603
563,
0.0225132
563,
0.0227482
 794, 0.0499254772,
0.0199804
772,
0.019438
 971, 0.0252059697,
0.0187601
697,
0.019129
 591, 0.0228805311,
0.0181506
311,
0.0184334
 721, 0.020882577,
0.0178132
77,
0.017797
 916, 0.0178964316,
0.0160175
316,
0.016454
 611, 0.0163776700,
0.0149515
700,
0.0149051
Top10 result
(classId, value)
549, 0.2040894549,
0.2034392
549,
0.2034393
 922, 0.0968276922,
0.0914842
922,
0.0914842
 446, 0.0806766446,
0.080296
446,
0.0802961
 815, 0.0592603815,
0.059889
815,
0.059889
 794, 0.0499254794,
0.0473791
794,
0.0473791
 971, 0.0252059971,
0.0242755
971,
0.0242755
 591, 0.0228805591,
0.0239744
591,
0.0239744
 721, 0.0208825721,
0.0197706
721,
0.0197706
 916, 0.0178964916,
0.0175369
916,
0.0175369
 611, 0.0163776611,
0.017226
611,
0.017226
On 12th Generation CPU, OpenVINO2022 and 2023 are almost the same result as 2021.
For 10th generation CPU, I will use OpenVINO2021.
For 11th generation CPU and above, I can also use OpenVINO2022 or 2023.
Wan_Intel
Hello North-man,
Thanks for sharing your replication result with us.
Glad to know that your issue has been resolved. This case will no longer be monitored as the issue has been resolved. If you need additional information from Intel, please submit a new question.
Best,
Wan
