6597 Discussions
E: [ncAPI] [0] checkGraphMonitorResponse:1066 XLink error, rc: X_LINK_TIMEOUT
liu__feifei
I run the object_detection_demo on ncs2 and after a while I encountered the following problem.
[ INFO ] Loading plugin
	API version ............ 1.4
	Build .................. 17328
	Description ....... myriadPlugin
[ INFO ] Loading network files
[ INFO ] Batch size is forced to  1.
[ INFO ] Checking that the inputs are as the demo expects
[ INFO ] Checking that the outputs are as the demo expects
[ INFO ] Loading model to the plugin
[ INFO ] Create infer requst, start inference.
E: [xLink] [         0] dispatcherEventReceive:308	dispatcherEventReceive() Read failed -4 | event 0x7faa3e7fbe30 USB_WRITE_RESP
E: [xLink] [         0] eventReader:254	eventReader stopped
E: [xLink] [         0] dispatcherWaitEventComplete:694	waiting is timeout, sending reset remote event
E: [ncAPI] [         0] checkGraphMonitorResponse:1066	XLink error, rc: X_LINK_TIMEOUT
E: [ncAPI] [         0] ncGraphQueueInference:3327	Can't get trigger response
What problem caused this error?Can someone help me?
Shubha_R_Intel
Dear liu, feifei
 I noticed that you are using an older version of OpenVino ( API version ............ 1.4). Please download and install OpenVino 2019R2 which was released last week. Hopefully your issue will be fixed in the new release.
Hope it helps !
Shubha
