[ ERROR ] Cannot find plugin for device: Default
Liu__Xiaowei
When I running  ./demo_squeezenet_download_convert_run.sh -d -MYRIAD
target = -MYRIAD
target_precision = FP32
Downloading the Caffe model and the prototxt
Installing dependencies
Run sudo -E apt -y install build-essential python3-pip virtualenv cmake libpng12-dev libcairo2-dev libpango1.0-dev libglib2.0-dev libgtk2.0-dev libswscale-dev libavcodec-dev libavformat-dev libgstreamer1.0-0 gstreamer1.0-plugins-base
Hit:1 http://mirrors.tuna.tsinghua.edu.cn/ubuntu xenial InRelease
Get:2 http://mirrors.tuna.tsinghua.edu.cn/ubuntu xenial-updates InRelease [109 kB]
Get:3 http://mirrors.tuna.tsinghua.edu.cn/ubuntu xenial-backports InRelease [107 kB]
Get:4 http://mirrors.tuna.tsinghua.edu.cn/ubuntu xenial-security InRelease [107 kB]
Hit:5 http://ppa.launchpad.net/damien-moore/codeblocks-stable/ubuntu xenial InRelease
Hit:6 http://ppa.launchpad.net/deadsnakes/ppa/ubuntu xenial InRelease
Hit:7 http://ppa.launchpad.net/fkrull/deadsnakes/ubuntu xenial InRelease
Hit:8 http://ppa.launchpad.net/jonathonf/python-3.6/ubuntu xenial InRelease
Fetched 323 kB in 3s (97.8 kB/s)
Reading package lists... Done
Building dependency tree
Reading state information... Done
260 packages can be upgraded. Run 'apt list --upgradable' to see them.
build-essential is already the newest version (12.1ubuntu2).
libcairo2-dev is already the newest version (1.14.6-1).
libpango1.0-dev is already the newest version (1.38.1-1).
cmake is already the newest version (3.5.1-1ubuntu3).
gstreamer1.0-plugins-base is already the newest version (1.8.3-1ubuntu0.2).
libglib2.0-dev is already the newest version (2.48.2-0ubuntu4.1).
libgstreamer1.0-0 is already the newest version (1.8.3-1~ubuntu0.1).
libgtk2.0-dev is already the newest version (2.24.30-1ubuntu1.16.04.2).
libpng12-dev is already the newest version (1.2.54-1ubuntu1.1).
libavcodec-dev is already the newest version (7:2.8.15-0ubuntu0.16.04.1).
libavformat-dev is already the newest version (7:2.8.15-0ubuntu0.16.04.1).
libswscale-dev is already the newest version (7:2.8.15-0ubuntu0.16.04.1).
python3-pip is already the newest version (8.1.1-2ubuntu0.4).
virtualenv is already the newest version (15.0.1+ds-3ubuntu1).
0 upgraded, 0 newly installed, 0 to remove and 260 not upgraded.
The directory '/home/liuxiaowei/.cache/pip/http' or its parent directory is not owned by the current user and the cache has been disabled. Please check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
The directory '/home/liuxiaowei/.cache/pip' or its parent directory is not owned by the current user and caching wheels has been disabled. check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
Requirement already satisfied: pyyaml in /usr/local/lib/python3.6/site-packages
Requirement already satisfied: requests in /usr/local/lib/python3.6/site-packages
Requirement already satisfied: chardet<3.1.0,>=3.0.2 in /usr/local/lib/python3.6/site-packages (from requests)
Requirement already satisfied: certifi>=2017.4.17 in /usr/local/lib/python3.6/site-packages (from requests)
Requirement already satisfied: urllib3<1.25,>=1.21.1 in /usr/local/lib/python3.6/site-packages (from requests)
Requirement already satisfied: idna<2.9,>=2.5 in /usr/local/lib/python3.6/site-packages (from requests)
You are using pip version 9.0.3, however version 18.1 is available.
You should consider upgrading via the 'pip install --upgrade pip' command.
Run /opt/intel/computer_vision_sdk_2018.4.420/deployment_tools/demo/../model_downloader/downloader.py --name "squeezenet1.1" --output_dir "/home/liuxiaowei/openvino_models/FP32"
###############|| Start downloading models ||###############
...100%, 9 KB, 40019 KB/s, 0 seconds passed ========= squeezenet1.1.prototxt ====> /home/liuxiaowei/openvino_models/FP32/classification/squeezenet/1.1/caffe/squeezenet1.1.prototxt
###############|| Start downloading weights ||###############
...100%, 4834 KB, 116 KB/s, 41 seconds passed ========= squeezenet1.1.caffemodel ====> /home/liuxiaowei/openvino_models/FP32/classification/squeezenet/1.1/caffe/squeezenet1.1.caffemodel
###############|| Start downloading topologies in tarballs ||###############
###############|| Post processing ||###############
========= Changing input dimensions in squeezenet1.1.prototxt =========
Configure Model Optimizer
INTEL_CVSDK_DIR environment variable is not set. Trying to run ./setvars.sh to set it.
[setupvars.sh] OpenVINO environment initialized
Install Model Optimizer dependencies
Hit:2 http://mirrors.tuna.tsinghua.edu.cn/ubuntu xenial-updates InRelease
Hit:3 http://mirrors.tuna.tsinghua.edu.cn/ubuntu xenial-backports InRelease
Hit:4 http://mirrors.tuna.tsinghua.edu.cn/ubuntu xenial-security InRelease
python3-venv is already the newest version (3.5.1-3).
libgfortran3 is already the newest version (5.4.0-6ubuntu1~16.04.11).
Requirement already satisfied: networkx>=1.11 in /usr/local/lib/python3.6/site-packages (from -r /opt/intel/computer_vision_sdk_2018.4.420/deployment_tools/model_optimizer/install_prerequisites/../requirements_caffe.txt (line 1))
Requirement already satisfied: numpy>=1.12.0 in /usr/local/lib/python3.6/site-packages (from -r /opt/intel/computer_vision_sdk_2018.4.420/deployment_tools/model_optimizer/install_prerequisites/../requirements_caffe.txt (line 2))
Requirement already satisfied: protobuf==3.5.1 in /usr/local/lib/python3.6/site-packages (from -r /opt/intel/computer_vision_sdk_2018.4.420/deployment_tools/model_optimizer/install_prerequisites/../requirements_caffe.txt (line 3))
Requirement already satisfied: decorator>=4.3.0 in /usr/local/lib/python3.6/site-packages (from networkx>=1.11->-r /opt/intel/computer_vision_sdk_2018.4.420/deployment_tools/model_optimizer/install_prerequisites/../requirements_caffe.txt (line 1))
Requirement already satisfied: six>=1.9 in /usr/local/lib/python3.6/site-packages (from protobuf==3.5.1->-r /opt/intel/computer_vision_sdk_2018.4.420/deployment_tools/model_optimizer/install_prerequisites/../requirements_caffe.txt (line 3))
Requirement already satisfied: setuptools in /usr/local/lib/python3.6/site-packages (from protobuf==3.5.1->-r /opt/intel/computer_vision_sdk_2018.4.420/deployment_tools/model_optimizer/install_prerequisites/../requirements_caffe.txt (line 3))
[WARNING] All Model Optimizer dependencies are installed globally.
[WARNING] If you want to keep Model Optimizer in separate sandbox
[WARNING] run install_prerequisites.sh venv {caffe|tf|mxnet|kaldi|onnx}
Convert a model with Model Optimizer
Target folder /home/liuxiaowei/openvino_models/ir/squeezenet1.1/FP32 already exists. Skipping IR generation../demo_squeezenet_download_convert_run.sh: line 181: If you want to convert a model again, remove the entire ${$ir_dir} folder. ${run_again}: bad substitution
Build Inference Engine samples
Target folder /home/liuxiaowei/inference_engine_samples already exists. Skipping samples building.If you want to rebuild samples, remove the entire /home/liuxiaowei/inference_engine_samples folder. Then run the script again
Run Inference Engine classification sample
Run ./classification_sample -d -MYRIAD -i /opt/intel/computer_vision_sdk_2018.4.420/deployment_tools/demo/../demo/car.png -m /home/liuxiaowei/openvino_models/ir/squeezenet1.1/FP32/squeezenet1.1.xml
[ INFO ] InferenceEngine:
    API version ............ 1.4
    Build .................. 17328
[ INFO ] Parsing input parameters
[ INFO ] Files were added: 1
[ INFO ]     /opt/intel/computer_vision_sdk_2018.4.420/deployment_tools/demo/../demo/car.png
[ INFO ] Loading plugin
Error on or near line 215; exiting with status 1
I am very hurry ,thank you so much.
nikos1
Valued Contributor I
Please try FP16
nikos1
Hello Xiaowei,
The error comes from a typo - please try again without the -MYRIAD (just use -d MYRIAD)
./classification_sample -d MYRIAD -i /opt/intel/computer_vision_sdk_2018.4.420/deployment_tools/demo/../demo/car.png -m /home/liuxiaowei/openvino_models/ir/squeezenet1.1/FP32/squeezenet1.1.xml
And lease try FP16 when you generate IR or you will get this error
[ ERROR ] [VPU] Unsupported network precision : FP32
To generate FP16 IR you can add --data_type=FP16 to the model optimizer command.
Let us know if you have any issues.
Nikos
Liu__Xiaowei
thank you very much
nikos1
You are welcome!
Let us now if you see any more issues.
kind regards,
nikos
Liu__Xiaowei
sorry I don't quite understand,Can you tell me some detail? such as how to use FP16. because I use ./demo_squeezenet_download_convert_run.sh -d CPU also have same error
Hyodo__Katsuya
Innovator
@Liu, Xiaowei It is as nikos says. Just execute the following. The file of FP16 is automatically generated. mistake ー> "-d -MYRIAD" correct ー> "-d MYRIAD" - When using NCS or NCS 2 or GPU ./demo_squeezenet_download_convert_run.sh -d MYRIAD - When using CPU ./demo_squeezenet_download_convert_run.sh -d CPU
Liu__Xiaowei
Thank you very much. The demo have completed successfully. I first use this NCS. Thank you again
